Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
95 registered members (AlienBug, 4WD, 53' Stude, A310, 10WSmuckers, ABN_CBT_ENGR, 6 invisible), 2,493 guests, and 31 spiders.
Topics305,939
Posts5,283,339
Members71,540
2015 Grand Cherokee 5.7 Coolant temps #5415701 04/28/20 03:23 PM
E
Env1ous Offline OP
E
Hey all,
I looked but didn't find exactly what I was looking for. I have a 2015 WK2 with the 5.7. What are the normal coolant operating temps and what temp does the low and high speed fans kick on at?
I do have HD cooling package - Trailer Tow Group IV
Thanks guys!
Re: 2015 Grand Cherokee 5.7 Coolant temps [Re: Env1ous] #5415822 04/28/20 05:22 PM
1
14Accent Offline
1
Well, I dug and dug through the service information but I just could NOT find a published spec from Chrysler on the fan turn-on temps. I did find that all Hemi's came with a 195 degree thermostat, and the ones I've driven seems to hover in the 210-215 range.
There are, apparently, two different cooling fans used depending on whether you have the "Max Cooling" package. The standard fan is 350 watts, controlled by a simple set of relay's that control either high or low speed. The Max Cool package has an 850 watt fan that is PWM controlled directly by the PCM, giving it both higher cooling capacity but a much broader range of speeds to work with.
I would have to imagine that when you say your truck has HD cooling that it includes the bigger fan. All I could find was that the PCM has an internal logic that uses engine coolant temp, oil temp, trans fluid temp, ambient temp, and A/C pressures to decide when and at what speed to run the fan.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2015 Grand Cherokee 5.7 Coolant temps [Re: Env1ous] #5415832 04/28/20 05:35 PM
Skippy722 Online Happy
Online Happy
Hemi‘s uses a 203F thermostat. My truck was hovering around 210F going down the highway today.
My Durango, with tow package/heavy duty cooling, wouldn’t ramp the fan to max until the coolant temp was 225’ish. Otherwise it’s variable, it’ll spin slow enough you can’t really hear it, crank all the way up and move some serious air, and it can go in between.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: 2015 Grand Cherokee 5.7 Coolant temps [Re: Env1ous] #5416197 04/29/20 08:26 AM
E
Env1ous Offline OP
E
Hey thanks guys!
Yeah I was digging last night and didn't find much. I believe with the Tow Package and HD cooling I do have the ECU controlled fan. I was curious because I was idling a few days ago after a drive and plugged in the Torque app and I was hovering around 225 and the fans didn't even seem to want to turn on. But it did start dropping slowly. I am going to take a look possibly today and just let it idle and see what the fans do and make sure it turns on with the AC and stuff.
Re: 2015 Grand Cherokee 5.7 Coolant temps [Re: Env1ous] #5416706 04/29/20 06:14 PM
B
bigdawglanecreek Offline
B
Check out www.jeepgarage.org. Had some good information
