Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
55 registered members (Ag76, 10WSmuckers, bdcardinal, BlakeB, Aero540T, 3 invisible), 1,363 guests, and 28 spiders.
Topics306,113
Posts5,287,769
Members71,602
2002 Cadillac Deville run or fix it? #5415682 04/28/20 02:56 PM
B
Brybo86 Offline OP
B
So someone is giving my dad a 2002 Cadillac Deville...
apparently is runs but has an ABS light and CEL on.
needs new tires.
has 120k
he wants to park it in my driveway so we can fix it up and then he can drive it....
I'm worried if it comes to my house it will never leave my driveway...
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415687 04/28/20 03:01 PM
B
Barkleymut Offline
B
take a piece of electrical tape and put it over the CEL and ABS lights and drive it.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415738 04/28/20 03:50 PM
J
JimPghPA Online Content
Online Content
J
In some places the ABS does not have to be fixed to pass inspection. The vehicle will just take a little bit more distance to stop if the driver hits the brakes hard enough to lock the tires up.
That said, at that age and millage that year and model of vehicle is an unbelievable money pit. If you keep it two to four times every year you can expect expensive repairs such as:
intake manifold gasket leaking antifreeze and requiring replacement
harmonic balancer drive pulley coming apart and serpentine belt not being able to stay on, requiring replacement of harmonic balancer drive puley
radiator leaking
power steering system breaking and requiring replacement
fuel line rusting out and or break lines rusting out, requiring replacement and parts no longer being available in pre-bent form requiring custom bending (this repair may sound minor, but the parts are expensive) and you have to put it up on a rack to do the job
fuel gauge not working and sender requiring replacement, (you can get the sender cheap at rock auto) but you have to drop the gas tank
seat springs breaking to the extent that you have to take it to an car upholstery shop
antifreeze pump leaking and requiring replacement
exhaust system rusting out and requiring replacement (hope that you do not have to replace the catalytic converter when that happens)
brakes on all 4, expect the aftermarket parts to not fit properly
exhaust gas re-circulation system to clog up requiring dis-assemble and cleaning of passages
exhaust gas re-circulation solenoid to fail
evap system purge solenoid in back of car to fail
evap system solenoid under hood to fail
heater core leaking
heater controls switch failing (good luck finding a junk yard one)
heater fan resistor burning out
heater fan failing
parking brake cables breaking and requiring replacement ( I think that vehicle has 4 of them and all 4 will break sometime at that age)
window switch
window regulator
window metal inside of door rusting out to the point the window will not go up
water leaking into cabin (very hard to find where it is coming in when that happens)
ignition coil going bad (there is one for each cylinder)
wiring under hood going bad intermittently
transmission problems
There are a few other major repairs, but basically for that year and millage if you can expect two to four major repairs every year. It is a money pit, and if you do the work yourself it is a pia every couple of months. The only thing that vehicle is good for is it's scrap weight value.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415741 04/28/20 03:55 PM
dtownfb Offline
A standard code reader will read the CEL code but not the ABS light. I would peruse the Cadillac forum to see what others are seeing:
https://www.cadillacforums.com/forums/cadillac-deville-1985-to-2005-including-1985-1992.96/
2006 Toyota Camry
2013 Toyota Sienna
2015 Toyota Camry
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415743 04/28/20 03:56 PM
ArrestMeRedZ Offline
I've got a 2000 Deville my parents bought new that is now driven by my daughter. With 96k on it the last 3 CELs have been camshaft position sensor (easy fix), mass air flow sensor (cleaned it) and crankshaft position sensor (a bit more difficult, but doable). Normally I'd say get an OBD reader but with a few steps you can learn about on a Cadillac forum you can get a dash readout that contains way more information.
I've also had a controller (emergency brake, gas door, trunk, etc.), climate control and 3 of 4 window regulators go out (the 4th will probably break the next time the window is used). A plastic or nylon part wears and breaks at about the 15-20 year point. Transmissions in that generation are a problem. If your dad's hasn't been rebuilt yet I would be surprised. The engine service due at, I believe, 100k is involved. My mechanic scowls at me when I suggest it's coming up. If yours is on original plugs that may be the reason it was given to your dad. That, and the myriad of things that wear out at this point is one of the reasons these cars can be had for a song. I personally haven't had the head bolt and other infamous engine problems this generation of Northstar engines is known for.
I guess I'm saying clearing the CELs and getting the car on the road might not be much of a problem. Keeping it on the road for any length of time might take some effort. I suspect you will get to know Rock Auto, Amazon and ebay intimately.
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415744 04/28/20 03:59 PM
J
Online Content
J
I would not put the money for tires into it. If I already had tires that fit it laying around then maybe try a code reader. But after you did get it fixed something else significant will break, and after that something else. It is an endless line of repairs.
JimPghPa
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415768 04/28/20 04:16 PM
Squirrelee Offline
You might be on the hook for upwards of $5,000 if you don't have the mechanical ability to fix the headgasket issue that might crop up on the Northstar (a.k.a. Deathstar) engine.
Some guy's dog thinks I'm a good man.
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415777 04/28/20 04:23 PM
J
Online Content
J
For what you will pay to keep that POS on the road you could be making payments on a much newer much more reliable vehicle that would not break down anywhere near as often.
JimPghPa
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415845 04/28/20 05:52 PM
1
14Accent Offline
1
Jeeze, you guys are being hard on a FREE car!
If it were me, as long as it didn't overheat WHILE DRIVING (not idling), had all 4 gears, and decent brakes I'd take it. Are you handy with a wrench? Nothing on those cars is difficult to fix, minus the head gasket. Hence the overheat advice. As long as the cooling system is in good order, you'll be fine. I've had 5 N* cars, not a one with cooling issues.
Electrical is going to be your battle with that car. They just weren't screwed together very well. That generation is my least favorite Deville, for some reason they just couldn't get it right. However, if you don't mind tinkering the parts are cheap and plentiful.
Is the engine fun to work on? No. What transverse mounted FWD V8 is? Will it leak oil? Of course, it's a N*. Other than that, go beat the snot out of it. If it blows up, no harm no foul.
Oh, and that looks like it has the 16" tires. 225/60's I believe. Cheap, easy to find.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2002 Cadillac Deville run or fix it? [Re: Barkleymut] #5415868 04/28/20 06:19 PM
A
aquariuscsm Offline
A
^^This! Everyone I know has done this on their GM cars.
Beautiful car btw!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 2002 Cadillac Deville run or fix it? [Re: JimPghPA] #5415870 04/28/20 06:21 PM
A
A_User55555 Offline
A
I'd consider myself a Northstar "enthusiast" as I drive one and used to have a 1999 Deville. I'm always reading up on these cars and I have never heard of half these problems listed.
You don't need a code reader as the car has one built in.
The only thing I'd be worried about is if it overheats. If it doesn't, make sure you change the coolant and replace the water pump tensioner and pulley. The tensioner is $20 but will save you a lot of money if it breaks.
The Northstar intake manifold is dry. No coolant passes through it.
I've never heard of this happen
This pretty much never happens. If anything, the back seat cushion pops up in one minute, and you can just replace the seat from a Junkyard.
They sell AC Delco advantage pads for like $20 and they work fine. Same with the rotors
I've never heard of this happen. Theres only one egr tube for the engine. Sometimes the EGR valve gets stuck, in which case you can remove it and clean it
The controls are digital and rarely fail.
There is no resistor.
Never had this happen and never heard of this occurring.
The rest of the things are not unique to this car but because of age.
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Valvoline Full Synthetic with a Purloator Boss PBL25288 Filter
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415901 04/28/20 06:43 PM
J
Online Content
J
Add CV joints to the list.
JimPghPa
Re: 2002 Cadillac Deville run or fix it? [Re: JimPghPA] #5415907 04/28/20 06:47 PM
dishdude Online Content
Online Content
You forgot the Betty Boop air freshener.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: 2002 Cadillac Deville run or fix it? [Re: Brybo86] #5415925 04/28/20 07:05 PM
G
GZRider Offline
G
Re: 2002 Cadillac Deville run or fix it? [Re: JimPghPA] #5415928 04/28/20 07:14 PM
1
14Accent Offline
1
Why, exactly? Those cars use huge CV joints and axles, they never fail unless something cuts the boot. Much better than the junk they're putting on cars today.
See: Every Nissan Rogue EVER made.
