Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
104 registered members (Arcoril, Al, ABN_CBT_ENGR, 2015_PSD, aquariuscsm, 830Lee, 10 invisible), 2,305 guests, and 38 spiders.
Topics306,122
Posts5,286,873
Members71,588
Looking at a 2006 Acura TL... #5414887 04/27/20 06:09 PM
G
gregk24 Offline OP
G
I'm looking at a 2006 Acura TL with around 160K miles on it, private seller. From what I read they are solid vehicles overall. I plan on test driving this evening, from a quick look yesterday, the paint appears to be in good shape (for an 06), no peeling or clear coat rash. Just scratches. No idea what the interior looks like though the owner says it's "mint", likely not the case but we will see. I did ask about timing belt, he wasn't sure when it was last changed so that would be a priority. Not sure how much that would cost, I assume around $1000. Will attempt to check fluids on test drive.
The vehicle would be used as a daily driver "beater".
Do any of you have anything to add about these TL's? Thanks in advance.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414893 04/27/20 06:14 PM
J
JLawrence08648 Offline
J
Trans are weak, 5 cylinder or 6? 5 cylinders have a weak camshaft and oil needs to be changed regularly and preferably with synthetic.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414894 04/27/20 06:15 PM
1
14Accent Offline
1
My dad had an '05 for a few years that was a salvage title, but we got a really good deal on it and I worked in the shop where all the work was performed. He had the car for a few years and it gave him no issues. That gen TL is a really solid platform, and the transmission issues of the early Honda's were long resolved by 2006. 160k really isn't much on one of those, plan on doing the TB and WP just because, and changing the transmission fluid, but other than that you should be fine.
There is a common issue on all Acura's of that gen, and that's a battery drain caused by a failed Bluetooth module. It's an easy fix, just drop the overhead console and unplug it.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Looking at a 2006 Acura TL... [Re: 14Accent] #5414903 04/27/20 06:22 PM
cpayne5 Offline
That last part is particularly interesting to me. smile I have an '06 TSX whose Bluetooth module kicked the bucket about a year ago. It is no longer my daily driver and the battery dies after a few days of sitting. I figured it was just a bad battery, but I wonder if it's the BT module that's draining the battery...? Thanks for the comment!
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414906 04/27/20 06:24 PM
The Critic Offline
Engine mounts (usually the side and front one) fail. If left unattended long enough the other ones will fail as well.
Make sure the timing belt was done at 105k. Oil Pump o-rings tend to leak as well, usually sometime before the 2nd scheduled timing belt service. Resealing the oil pump requires removing the timing belt, exhaust pipe and oil pan.
And the bluetooth issue that 14accent mentioned.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414930 04/27/20 06:46 PM
ctechbob Offline
There is no such thing is a 5 cylinder TL after 1998.
Things to check and replace:
Motor mounts
Compliance Bushings (Lower front a-arms) - Look for cracks or bad inside front tire wear. Replace with OEM bushings or pay the price. (Continued bad tire wear)
3x D&F on the trans and keep tabs on it. Also replace the filter
Bluetooth module probably doesn't work.
Seats are probably cracked, or will, same with the dash.
The J-Series engines are solid. Replace the timing belt and check the valve clearances (Often neglected)
If it has an oil leak from underneath it will be time to do the oil pump reseal, do that when you have the timing belt done as it all has to come off to do either job.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414968 04/27/20 07:40 PM
H
hallstevenson Offline
H
Honda dealers around here run specials for around $500 for the timing belt. It's the timing belt only though. I'm sure the majority of customers who use this coupon get a call telling them the water pump, tensioner, idler, etc need replaced once they open it up so yeah, then you'll approach $1000. An independant shop, using aftermarket parts, will be around $600.
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5414988 04/27/20 08:04 PM
ctechbob Offline
ASIN TKH-002, new OEM seals if yours are leaking. If not, leave them. New Serpentine belt, tensioner if you need it. Oil pump and all those assorted o-rings will run about $50-70 in parts (I have my list at home, the 2003 Accord is fixing to go under the knife for all of it this week) So $300 give or take in parts, the rest of it is labor.
Trans-Idemitsu H+
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5415077 04/27/20 09:17 PM
G
gregk24 Offline OP
G
It does have a small oil leak, maybe it’s the oil pump seal.
61,xxx miles
54,xxx miles
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5415126 04/27/20 10:05 PM
The Critic Offline
https://youtu.be/c0wBHItpGtI
You are looking at 6 hours labor plus parts to repair. At the dealer, it will be about $2k.
Re: Looking at a 2006 Acura TL... [Re: The Critic] #5415135 04/27/20 10:12 PM
G
gregk24 Offline OP
G
From what I read, it doesn't look like it would damage anything if not done. Could be wrong.
Of note, when in overdrive I noticed the trans appeared to be going in and out of overdrive. Fluid was dark, but not burned. I am familiar with Honda ATF. The guy doesn't want to move on the price. I am not interested at $5600.
61,xxx miles
54,xxx miles
Re: Looking at a 2006 Acura TL... [Re: gregk24] #5415170 04/27/20 11:06 PM
R
rubberchicken Offline
R
At $5600 it should be mint condition. NADA, Edmunds etc would price that around $2500-3500 at most for a good example. If he cannot produce any records of a timing belt, then consider it not done and it needs it.
A few other things- dashboard tends to get major cracks, and they are very expensive to fix. Power steering o-rings can cause leaks or squealing.
Re: Looking at a 2006 Acura TL... [Re: The Critic] #5415235 04/28/20 02:24 AM
ctechbob Offline
I'm about to find out. I'm setting aside 2 days to do my Accord. I've done the timing belt on the TL, should have done the pump seal then as well, but didn't.
OP, yea if they wouldn't move off that price it would need to be mint, and I'm sure it isn't.
Trans-Idemitsu H+
Re: Looking at a 2006 Acura TL... [Re: ctechbob] #5415237 04/28/20 02:28 AM
The Critic Offline
It isn’t a difficult job, definitely doable in one day. With the t-belt off, remove the exhaust pipe that is in the way and remove the oil pan. Remove the pickup, then remove the oil pump. Replace the 3 gaskets (filter adapter, pickup tube o-ring and the Oil Pump gasket). Clean all areas carefully and make sure the surface is shiny clean before applying RTV.
Re: Looking at a 2006 Acura TL... [Re: The Critic] #5415239 04/28/20 02:57 AM
ctechbob Offline
Sure, if you don't have a wife and kid hanging around because they can't/won't go anywhere smile. Usually, they ask me to do something right after I'm elbow deep in something that I can't stop.
Trans-Idemitsu H+
