Walmart closing all Tire and Lube Expree in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
99 registered members (2009Edge, 2015_PSD, 53' Stude, 2010Civic, ABN_CBT_ENGR, 94astro, 9 invisible), 1,917 guests, and 36 spiders.
Topics306,089
Posts5,287,190
Members71,596
WIX 51516, Seven Months, 3321 miles #5414967 04/27/20 07:38 PM
MrQuackers Offline OP
Plenty of short trips for sure. Run on the mighty Saturn 1.9 DOHC
Looks like good solid construction, but it was leaking the whole OCI, apparently at the seam as others have experienced. Date code best as I can determine is 061511D1. As you can see, I punched a hole with a screw right through the code to drain the oil.
I now have a MotorCraft FL-400S installed and the leak is no longer, confirming the WIX filter was indeed leaking.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Oil used during the OCI was Mobil 1 Turbo Diesel Truck 5w-40, Mobil 1 HM 5w-20, Rislone Engine Treatment, LiquiMoly mos2, and a touch of Heinz 57 oils. Also of note, I performed a 12 minute B-12 flush before the oil change I just performed: FL-400S + Mobil Delvac Super 1300 15w-40 + Rislone + LM mos2
Yes, Saturns be thirsty, about 1150 miles to the quart.
I will post additional pictures later.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5414986 04/27/20 08:02 PM
Still waiting on that 50k mile Tough Guard, Linctex!
coffeeMobil 1 USA
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5414987 04/27/20 08:04 PM
paulri Online Content
Online Content
Interesting find. This has got to be the worst looking Wix I've seen posted here. Usually they look like they've only been used for a thousand miles or so.
I see what looks like a gap along the seam. Is that why you talked about leaking? Or did you notice it dripping from the filter onto the ground?
2005 Toyota Sienna LE; 171,000 miles
2006 Toyota Highlander Hybrid 136,000 miles
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5414991 04/27/20 08:06 PM
No, the seam of the can at the base plate. Oil was dripping off the sump pan. Never leaked like this before and is not leaking now with the FL-400S currently installed.
coffeeMobil 1 USA
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5414993 04/27/20 08:09 PM
M
Micahmcmeen Offline
M
I wonder if the quality change is because of the mann+hummel take over?
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5414995 04/27/20 08:10 PM
This filter is old stock from my stash, probably made in 2011
coffeeMobil 1 USA
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415016 04/27/20 08:29 PM
O
oldhp Offline
O
Can the rubber quad ring dry out because of sitting for a long time???
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415023 04/27/20 08:34 PM
Z
ZeeOSix Offline
Z
Seems like quite a few WIX filters have been shown here to have a leaky base seam.
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415043 04/27/20 08:53 PM
53' Stude Online Content
Online Content
MrQuackers: I always enjoy and look forward to your posts. Thank You and as always great write up and the oil did some cleaning I see. Thank You for c&p smile thumbsup
2009 Toyota Camry LE
Re: WIX 51516, Seven Months, 3321 miles [Re: 53' Stude] #5415053 04/27/20 09:02 PM
I am honored.
coffeeMobil 1 USA
Re: WIX 51516, Seven Months, 3321 miles [Re: 53' Stude] #5415180 04/27/20 11:38 PM
B
bbhero Offline
B
Very,very well stated 53'....
Great work as usual from Mr Q....
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415236 04/28/20 02:27 AM
F
FT92 Offline
F
just bought a wix filter for my Honda accord ,haven't installed it yet but now i'm wondering if I should ??
Re: WIX 51516, Seven Months, 3321 miles [Re: FT92] #5415390 04/28/20 08:25 AM
J
jeepman3071 Online Content
Online Content
J
I would install it with confidence. thumbsup I pretty much use Wix and Honda OEM filters exclusively on my family's Hondas and have had zero issues.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415414 04/28/20 08:59 AM
M
mpack88 Offline
M
I was going to use the fl-400 on my mother's Saturn 1.9 dohc but there was a plastic cover in the way that goes around the inner tie rod so I just stuck with a short filters.
Re: WIX 51516, Seven Months, 3321 miles [Re: MrQuackers] #5415589 04/28/20 12:39 PM
Thank you mods for correcting the miles in the title smile
Regarding the condition of the media, it is solid, but molybdenum disulfide laced oil has been circulating through it for a while, and hello short trip winter driving, a little wavy nbd
coffeeMobil 1 USA
