Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
44 registered members (BigGeo, Amkeer, Aerojoe, 87sammy, 53' Stude, 3 invisible), 949 guests, and 66 spiders.
Topics306,117
Posts5,287,830
Members71,604
Clocking struts properly #5414222 04/27/20 04:47 AM
F
ford46guy Offline OP
F
What is the trick to getting coilover struts aligned (or clocked) precisely. For my application they specify 34.7 +-2 degrees.
The first diagram is the orientation of the strut bolt flat.
If its off even a bit, you have to loosen it up and realign (or force the spring).
The diagram is pretty unclear.
You could matchmark the new mount, but it isn't that precise(very close, but enough to redo)
How can you measure this?
Install the front coil spring insulator upper to the front suspension support as shown in the illustration.NOTE:
The arrow on the front coil spring insulator upper must align with the identification mark on the front suspension. (there is no arrow, but a dot on the mount)
(f) Align the width across flat on the piston rod end of the shock absorber and width across flat on the suspension support.
Then install thesuspension support to the shock absorber.(g) Temporarily tighten the lock nut on the shock absorber.(h)
Adjust the front suspension support sub-assembly so that the bolts come to the positions as shown in the illustration, and remove the SST fromthe front coil spring
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Clocking struts properly [Re: ford46guy] #5414273 04/27/20 06:39 AM
A
anthonym6 Offline
A
What is the application?
Re: Clocking struts properly [Re: ford46guy] #5414309 04/27/20 07:40 AM
skyactiv Offline
If this is an actual issue, there should be post on the procedure on the net. Your probably making a mountain out of a molehill.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Clocking struts properly [Re: ford46guy] #5414344 04/27/20 08:23 AM
T
tcp71 Offline
T
When we first got our van in 2005 it had a tendency to pull left. After checking alignment and finding it good, the service manager mentioned rotating the spring and perch, which he did. Never had a pulling problem after that. By the diagram you simply compress and rotate the spring to get the end to match the angle.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Clocking struts properly [Re: anthonym6] #5414348 04/27/20 08:24 AM
F
F
Lexus 11 GS AWD Front.
The strut has a hook for the AWD and a pin bolt that goes in a sleeve. The last pic is for the rear strut.
Not such a popular car to have many tutorials.
Re: Clocking struts properly [Re: ford46guy] #5414504 04/27/20 10:42 AM
The Critic Offline
Prior to removing the strut, use a paint pen to mark the strut mount stud that faces the outside of the vehicle. Once the strut assembly is out of the vehicle, use a paint pen to mark the end of the upper coil and the corresponding location on the underside of the strut mount. This will determine where the bottom coil will end as this is important for mounting purposes. Some Toyota strut mounts are “clocked” in a specific manner and this procedure will help ensure that the strut mount is installed in the correct orientation.
Transfer those marks to the new strut mount and reinstall your newly “built” assembly.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Clocking struts properly [Re: ford46guy] #5414531 04/27/20 11:20 AM
slacktide_bitog Offline
The 4th gen Maxima also has a clocking position like that. In that car, you bolt the top nuts first, then take a long screwdriver and turn the eye at the bottom of the shock until it's in the correct position smile
Are there any holes at the bottom of your strut? A clevis mount? Anything?
Re: Clocking struts properly [Re: slacktide_bitog] #5414590 04/27/20 12:12 PM
F
F
the bottom of the strut sits in cast iron bracket. It is round with a notch. Notch would face the front I believe (not sure). How to install a Tundra Drive Train in a Sedan :lol:
[Linked Image]
Re: Clocking struts properly [Re: The Critic] #5414595 04/27/20 12:14 PM
F
F
I did that, was probably off by .5 degree and had to loosen almost all the way to move it a bit. Lets just say it is a very strong, tight spring for this 2 ton car ,and some coils are progressive and it matters how you compress it (with those junky sticks). Next one I will mark very precisely. If the angle is correct the lower part (I posted another diagram) just "falls in."
Re: Clocking struts properly [Re: ford46guy] #5414602 04/27/20 12:27 PM
The Critic Offline
Yep, that happens when you replace the mount. This is why we try re-use the mount if at all possible. When the mount is reused, the spring/mount relationship does not get changed.
Re: Clocking struts properly [Re: The Critic] #5414761 04/27/20 03:13 PM
F
F
Thanks. Was on the fence with the mounts but the rust was a bit too much for comfort. The rubber looked very dry too, but these may be in another 100K.
