Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
94 registered members (AlienBug, 4WD, 53' Stude, A310, 10WSmuckers, ABN_CBT_ENGR, 6 invisible), 2,492 guests, and 29 spiders.
Topics305,939
Posts5,283,339
Members71,540
Laptop Wakes Up From Sleep Mode By Itself #5414041 04/26/20 08:47 PM
Z
ZeeOSix Offline OP
Z
My new laptop with Windows 10 will wake itself up when it's in "Sleep Mode". Does Widows 10 do this for some reason, like checking for updates or running a virus scan even though the computer is sleeping? My Windows 7 machine never did this ... when it was asleep it stayed asleep until I woke it up manually.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414045 04/26/20 08:51 PM
B
blufeb95 Online Content
Online Content
B
Windows 10 will wake to install updates. There was a way to disable it but when I attempted to do it recently it gave me some error and wouldn't let me change the setting.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414066 04/26/20 09:06 PM
Dave9 Offline
Check Task Scheduler. You should be able to disable that or change when it happens.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: blufeb95] #5414091 04/26/20 09:37 PM
Z
ZeeOSix Offline OP
Z
I found that setting in Windows Updates and adjusted it to a narrow window, but the computer was still waking itself up outside the time window I set.
Thanks ... I'll go see if I can find Task Scheduler and look into the settings.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414114 04/26/20 10:16 PM
Z
ZeeOSix Offline OP
Z
Ok, so I went into Task Scheduler (talk about settings galore on stuff I've never heard of), and did see some tasks that were checked "Wake the computer to run this task". What a mess. Maybe I'll just leave it alone since I have the computer to go back to sleep after 45 minutes.
Couple of examples below.
[Linked Image]
[Linked Image]
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414144 04/26/20 11:04 PM
B
Online Content
B
You finally got me to look into how to get this done.
I had to download PsTools from SysInternals and from the directory I extracted PSTools into I ran "psexec.exe -i -s %windir%\system32\mmc.exe /s taskschd.msc" from an elevate command prompt. Then I was able to disable all the "Wake the computer to run this task" options on all the UpdateOrchestrator tasks.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414305 04/27/20 07:33 AM
F
FT92 Offline
F
wondered about that myself ,only my PC does that , guess i know why now thanks
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414408 04/27/20 09:22 AM
T
Touring5 Offline
T
There are a couple of simple command line commands (run a command prompt as administrator):
powercfg -lastwake
and
powercfg -waketimers
I had a long standing issue with this happening, turned out the solution was to disable the ethernet adapter from being able to wake the pc (via device manager).
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5414457 04/27/20 10:01 AM
J
JMJNet Offline
J
Sad to say that McAfee is probably the worst apps that you can add to your laptop.
It is a resource hog.
  • 2017 Toyota Sienna
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: JMJNet] #5414463 04/27/20 10:03 AM
4WD Online Confused
Online Confused
Yep … just removed it when my son was trying to speed up my laptop that has spent very little time on the net.
(I’m mainly on my company Dell or an iPad like now)
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: JMJNet] #5414658 04/27/20 01:30 PM
Z
ZeeOSix Offline OP
Z
Yeah, it came loaded on this Dell laptop. Free 1 year full subscription. I plan on removing it at some point and just going with Windows Defender.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: blufeb95] #5432544 05/18/20 04:09 PM
E
Ed_T Offline
E
run in an admin command prompt: powercfg.cpl
change plan settings
change advanced power settings
sleep
allow wake timers
setting: disable
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: Ed_T] #5432601 05/18/20 05:03 PM
Z
ZeeOSix Offline OP
Z
sleep
allow wake timers
setting: disable
My laptop is waking up from Sleep Mode every 3 hours. I went into settings yesterday and disabled the "Sleep > Allow wake times", but it shows that it still woke up one time last night. "Plugged in" was set to 'Enabled' before I changed it. Need to track down whatever else is triggering a wake-up from Sleep Mode.
Any more ideas what where else to check to find out what's waking it up at night?
[Linked Image]
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: ZeeOSix] #5432641 05/18/20 05:46 PM
U
uc50ic4more Online Content
Online Content
U
I think Win10 also defaults to defragging the HDD every week, which it'll do during off-peak hours.
Re: Laptop Wakes Up From Sleep Mode By Itself [Re: uc50ic4more] #5432829 05/18/20 08:58 PM
Z
ZeeOSix Offline OP
Z
I disabled disk defrag since I have a SSD. So something else is still waking it up from Sleep Mode.
