Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
104 registered members (bbhero, Astro14, 2010Civic, 2015_PSD, BigGeo, Alfred_B, 7 invisible), 2,120 guests, and 18 spiders.
Topics306,108
Posts5,286,573
Members71,586
Mystik JT6 #2 hi temp for ball joints #5413994 04/26/20 07:22 PM
L
luca Offline OP
L
I wanted to double check if Mystik #2 high temp is acceptable to use in ball joints. Thanks!
Re: Mystik JT6 #2 hi temp for ball joints [Re: luca] #5414001 04/26/20 07:36 PM
Z
zfasts03 Offline
Z
Yes, but use the JT6 that has the 3% moly in it for ball joints, tie rods, pitman, centerlink, etc. Use the JT6 w/o moly for roller bearings, u-joints, etc.
w/moly
https://www.mystiklubes.com/do/product/CAR_SUV_VAN_LT_TRUCK/665056002
w/o moly
https://www.mystiklubes.com/do/product/CAR_SUV_VAN_LT_TRUCK/665005002
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Mystik JT6 #2 hi temp for ball joints [Re: luca] #5414019 04/26/20 08:20 PM
Z
zfasts03 Offline
Z
I should have said, either can be used...
but moly is preferred for slow speed pounding joints and...
no moly is preferred when bearings need to roll.
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: Mystik JT6 #2 hi temp for ball joints [Re: luca] #5414117 04/26/20 10:23 PM
Snagglefoot Offline
According to the PI sheet the moly is for mining, construction and severe industrial applications. Another case of Bitogger overkill?
If you want the job done right......do it yourself.
Re: Mystik JT6 #2 hi temp for ball joints [Re: luca] #5414125 04/26/20 10:37 PM
Snagglefoot Offline
I take it you already have a tube of it.? Yes, it is rated GC for wheel bearing and LB for chassis lubrication and is perfectly suitable.
Re: Mystik JT6 #2 hi temp for ball joints [Re: Snagglefoot] #5414291 04/27/20 07:09 AM
L
luca Offline OP
L
Yes I have a tube of it in my gun. It's the non moly. Sounds like it'll do just fine in my new ball joints. Thanks for confirming
Re: Mystik JT6 #2 hi temp for ball joints [Re: luca] #5417809 04/30/20 10:06 PM
N
nobb Offline
N
I use the standard JT6 for everything: Up here in Canada it's readily available at Canadian Tire, but I've never seen the moly version anywhere.
