Yes, but use the JT6 that has the 3% moly in it for ball joints, tie rods, pitman, centerlink, etc. Use the JT6 w/o moly for roller bearings, u-joints, etc.
Originally Posted by Snagglefoot
Originally Posted by luca
I wanted to double check if Mystik #2 high temp is acceptable to use in ball joints. Thanks!
I take it you already have a tube of it.? Yes, it is rated GC for wheel bearing and LB for chassis lubrication and is perfectly suitable.
Yes I have a tube of it in my gun. It's the non moly. Sounds like it'll do just fine in my new ball joints. Thanks for confirming
