Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
27 registered members (bworley, Cdn17Sport6MT, bachman, ajchien, ArrestMeRedZ, 3 invisible), 1,204 guests, and 56 spiders.
Topics305,879
Posts5,281,961
Members71,528
Pump on swamp cooler troubleshooting #5415656 04/28/20 02:22 PM
paulri Offline OP
Pump on swamp cooler is not working. I can plug in something else into the socket (that the pump itself is plugged into) it is running on, and that something will run. I put a running hose into the tube that the pump pushes water into, to get to the spider. Water pours out immediately onto all the pads.
So that pretty much isolates the pump as the problem, doesn't it?
OK pumps are only 20-30 bucks at lowes. This unit is 10 years old, the pump has a decent amount of rust on the outside. Is there any reason to troubleshoot it and still get it to run? And if so, what could I try?
2005 Toyota Sienna LE; 171,000 miles
2006 Toyota Highlander Hybrid 136,000 miles
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415661 04/28/20 02:32 PM
paulri Offline OP
FWIW, the rust is only one one metal band that goes around the pump, but doesn't touch the water level. I just looked again and most of that is actually calcium deposts, but there is a small amount of rust. The plastic part of the pump actually looks pretty good.
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415668 04/28/20 02:39 PM
ArrestMeRedZ Online Content
Online Content
Just replace it and make sure the screen that filters the water feed is clean. At 10 years you have got your money's worth out of the old one and even it you are able to get it to limp along, you don't want it failing in the middle of July.
Now, with the new one installed, if you want to try and repair the old one as a spare, go ahead. Probably not worth the time spent on it, though.
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415675 04/28/20 02:48 PM
paulri Offline OP
Fair enough. I did look at teh screen, it is pretty clean. I don't even think I want to replace that.
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415894 04/28/20 06:37 PM
AZjeff Offline
They don't last that long around here with the minerals in the water, I think the impeller binds and burns up the motor. I'd try to find the same brand.
It's been 2 years since we moved to a house with A/C, don't miss the swamper a bit.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415895 04/28/20 06:40 PM
paulri Offline OP
I would think in AZ that one would come in handy, unless it just gets so hot, that even that doesn't bring it down.
We also have AC, but we do like to use it, we live in desert so its never too humid to use one.
Well thanks anyways, called the OEM and the same pump isn't in my vicinity, not going to drive out of town for a crapshoot repair that might or might not be what is needed, so I threw in the towel & called an ac repair guy. frown
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415930 04/28/20 07:20 PM
AZjeff Offline
Replacing that little pump is/was a 10 minute swap job in our cooler. Is your's hard to access or something?
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415932 04/28/20 07:22 PM
paulri Offline OP
It is stuck in the swamp cooler--even with Deep Creep the screws weren't coming off. But I also would have had to drive out of town to find an exact replacement, so I just called a repair guy.
Re: Pump on swamp cooler troubleshooting [Re: paulri] #5415956 04/28/20 07:52 PM
SpitFire6 Offline
Hi,
to get longer life use demineralized water and stop using tap/well water.
Cheers,
Iain.
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Pump on swamp cooler troubleshooting [Re: SpitFire6] #5416046 04/28/20 10:07 PM
AZjeff Offline
Originally Posted by SpitFire6
Hi,
Cheers,
Iain.
Don't know if you're familiar with an evaporative cooler for a house. It's usually on the roof or in a gable end and use gallons of water a day. They're plumbed into the cold water line and have a float valve that controls the water level in the pan that probably holds 10-15 gallons of standing water. This is what a residential cooler looks like, our old house had one exactly like this, and the drawing shows how it works.
[Linked Image]
[Linked Image]
Re: Pump on swamp cooler troubleshooting [Re: AZjeff] #5416053 04/28/20 10:19 PM
SpitFire6 Offline
Hi,
Cheers,
Iain.
[Linked Image]
[Linked Image]
Hi,
That is new to me. Thank you for correcting me.
I have never heard of a dwelling unit before.
Thanks,
Iain.
