Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
100 registered members (ABN_CBT_ENGR, 4WD, 10WSmuckers, 330indy, 55hambone, 53' Stude, 11 invisible), 2,513 guests, and 23 spiders.
Topics305,938
Posts5,283,305
Members71,540
Honda engine #5413825 04/26/20 03:01 PM
R
rokwldr Offline OP
R
I have a Northstar generator with a Honda GX620 20 H.P. It has around 100 hours on it. I used Napa universal fleet 15-40 in it for the first two oil changes. It calls for 10-30 or 30W. I see now Honda has a synthetic oil for their power equipment. I am now thinking of using a 10-40 synthetic maybe like Shell Rotella or M1 15-40 Delvac. These oils are higher in zinc than car oils and this is a flat tappet engine and works hard here in South Florida. It had done fine on the Napa but requires 50 hour oil changes. I'm thinking I can go to 75 with a good syn. Thoughts anyone?
Re: Honda engine [Re: rokwldr] #5413840 04/26/20 03:19 PM
spasm3 Offline
How much does it hold? I have synthetic in my small generator, but it only holds like .6 quarts. So i will change at 50hrs.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Honda engine [Re: rokwldr] #5413860 04/26/20 03:51 PM
R
rokwldr Offline OP
R
About a quart and a half.
Re: Honda engine [Re: rokwldr] #5413875 04/26/20 04:22 PM
Sam_Julier Offline
There was a person on the site from Calgary. Clevey, I think. He hasn’t posted in a while.
He had over 20 Honda powered generators and compressors for his home construction business. They run all day, 7 days a week. He used 5W30 in the winter, 15W40 in the summer. Conventional. 100 hour OCI. His highest time engine was over 10,000 hours.
I think 15W40 changed every 50 hours will work just fine.
2013 Toyota Avalon Hybrid TGMO 0W20, 81k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 177k
Re: Honda engine [Re: rokwldr] #5413909 04/26/20 05:18 PM
Cujet Offline
Here in FL, an oil with an HTHS of 3.5-3.8 will work quite well in quality air cooled engines. I tend to use M1, 5W-40 Turbo Diesel Truck in my higher quality engines and Mobil 1 15W-50 in my Subaru powered portable generator (which may now be near 2000 hours) (as that beastie works at 100% load much of the time) .
I've found that the 100 hour oil changes specified in the owners manuals are no problem with synthetic oils. It's been many years since I've done a UOA on my OPE, but never an issue at 100 hours.
Re: Honda engine [Re: rokwldr] #5413939 04/26/20 05:52 PM
O
Oildudeny Offline
O
Mobil 1 5w30 synthetic
Re: Honda engine [Re: rokwldr] #5414018 04/26/20 08:19 PM
J
jsfalls Offline
J
I think 50-75 hr oil changes with 15w40 would be more than sufficient.... there is a 2004 craftsman mower in the family that still has the original oil and still going fine ( maybe an ounce added here or there). OPE doesn't seem to care as long as there is oil in it.
2012 Mazda 5 - Havoline 0W20, Idemitsu ATF
2003 Honda Civic EX - Bulk oil
2004 Trailblazer - needs an oil change ....
Re: Honda engine [Re: Cujet] #5414425 04/27/20 09:36 AM
J
jeepman3071 Offline
J
I agree that in the Florida heat, a HDEO is probably ideal. Anything from SuperTech 15w40 to Rotella Synthetic 5w40 will work fine for 100 hours, no need for anything fancy, just keep the level full.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Honda engine [Re: rokwldr] #5415587 04/28/20 12:35 PM
H
hatt Offline
H
Honda recommends 6 month or 100 hour changes. 75 hours on the Napa 15w-40 or any other reputable 15w-40 HDEO would be fine.
They also recommend 200 hour filter changes. I hope someone doesn't see this.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Honda engine [Re: rokwldr] #5419274 05/02/20 03:48 PM
R
rokwldr Offline OP
R
I'll probably stick with the NAPA 15-40. I also use it in my 4 stroke outboard for ten years noe. That gets a once a year oil change and that is usually 50 70 hours. Yamaha says 100 so I'm good. I've sent samples to Blackstone and they come back perfect every time. Most 4 stroke outboard oil is rebadged deisel oil. The NAPA is also. I have 12 gallons left and It works , so I'll use it. Honda says 100 hours on their strait 30W so if I have to run a week I should be good going 80 or so hrs.
Re: Honda engine [Re: rokwldr] #5420655 05/04/20 10:21 AM
ChrisD46 Offline
*I use 5W30 M1 or similar... I believe Honda recommends a 30 weight (or any derivative in a 30 weight such as 5W, 10W 15W , etc.) ??
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
