Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
81 registered members (1978elcamino, 2015_PSD, 64bawagon, 97prizm, alchargo, AndyB, 11 invisible), 2,019 guests, and 80 spiders.
Topics306,053
Posts5,286,483
Members71,593
Montana Bullet Works 44 Magnum #5413461 04/26/20 09:14 AM
7
762fermeandyou Offline OP
7
Hi all,
Ordered up 200 .44 Mag 255gr SWK-K 15 br hardness from MBW. I have a S&W Stealth Hunter 7.5" I have shot jacketed Nosler and XTP's only. I have some virgin Privi brass, Fed magnum primers, CCI large primers, and powder. H110, 296, 2400, IMR 4227, and Unique. I figure I will social distance in reloading room and make up some loads. I usually refer to my Lyman manuals with 44 magnum. Jacketed bullets have never disappointed me in this revolver, however I am bored and want to try something else. Anyone try MBW?
62 Mercury Meteor 5.0 10w30 VPB blend / FL1A
95 Jeep ZJ 4.0 5w30 Havoline Conv / Rislone ZDDP / XG8A
15 Silverado 5.3 0w20 QSUD / PF63E
17 Explorer 3.5 N/A 5w20 Napa syn / Napa Proformer
Re: Montana Bullet Works 44 Magnum [Re: 762fermeandyou] #5413472 04/26/20 09:23 AM
JohnnyJohnson Offline
Well I sure hope they are gas checked if you are shooting them and any real kind of velocity. I find lead makes the best target loads and I shoot 200 Gr. SWC I cast myself. They are Br hardness 15. I use 5.0 Gr. of Titegroup. Hotter loads you may also want to look at Lil'Gun made by Hodgdon.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Montana Bullet Works 44 Magnum [Re: 762fermeandyou] #5413488 04/26/20 09:39 AM
Slick17601 Offline
Should work great with 2400.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Montana Bullet Works 44 Magnum [Re: JohnnyJohnson] #5413492 04/26/20 09:46 AM
7
7
They are not Gas checked Johnny. Suggested velocity? I have a chrono.
Re: Montana Bullet Works 44 Magnum [Re: 762fermeandyou] #5413866 04/26/20 04:10 PM
Well personally I keep all my none gas checked bullets well under 1000. Then I've had zero issues with leading. Casting season is about to begin. I'll make another 2000 38's and Probably 1600 45's. I will size and Lube them next winter when the weather is miserable.
2004 Corolla 140116
2006 Duramax 77077
Re: Montana Bullet Works 44 Magnum [Re: 762fermeandyou] #5414133 04/26/20 10:48 PM
T
TurboLuver Offline
T
I have no observable leading using the proper diameter Keith style 250-260gr plain base cast bullets in my 44's up to around 1350 fps.
Keith's famous 44 mag load was his 250-260gr SWC over 22.5grs of 2400 for around 1400 fps with no leading.
2015 Lexus GS350 F Sport RWD
2008 Civic SI
1999 GMC Suburban K2500
1997 Jeep Cherokee Country
Re: Montana Bullet Works 44 Magnum [Re: 762fermeandyou] #5414147 04/26/20 11:12 PM
B
bunnspecial Offline
B
My thoughts on shooting lead in 44 Mag(and other magnums) in general, without any experience with these particular bullets:
1. Most leading comes from bullets that are too hard. Hard bullets don't obturate properly to the bore, and you can end up with combustion gases leaking around the base and effectively soldering lead to the barrel. This type of leading is very difficult to remove, while "streaking" from running a soft bullet at high velocity usually brushes out easily.
As an example to this point-22LRs are dead soft pure swaged lead, and usually run at 1000-1200fps depending on barrel weight. When was the last time you had a badly leaded 22?
I shoot a lot of Missouri "Cowboy" bullets, which are around BHN 12. I've run these in various calibers at 700-1200fps and they don't lead.
2. Somewhat contrary to the above point, most modern S&Ws have an "EDM" barrel, which is almost glass smooth. My 629 "Mountain Gun" has this type of barrel. These are so smooth that there can be issues with bullet lube wetting the barrel properly, and they can lead like crazy even with everything done right. These barrels can usually be recognized because, aside from looking basically perfect, the rifling doesn't have the sharp edges typically seen in conventionally rifled guns.
3. If all else fails, tumble lubing in Lee Liquid Alox will usually keep most anything from leading and is easy to do.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Montana Bullet Works 44 Magnum [Re: TurboLuver] #5416733 04/29/20 06:45 PM
Slick17601 Offline
This
Re: Montana Bullet Works 44 Magnum [Re: Slick17601] #5416825 04/29/20 08:19 PM
B
bunnspecial Offline
B
This
Elmer didn't like/use gas checks either.
There again, size right and don't go overboard with hardness and you won't have leading issues.
