1991 BMW 735 Coolant recommendation
Waterloo, ON
Hello,
Looking for a coolant recommendation for 1991 BMW 735. Has cast iron block and aluminium head. Last time I used Peak long life, but am told these universal coolants have only 2% corrosion inhibitors, and dedicated formula has 5% inhibitors. Have Prestone dex-cool in the stash. Any thoughts?
Zerex G48, avaliable 50\50 premixed at Walmart. If you need concentrate, head over to the local BMW or Mercedes dealer and ask for a gallon of blue coolant.
Alternatively, you can use PEAK OE Equipment European Blue 50\50 with a softer acid than most other blue blends but that's not a big deal in this car.
Probably don't have the owner's manual? Get it from the BMW dealer.
I use BMW coolant only- and I change it every two years. That regimen has served me well for 37 years and 12 BMWs.
G-48 or G-05. They are about the same with the exception of G-05 NOT having 2-EHA which IMO is a good thing in old systems. I personally ran G-05 in my 1991 318i for most of my 116k miles of ownership (bought used). The entire system minus the profile gasket was original, clean, and worked perfect.
PEAK makes a G11/G48 blend with sodium benzoate instead of 2-EHA. Main upside to this route is that you get to keep the delicious dark blue color.
Officially BMW would tell you to run BMW blue (aka G48) which does have 2-EHA. So if BMW is telling you to use their coolant with 2-EHA I wouldn't worry about picking a coolant that doesn't have it. Many BMW owners run Prestone without issues which until very recently was a straight Dexclone so you can make your own conclusion.
BMW Blue (G48) is what I call G-05 Lite, they are very similar, but the G-05 has a few extra adds like Nitrite to protect Diesel engine liners from cavitation corrosion. Adds BMW blue for a gas engine doesn't require, but it's not a problem being there.
G-48 is gas only I believe
G-50 is gas and diesel rated
I consider them fairly interchangeable in a gas/petrol engine. I would happily run G-05 in your older BMW, but I would miss the great blue colour.
The modern BMW G48 contains 2-Eha, which the original coolant would not have had, so i'd probably run G-05 in it.
It has about half the silicate of G48 , 200-300ppm while G48 has 500-600ppm, but Nitrite which is good for cast iron and cavitation protection, Also Molybdate which is a rare inhibitor but one that works really well for many metals specially solder.
I bought the car new, so yes I have the owners manual, but that information is 29 years old.
Sounds like G-05 is what I want. Thanks to all who replied, I learned a lot...
G-05 is a great choice, and readily available in the US.
However, if you want to retain that inky blue colour, there is Pentofrost NF, which is basically a VW G11 Spec coolant ( very similar to G48, but without 2-Eha )
I have a 1980 528i and an 1982 320. I have been using G-05 in them for years. I have also used the older BMW blue antifreeze in the past (not sure it was G48 back then). Before that I used plain old green IAT antifreeze. The G05 has worked fine for me for probably 20 years, I would recommend it.
wb
I don't recall that the manual for my 91 BMW cited a spec, standard, or type. As I recall, it just said genuine BMW coolant...
"With the protection of the environment in mind, BMW has been filling all of its vehicles with nitrite- and amino-free anti-freezing and anti-corrosive agents since mid-1986 as standard practice. The use of anti-freezing and anti-corrosive agents that contain nitrites and amines is no longer permissible."
Basically the reason why most German OEMs used G11 instead of G05.
Daimler used G-05 until pretty recently, at least for older vehicles... I have MB-labeled G-05 still on my shelf.
Of course Daimler is not BMW. BMW has indeed used blue for a very long time - whether G11 or G48 a decade or more ago I couldnt say. When I looked into it for my M42, it was G-48, but my BMW was 20 years old at that point...
Nitrite- and amino-free, with protection for aluminum radiators was what the manual called for at the time.
The factory coolant turned blue around 1998. Prior to that, it was a pale green, like Volvo's.
G-05 has been a popular alternative to G48, and more readily available in the aftermarket. The Zerex-branded G48 improved upon its availability, but the full strength version is harder to find than the 50/50. NAPA and the parts houses will have the concentrate, but most chain stores will only carry the 50/50 if they have it at all.
