Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
104 registered members (antonmnster, Astro14, 5AcresAndAFool, 77GrandPrix, Alfred_B, 2015_PSD, 9 invisible), 2,182 guests, and 45 spiders.
Topics306,108
Posts5,286,598
Members71,586
Towing Safely post #5415776 04/28/20 04:21 PM
wwillson Offline OP
Administrator
Administrator
I have a couple motivations to post this here from my other website. There are many eyes here and few there and I would like to get as many comments as possible, but I won't post it here, because I don't want Google to index it here. I would also like to some folks here to sign up and contribute there :-)
Please let me know what you think and what you would add or modify.
https://rvthe.us/community/threads/towing-safely.74/#post-203
Thanks,
Wayne
Re: Towing Safely post [Re: wwillson] #5415798 04/28/20 04:54 PM
supton Offline
I don't tow often, but one thing I do is "check often". Like, after 20-30 minutes (or miles), check everything. chains still attached, lights still working, no tires or hubs getting hot? Whenever I stop I do a quick check, make sure nothing has changed.
Something I've gotten bit by a couple times is potholes and uneven ground. It becomes very easy to drag the hitch. For a while I carried around some cut up 2x's so that I could level off if I needed to (if I was towing an RV I might have a stack already, being the cheapskate that I am).
Also, whenever I back up my trailer and manage to have a spotter, I tell them "if you can't see me in the mirror then I can't see you". It might be helpful to work out some hand commands so that all are on the same page.
Something I have only recently had a chance to use is a backup camera. I bought a cheapo one to go onto my rearview mirror for my truck, as it has such lousy rearwards visibility--but thought ahead and bought a camera to put onto my enclosed trailer, so I could see what was behind me. And wired it up so that I could easily switch between the two. For what it cost, and the work to install, it seems like a cheap way to make things better when you have to back up solo.
Edit: I tow rarely, so I'd take the above with a grain of salt.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Towing Safely post [Re: wwillson] #5415808 04/28/20 05:03 PM
wwillson Offline OP
Administrator
Administrator
Supton - these are great suggestions! I do the same - my rule is when I stop I do a walk-around and check the hitch area, feel the hubs to see if they are hot, etc.
Thanks
Re: Towing Safely post [Re: wwillson] #5415810 04/28/20 05:04 PM
J
JimPghPA Online Content
Online Content
J
I have seen people using very old dried out cracking tires that were obviously under-inflated and barely an adequate size for the weight of the trailer (RV) they are being used on even when the tires were new, driving at faster speeds than I would normally drive at on highways.
I shake my head and think that they have no idea how serious a blow out can be.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Towing Safely post [Re: wwillson] #5415835 04/28/20 05:37 PM
Z
Zaedock Offline
Z
As others mentioned, I check all my equipment at fuel stops. I tow often, and find that tires are the most important thing to keep tabs on.
My last trip to Moab, I brought 3 spare tires and used 2 of them! One for me, and one for a friend who was already on his spare.
The road debris (mostly tire "gators") was horrible.
Regarding a spotter, I feel comfortable enough not to need one, but it's not a bad idea in a camp ground as a precaution.
I recently replaced my ball/ball mount. My son asked why as it didn't look too bad. I showed him the elongation caused by the pin and corrosion inside. It's now retired to ATV duty.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Towing Safely post [Re: wwillson] #5415896 04/28/20 06:40 PM
Spartanfool Offline
Some states require that the safety chains be crossed to prevent the tow bar from hitting the pavement in the event it becomes disconnected.
Re: Towing Safely post [Re: wwillson] #5415994 04/28/20 08:59 PM
B
bullwinkle Offline
B
Select a ball mount that has your trailer level or slightly higher in the front than the back. That way, when you load it with payload slightly in front of the axle, the trailer won't dive on bumps. Can't over-emphasize how important trailer tire inflation & condition is-especially with the Chinese trailer tires that are common now. I'm getting to the point that I carry TWO spares on long trips with a trailer!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Towing Safely post [Re: wwillson] #5416142 04/29/20 07:04 AM
Donald Offline
Tow with a 3/4 ton pickup. Even if the trailer brakes (surge brakes) don't work all that well, you should be OK.
2015 Ford F-250 w/Powerstroke
Re: Towing Safely post [Re: wwillson] #5416223 04/29/20 08:52 AM
F
Fitter30 Offline
F
Most utility trailers are not towed to often. Most people check their tires but never look at he tire stem. Found out that tire experts recommend replace tires 7 years. Stems just seem to look worse earlier and they.like to fail when adding air to the tire.
Re: Towing Safely post [Re: Donald] #5416439 04/29/20 01:08 PM
02SE Offline
That's good advice if the trailer doesn't overload the 3/4 ton truck. A 3/4 ton truck would be very overloaded with the 5th wheel trailer we tow.
The point: Make sure the tow vehicle can safely tow the load.
Re: Towing Safely post [Re: wwillson] #5416871 04/29/20 09:28 PM
B
bunnspecial Online Content
Online Content
B
I have very little towing experience, but saw something this past weekend that scared me to death.
Guy was pulling one of the little U-Hauls behind a 1/2 ton at 70mph about a quarter mile ahead of me. The next thing I know, I see sparks flying, things going squirrely, and him quickly getting into the shoulder. I had plenty of time to slow down and actually came to a near complete stop along with getting over into the other lane.
What I saw when I passed was the hitch from his truck scarred and laying in the road, and the tongue on the ground. Fortunately, it looked like the chains(crossed over) had held it well enough for him to get it off the road and stopped.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Towing Safely post [Re: wwillson] #5416877 04/29/20 09:34 PM
spasm3 Online Happy
Online Happy
Wayne
One thing i always do, is after i have engaged the ball on the tongue of the hitch , i feel under with my hand to make sure coupler latch is under the ball, not on top of it. Might be what happened with what bunnspecial witnessed.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
