Forums Migration
Please read this thread
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
94 registered members (ARCOgraphite, aquariuscsm, alchargo, Audioquest, 2015_PSD, ArrestMeRedZ, 3 invisible), 1,963 guests, and 31 spiders.
Topics307,546
Posts5,312,870
Members71,870
Page 1 of 3 1 2 3
Should l Replace Tensioner w/Timing Belt ? #5414315 04/27/20 07:47 AM
G
Gebo Offline OP
G
Getting ready to do a timing belt/water pump change on a '99 Camry V6 due to age. Last belt was done in 2010.
What is your opinion as to whether to replace tensioner? I'm getting conflicting info. This car belongs to someone else
and they are instructing me to do whatever I think is best. My understanding is it is not normally replaced with the timing
belt.
It only cost $62 OEM from Dealer.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414328 04/27/20 08:01 AM
M
mattd Offline
M
It is something that is normally replaced. It’s common practice to replace everything the timing belt rides on (idlers, tensioner pulley and water pump). IMO it wouldn’t be a bad idea to replace the camshaft seals either, common with the that vintage, especially with the age. What’s the mileage?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414334 04/27/20 08:06 AM
G
Gebo Offline OP
G
176k. Camshaft seals and valve covers replaced at 148k.
What got me confused is PM and service Tech at Lexus says they virtually never replace tensioner when doing a timing belt/water pump change.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414335 04/27/20 08:08 AM
M
mattd Offline
M
Every timing belt job I’ve ever done I always replaced the hydraulic tensioner. As I stated it’s good practice and if it’s fails, even halfway through the inverval, you have a big problem.
ASE Master, L1, L2
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414336 04/27/20 08:10 AM
G
Gebo Offline OP
G
Thanks for your advice. I appreciate it.
Plus the fact it is a 1999 lends me to believe I won't be wasting money.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414338 04/27/20 08:17 AM
G
Gebo Offline OP
G
So right now, I'm doing timing belt, water pump, 2 idlers, tensioner and thermostat (I already have the thermostat). PS and Alt belts done at 148k as well.
I premix my Toyota Red and provide it to my indy.
The only thing I can think of is if the crank seal is leaking.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414346 04/27/20 08:23 AM
Astro14 Offline
Always replace the tensioner. Always.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414358 04/27/20 08:31 AM
J
Jimzz Offline
J
Just get the AISIN TKT024 kit. Comes with mostly OE parts including a Japanese tensioner.
Less than $157 at rockauto
yup
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414360 04/27/20 08:32 AM
O
opus1 Offline
O
Short answer: yes.
You're in there anyway, might as well do the job once. The dealership/pros may not replace it as a part of the maintenance, but they've got nothing to lose - if it fails, the owner is back with another job for them. wink
Current Fleet:
2010 Hyundai Sonata GLS
2009 Chevy Cobalt SS Sedan (yes,the turbo)
2002 Dodge Dakota SXT Club Cab
1994 Ford Ranger XLT (RIP, Dad)
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414364 04/27/20 08:36 AM
demarpaint Offline
I'd replace it.
God Bless Our Troops
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414376 04/27/20 08:45 AM
T
tundraotto Offline
T
Yes you should.
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414396 04/27/20 09:09 AM
G
Gebo Offline OP
G
Order placed. Thanks for your advice.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Should l Replace Tensioner w/Timing Belt ? [Re: opus1] #5414397 04/27/20 09:10 AM
I
InhalingBullets Offline
I
Originally Posted by opus1
Short answer: yes.
THIS!
'16 Toyota Prius 4
'15 Honda Accord Sport
'14 Victory Cross Country Tour
'13 Toyota Prius 3
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414406 04/27/20 09:21 AM
Char Baby Offline
Yes, replace everything.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Should l Replace Tensioner w/Timing Belt ? [Re: Gebo] #5414428 04/27/20 09:37 AM
Number_35 Offline
If it's a hydraulic tensioner, yes, replace it. In my experience, they last about 1.5x as long as the recommended TB interval (that is, often failing in between TB changes).
If it's a simple spring, I don't think it's as necessary, but as the cost is fairly low you might as well. So I guess that means you should change the tensioner regardless.
One more thing to watch for - the camshaft seal(s) should likely be changed at that mileage.
Page 1 of 3 1 2 3
