Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
15 registered members (iontrap, bachman, FFeng7, Char Baby, blufeb95, 1 invisible), 1,129 guests, and 81 spiders.
Topics306,047
Posts5,286,363
Members71,593
2002 Harley Heritage Classic (FLSTC) CARBED #5414862 04/27/20 05:36 PM
dive_hive Offline OP
Stage "1". Slip-ons, rejet, upgraded filter. The blackstone comments that reference engine work is one oil change ago, the cam tensioners were replaced. Bike was ran 35 miles before sample was taken. 1 year between change. Seems to be a trend on BITOG with high iron and aluminum with M1. Yes? Let me know all your thoughts.
2004 Ram 2500 5.7 Hemi 254,000 mi
1996 Chevy 1500 5.7 165,000 mi
2002 Harley FLSTC 24,000 mi
1966 MF 135 DELUXE Z-145
1964 JD 4020 Diesel
Re: 2002 Harley Heritage Classic (FLSTC) CARBED [Re: dive_hive] #5415090 04/27/20 09:26 PM
B
Bonz Offline
B
I like the M1 20w50, used it in the ZRX1200 last riding season. 5,065 miles, sus vis 93.7, tbn 6.4, flashpoint 410, aluminum 24, iron 15.
Aluminum can be from the clutch basket in the shared sump that gives the ZRX it's aluminum number. However I did put pistons in about 12,000 miles ago, so it had been about 7,000 miles after the pistons when I began to run the 20w50. But popular opinion around here says it's from the clutch basket.
Not sure what aluminum may be from in your case, pistons?
This round I went with M1 10w40 4T again. I had run it the oil change previous to the 20w50 as well and had almost identical wear numbers across the board for just under 5,000 miles.
Re: 2002 Harley Heritage Classic (FLSTC) CARBED [Re: Bonz] #5415167 04/27/20 11:00 PM
Yes, the aluminum would be from the pistons. I plan on riding alot more this year, so I'll give it a change or two and see. The M1 is actually getting harder to find here. Walmart and the autoparts stores quit handling it. Most have lucas and Castrol Power1 vtwin now. Hellofa lot cheaper even if I had to change it more often.
1964 JD 4020 Diesel
Re: 2002 Harley Heritage Classic (FLSTC) CARBED [Re: dive_hive] #5415368 04/28/20 08:00 AM
B
Bonz Offline
B
Haven't been in Walmart for a couple weeks but they had both M1 and the Supertech motorcycle oils side-by-side. I'm not going to take the leap and run the Supertech but I'm waiting to see an analysis of any version of the Supertech MC oils. 10w30 ATV, 10w40 or 20w50. I'm sure the oil is fine however with the flat tappet rocker arm system in the ZRX the extra zinc/phos the Mobil oils offer is desirable. If they have additive packages similar to the Mobil motorcycle oils, I am all in.
Re: 2002 Harley Heritage Classic (FLSTC) CARBED [Re: Bonz] #5415970 04/28/20 08:11 PM
I wasn't aware Supertech had a MC line. My WM def doesn't have it, but it's one of the smallest WM's I've ever seen. I'd be interested, if I find some I'll do a VOA.
1964 JD 4020 Diesel
Re: 2002 Harley Heritage Classic (FLSTC) CARBED [Re: dive_hive] #5416152 04/29/20 07:18 AM
B
Bonz Offline
B
Took a picture of it yesterday when I stopped by Walmart, it was on my mind from this thread. They had 20w50 however there's typically 10w30 ATV and 10w40 as well. Next to Mobil 1 for comparison. Mobil 1 MC oil, either flavor, is the best oil I have run in a shared sump based on shift quality, maintaining viscosity and TBN is strong after 5,000 miles for either oil.
[Linked Image]
