Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
81 registered members (4WD, 2015_PSD, 28oz, 2010Civic, 2004tdigls, 55hambone, 7 invisible), 2,282 guests, and 31 spiders.
Topics306,297
Posts5,289,787
Members71,618
Page 1 of 3 1 2 3
2021 Corvette "engine needs to be running to check oil"? #5414643 04/27/20 01:15 PM
wemay Offline OP
2019 Volkswagen Passat Wolfsburg TSI: Castrol 0W-20, CH11784 o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414649 04/27/20 01:20 PM
R
racin4ds Offline
R
GM is still in love with M1 aren't they.... must be getting it cheap... smile
Side note, I didn't know you could get the ESP formula in 0W40.... I'd rather use that in my TDi versus the 5W30 it calls for. Theres just something in me that wants great HTHS for a turbo diesel.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414650 04/27/20 01:21 PM
R
Rand Offline
R
probably some sort of dry sump system?
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414651 04/27/20 01:22 PM
J
Jimmy_Russells Offline
J
It's a dry sump
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414652 04/27/20 01:23 PM
JohnnyJohnson Offline
Another reason not to buy a Government Motors car.
2004 Corolla 140120
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414654 04/27/20 01:27 PM
B
bullwinkle Offline
B
Interesting that it's a PF64 (Ecore?) & not a UPF64R? Being a dry sump system, it'll have a reservoir to check oil level (you guys all beat me to the dry sump punch!).
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414660 04/27/20 01:31 PM
Quattro Pete Offline
Quote
Owner's manual of our Q5 mentions the same thing, in order to get an accurate reading on the digital display.
But if you buy a physical dipstick (one isn't included from the factory), you can check it at any time.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: Jimmy_Russells] #5414661 04/27/20 01:31 PM
Z
ZeeOSix Offline
Z
Originally Posted by Jimmy_Russells
It's a dry sump
Yep ... different oil level checking procedure.
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414669 04/27/20 01:37 PM
B
bullwinkle Offline
B
Adding-the M1 ESP 0W40 is apparently so new that Mobil doesn't even list a PDS for it in the USA yet, although Summit Racing & others seem to carry it for a somewhat reasonable price. Might be a decent oil for a race LS engine (although the cat would be the first thing gone, meaning any HDEO could be used).
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414670 04/27/20 01:39 PM
A
aquariuscsm Offline
A
What was that stuff in the aerosol can Phil sprayed on the filter and drain plug once he reinstalled them?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: aquariuscsm] #5414686 04/27/20 01:55 PM
Z
ZeeOSix Offline
Z
Some kind of cleaner ... brake cleaner perhaps.
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414690 04/27/20 01:58 PM
Z
ZeeOSix Offline
Z
Actually, that's a 2020 Corvette, which is the first year of the C8 Vette.
Phil looks down the center tube of the oil filter for "metal shavings". That's the clean side of the filter, so you will never see any debris in that location. I'd be cutting the filter open for an inspection between the pleats.
Phil also didn't seem to tighten the oil filter very tight ... looked like about 1/2 turn by hand. Filter access is bad for a hand tightening. I'd be using an end cap tool and marking the filter for a 3/4~7/8 turn.
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414704 04/27/20 02:15 PM
R
ragtoplvr Offline
R
Checking dry sump with engine running is common. Wait until a old Harley drains down, the owner adds oil, then starts it and it is overfilled and oil goes all over.
Re the government motors comment, this is a superior system. When you do not know what you are talking about, better to keep your mouth shut, rather than expose your lack of knowledge and remove all doubt.
Rod
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414719 04/27/20 02:31 PM
J
JohnG Offline
J
Quote
+1
So it's a dry sump. I don't see a huge mystery here.
Re: 2021 Corvette "engine needs to be running to check oil"? [Re: wemay] #5414725 04/27/20 02:40 PM
T
Trav Offline
T
Same as on the older 911 and many other dry sump cars. Nothing new or different for this type of system.
The Government motors comment by one poster is way out of line, this is one of the best cars in the world at any price but at 60K its a steal.
Page 1 of 3 1 2 3
