Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
79 registered members (830Lee, ABN_CBT_ENGR, 4WD, 55hambone, 555, Al, 7 invisible), 2,082 guests, and 35 spiders.
Topics306,053
Posts5,286,514
Members71,593
Page 1 of 3 1 2 3
Extract oil....not for me. #5415694 04/28/20 03:14 PM
sloinker Offline OP
I could see the time saving benefits if you have a filter on top of the engine but that is all. I have a lift and during the time the vehicle is up in the air I do a thorough inspection of the brakes,suspension,steering,exhaust, CV/U joints. Check for leaks and generally look for anything out of the ordinary. Of course you can also do the other under the car fluid services as required. So I guess the question is, do folks that use extractors forego the other maintenance that requires being under the car. I see many flush the transmission without changing the filter, why bother? I guess it isn't too surprising on a board that the majority is fixated on the lowest cost /longest OCI available for their vehicle. Do oil extractor folks do the required inspections that require being under the car or do they skip them?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Extract oil....not for me. [Re: sloinker] #5415710 04/28/20 03:29 PM
L
loneryder Offline
L
Not many people would argue with you if they had Lifts. If I had a lift, I would totally agree with you. When I found out that Mercedes dealers used extraction, I started using one. The filter is on the top and it's the only thing I can do on the car these days.
But you are correct in being able to inspect everything.
Re: Extract oil....not for me. [Re: sloinker] #5415730 04/28/20 03:45 PM
supton Online Content
Online Content
I skipped 'em. In NH it goes on a lift once/year no matter what due to safety inspection.
Despite "never" being under the car I still caught a CV boot when it gave up, on my one car that I did topside oil changes on. [On that car the oil filter could only be changed topside. And it had a bellypan with at least 10 bolts holding it in place.]
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Extract oil....not for me. [Re: sloinker] #5415731 04/28/20 03:46 PM
L
Lolvoguy Offline
L
So I guess the question is, do folks that use extractors forego the other maintenance that requires being under the car. …. Do oil extractor folks do the required inspections that require being under the car or do they skip them?
What other "maintenance" are you referring to?
It's not like everyone is driving around in a 64 Fury with greasable u joints, ball joints and tie rod ends.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Extract oil....not for me. [Re: sloinker] #5415736 04/28/20 03:50 PM
Donald Online Content
Online Content
If you can get the drain plug out then why not drain the oil. I have the Fumoto on my Subaru and I can just feel for the level to turn. So I do not have to get under very far.
Marine engines are what typically have used extractors I thought.
2015 Ford F-250 w/Powerstroke
Re: Extract oil....not for me. [Re: Lolvoguy] #5415784 04/28/20 04:33 PM
L
Leo99 Offline
L
Exactly. Just because you're doing stuff doesn't mean your vehicle will last or drive longer or better.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Extract oil....not for me. [Re: sloinker] #5415789 04/28/20 04:44 PM
PimTac Offline
My sense is that extraction is great for vehicles with the filter accessible from above. If one has to get under the car then the advantage goes away.
I do agree with the idea that getting underneath allows one to visually inspect for anything amiss. You can catch problems early on. That goes for above as well. A quick check around plus topping off washer fluids makes sense.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Extract oil....not for me. [Re: sloinker] #5415805 04/28/20 05:01 PM
2015_PSD Offline
The filter on two of my vehicles is on top of the engine, but I still drain from below. For me, there is no advantage to extraction.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Extract oil....not for me. [Re: Leo99] #5415825 04/28/20 05:28 PM
I
Imp4 Offline
I
So maybe Sloinker's use of the word 'maintenance' was misplaced but additional visual inspection is certainly a reasonable expectation when under a vehicle.
All it takes is one time of spotting a torn CV or ball joint boot early to make it worth while.
Re: Extract oil....not for me. [Re: sloinker] #5415840 04/28/20 05:46 PM
J
JC1 Offline
J
I have an extractor. I normally don't use them for oil changes on the vehicles. Primarily used for Lawnmower, Snowblower and fluid extractions for Power steering reservoirs, P/S lines etc.
Usually inspect stuff when I'm swapping winter tires twice a year and when I do oil changes.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Extract oil....not for me. [Re: sloinker] #5415918 04/28/20 07:00 PM
sloinker Offline OP
In the owners manual, maintenance manual there are time and mileage intervals for all I noted. Many can only be done from under the vehicle.
Re: Extract oil....not for me. [Re: sloinker] #5415993 04/28/20 08:59 PM
E
Eddie Offline
E
One can reach an age where it is very difficult to crawl under to do the oil drain. At that point we have a choice of suck out the oil and replace or let someone else drain it. I will most probably do the suck it out method IF the design lets my get ~ 95% out. Ed
2014 CX5 Touring 2.5L :-)
Re: Extract oil....not for me. [Re: sloinker] #5416004 04/28/20 09:11 PM
E
E365 Offline
E
Even on cars with filters below, extracting all the oil from above makes for much less hassle and mess for me.
99% of the oil transports itself into the sealed extractor vessel, as if by magic. Then it’s an easy, clean pour with the integrated spout directly into my recycling jugs.
Or I could let 5+ quarts of scalding hot oil come blasting out the drain hole that’s 8” from my face as I lay on my back and hope I catch it all in the catch pan. Then slide the sloshing pan out from under the car, again hoping I don’t spill more on the way to my recycling jugs.
Been using an oil extractor every chance I can for 15+
years and I’ll never go back.
Plus, changing oil on outdoor power equipment with one is by-far the best way to do it.
Whatever's on sale...
Re: Extract oil....not for me. [Re: E365] #5416023 04/28/20 09:38 PM
R
raburn2906 Offline
R
Pretty dramatic...
2008 Ford F150 XLT 4.6L
210,834 - Valvoline FS Max Life 5W30 - Motorcraft FL820-S
2001 Ford F150 XLT 5.4L
233,655 - Valvoline FS Max Life 5W30 - Wix 51372
Re: Extract oil....not for me. [Re: sloinker] #5416025 04/28/20 09:44 PM
dblshock Offline
I extract every other OCI now with the COVID-19 slow down may extract 2:1 stay tuned.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Page 1 of 3 1 2 3
