What would you do. About a year ago, I installed some Autolite platinum spark plugs in my Jeep. Within about 1 month, I noticed rust on all of the plug bolts. Seeing this, I immediately replaced the plugs with new NGK’s. But, the lame Autolite’s threads had developed rust too, leaving rust in the threads on the motor’s head. Since then, the engine hasn’t idled very smooth. I suspect that the rust has caused resistance in the plug to engine ground.
Here’s what I plan on doing. I’m going to take a stainless steel pipe brush and scrub out the plug holes. I know that some of the rust will get into the cylinder, but, I suspect the amount will be minor, and will be quickly combusted.
What do you guys think?
