Originally Posted by blufeb95
So is this the same Techron you buy off the shelf, or is it a more concentrated solution? Is this to reach EPA minimum or is this the blend rate for Chevron top tier fuel?
It has to be a commercial grade concentrate. No way they're telling consumers to add 1oz per gallon, but then dosing a station's tank at a minimum concentration of .06oz (rounded) per gallon. You're talking roughly 16 times less concentration at the pump as compared to using a bottle off the shelf as advertised.
If this truly is the case, then they're not kidding when they call the off the shelf product Techron Concentrate.
