VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
85 registered members (Audios, 4WD, 1foxracing, aquariuscsm, AurionX2, alarmguy, 10 invisible), 1,731 guests, and 26 spiders.
Topics306,281
Posts5,289,534
Members71,618
Grease compatibility-Calcium Sulfonate/Kendall SHP #5415678 04/28/20 02:54 PM
M
Megalops43 Offline OP
M
Hi guys,
I currently have Kendall SHP NLGI-2 on a 2 axle utility trailer.
Grease specs: https://kendallmotoroil.com/product/shp-grease/
I cant find this locally. The thickener is calcium sulfonate.
Any other brands compatible with this grease?
Am i right to make sure that the substitute grease thickener is calcium sulfonate?
Im trying to avoid purchasing the kendall grease online because of cost, shipping etc.
Thank you in advance.
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: Megalops43] #5415717 04/28/20 03:36 PM
R
Rob_Roy Offline
R
If you are repacking the bearings it won't matter. Just clean everything with solvent and repack with your favorite wheel bearing approved grease.
If you are just adding grease via a zerk, a Calcium Sulfonate grease would be preferred, but a lithium complex grease should work as well (it is listed as compatible with calcium sulfonate).
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: Megalops43] #5415759 04/28/20 04:06 PM
spasm3 Offline
[Linked Image from interlubecorp.com]
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: spasm3] #5415944 04/28/20 07:38 PM
M
M
Thanks Spasm, Robroy. It didn’t occur to me to search for a grease comparability chart.
Not repacking , just adding a couple of squirts for maintenance.
Thanks for the info, I really appreciate it!
2003 Chevy Silverado 4.3L, automatic.
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: Megalops43] #5417018 04/30/20 06:22 AM
ChadHubbard Offline
Lucas Marine Gease is a OBCS - overbased calcuim sulfonate grease. Pretty easy to find at local auto parts stores.
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: ChadHubbard] #5417046 04/30/20 07:32 AM
4WD Online Confused
Online Confused
Agree this is likely the easiest to find and one I used on trailer bearings in the past …
Re: Grease compatibility-Calcium Sulfonate/Kendall SHP [Re: Megalops43] #5434050 05/20/20 10:55 AM
N
nthach Offline
N
WD-40 Specialist True Multi-Purpose Grease also is a OBCS grease. It was available at Home Depot. It was chosen according to WD-40 to insure compatibility with Li-complex greases.
LubriMatic Marine Bearing Grease is a basic calcium sulfonate based grease that's cheap and available at many hardware stores.
