Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
70 registered members (4WD, 2010Civic, ARB1977, 2004tdigls, 55hambone, Astro14, 3 invisible), 2,318 guests, and 47 spiders.
Topics306,296
Posts5,289,779
Members71,618
4Runner and Towing, 0-20 or 0-30? #5414612 04/27/20 12:40 PM
Z
zonzin Offline OP
Z
I have a 2015 Toyota 4Runner and tow a 3000 lb travel trailer. My question is would it be wise to switch to 0-30 M1 is the towing season/hot months? The 6 bannger in the 4Runner really winds up when towing, especially in the mountains, and temps run in the 90's to 100 in the summer months. I currently run M1 0-20 and change at 7k when towing, 10 k when not. Will the 0-30 be better protection?
Thanks
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414613 04/27/20 12:41 PM
Bryanccfshr Offline
I would run a 5w30, 10w30 or m1 0w40. Although there is no real reason for @ 0w anything in the summer. A good synthetic 10w30 would be the best solution.
Have run all in mine and am confident in them.
The challenge in the mountains is not only the high rpms and grades, it is the lower boiling point and the fact that cooling systems get less efficient at higher altitude. Pulling. A trailer up grades in high alttitude I would definately step the HTHS to 3.0 or above.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414675 04/27/20 01:41 PM
V
Vladiator Offline
V
0w40/5w40 is my go-to for any towing needs in the mountains. 0w30/5w30 would be fine just towing, or just mountains, but towing PLUS mountains is where I step it up to 0w40/5w40 shtuff. Gained that habit when I saw a dodge dakota go up a mountain with a camper trailer, and after a few uphills his engine started knocking... He had 5w30 in that 3.7L, according to the sticker.
0W20 in summer at Death Valley is as good as 25w70 in winter at Alaska. Both can be done, neither is good for the engine long term. Oil grade is chosen by CLIMATE and OPERATING CONDITIONS.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414685 04/27/20 01:55 PM
CT8 Offline
0W-30 or even better 5w-30. A 5w-30 will do the job. The engine has an oil cooler. I have been running Ow-40 M1 in my sons 2006 4x4 Tacoma with the 4 cyl.
2015 F150 2.7
2018 F350 6.2
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414720 04/27/20 02:33 PM
M
Mitch Alsup Offline
M
I'd think about changing the oil in the transmission after any long tow in a 4Runner.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414748 04/27/20 02:56 PM
K
Kawiguy454 Offline
K
If i was winding up that lil 4 popper towing and roasting the oil i'd do 10w30. You're giving that poor thing the worst possible beating and bearings would be my worry. If just one is on loose side pressure may net be there.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: Kawiguy454] #5414750 04/27/20 02:58 PM
PimTac Offline
It’s a six cylinder motor.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414755 04/27/20 03:04 PM
Z
Zaedock Offline
Z
I used Napa conventional 5W20 pulling my 5,000 lb Jeep on a 1800 lb trailer with about 500lb worth of spare parts in the bed of my old 2003 F150 5.4L up the Ike Gauntlet though the Rockies from Mass and then back again after two weeks, and didn't skip a beat.
I think the Mobil 1 0-20 would work fine. Changing to 0W30 would probably make you feel better.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414757 04/27/20 03:07 PM
K
ka9mnx Offline
K
I think you would be fine with 0w-20. Does the owners manual state anything about severe driving or towing?
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414760 04/27/20 03:08 PM
K
ka9mnx Offline
K
"Winding up" is a good thing. Lugging the engine would be a killer for the bottom end.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414768 04/27/20 03:23 PM
X
xyxptlx Offline
X
How high are your Mtn’s? If they are east coast at or below 6k I’d not worry about it, unless your oil temps are high. Out west it’s mostly a cooling problem as the engine derates with altitude, unless you are supercharged.
Is that an automatic transmission? Again it’s oil temperature that is the question.
I suppose driving technique in the mountains is off topic? Going down the hill can cause problems, too.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414807 04/27/20 04:16 PM
K
krismoriah72 Offline
K
According to Shell Gas Truck you dont need 0w30 (they dont make it).
https://rotella.shell.com/en_us/products/gas-truck-synthetic-engine-oil.html#read
WIth that being said if it were mine i would go with 5w30 Gas Truck and hammer down.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: zonzin] #5414915 04/27/20 06:34 PM
Bryanccfshr Offline
Your owners manual will state a higher viscosity may be better suited for this driving condition. I would accept that hint.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: ka9mnx] #5415018 04/27/20 08:31 PM
Z
zonzin Offline OP
Z
If I read it correctly 0-20 unless severe driving conditions but it give no specific recomendation.
Re: 4Runner and Towing, 0-20 or 0-30? [Re: xyxptlx] #5415019 04/27/20 08:32 PM
Z
zonzin Offline OP
Z
dup
