KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
102 registered members (830Lee, 4WD, aquariuscsm, AndyB, agarb, Alfred_B, 11 invisible), 2,236 guests, and 47 spiders.
Topics305,996
Posts5,284,323
Members71,558
Karosene alternative #5414677 04/27/20 01:43 PM
G
Gito Offline OP
G
Is there an alternative cleaner to Karosene that I can use to clean the head gasket residue left behind on the cylinder head.
Can’t find Karosene at hardware stores.
One guy from HD said he heard it was outlawed in CA.
Any advice is greatly appreciated
Re: Karosene alternative [Re: Gito] #5414681 04/27/20 01:48 PM
CT8 Offline
I like the Home Depot guy said he herd part of any postings.. Carefully scrape or use paint remover. Kerosene isn't the best solvent. There are gasket removers in spray cans but it is paint remover.
2015 F150 2.7
2018 F350 6.2
Re: Karosene alternative [Re: Gito] #5414684 04/27/20 01:50 PM
B
bullwinkle Offline
B
I've used diesel fuel, or even gasoline (wear gloves!) as parts cleaner in the past. Diesel is basically a heavier, lesser refined version of K1 anyway. As always, never smoke or clean near open flames, outside is always better!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Karosene alternative [Re: Gito] #5414698 04/27/20 02:06 PM
Dave9 Offline
First try a plastic scraper tool, but yes, diesel is what I'd use instead. Gas would work even better but far more flammable and dealing with the fumes is an issue unless it's a very well ventilated area. You can mix diesel and gas, to make it a bit more active but not fume so readily as straight gas. That would be superior to kerosene. I use that, with a little oil added too, for a far less expensive substitute for "goo gone" to clean gummy sticker or duct tape, etc adhesive residue off of things.
Re: Karosene alternative [Re: Gito] #5414699 04/27/20 02:08 PM
Yah-Tah-Hey Offline
Stoddard solvent, Varsol,(aka mineral spirits) is a better solvent and much safer.
Re: Karosene alternative [Re: Gito] #5414713 04/27/20 02:26 PM
J
JohnG Offline
J
But since you are from CA, you may have to find a solvent that is safe to use. Maybe something like Ivory Liquid (with low VOC emissions) would do the job. If that doesn't work it may be possible to step up to something stronger, like Simple Green.
Try WD 40 (mostly kerosene) or even (keep this quiet) Carb Cleaner. Don't forget to take your ID to buy it! LOL
Re: Karosene alternative [Re: Gito] #5414753 04/27/20 03:03 PM
Chris142 Online Content
Online Content
Brake cleaner
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Karosene alternative [Re: Gito] #5414790 04/27/20 03:58 PM
M
meadows Offline
M
Use charcoal lighter fluid.
Re: Karosene alternative [Re: Gito] #5414791 04/27/20 03:59 PM
dave123 Offline
Odorless Mineral Spirits
Re: Karosene alternative [Re: Gito] #5414864 04/27/20 05:38 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Id use mineral spirits if I couldnt find kerosene. Diesel would also be an option, but it will smell worse/longer if it gets onto something.
Re: Karosene alternative [Re: Gito] #5414919 04/27/20 06:38 PM
tom slick Offline
Mineral Spirits are easy to find and safe to use. if you need something stronger use lacquer thinner. Non-Chlorinated Brake Cleaner is mostly Acetone so you could try that also.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Karosene alternative [Re: Gito] #5415011 04/27/20 08:23 PM
J
Jake_J Offline
J
Since you plan to use it as a solvent instead of a fuel, mineral spirits, braker cleaner, carb cleaner, acetone, etc are all excellent solvents. Diesel is the closest thing to Kerosene, and both Diesel and gasoline are good solvents.
Re: Karosene alternative [Re: Gito] #5415328 04/28/20 07:14 AM
DriveHard Offline
orange based painter stripper...I use this stuff for all kinds of things, works amazing!
http://www.citristrip.com/product
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Karosene alternative [Re: Gito] #5415518 04/28/20 11:28 AM
A
Avery4 Offline
A
I use acetone to clean gasket surfaces because it is very effective, dries quickly, and leaves no residue and its cheaper than brake clean if you buy it by the gallon, although brake clean works very well too. Make sure the head and block surfaces are completely free of any gasket residue and oil before reassembly. I wouldn't use kerosene or diesel to clean the surfaces because they leave an oily residue. Hope this helps and good luck with your project! grin
