Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
High Gloss product for Silver car?
by tc1446 - 05/28/20 11:15 AM
oldcodger, cwllams1, Danwrig, DanielR, lagreca
71557 Registered Users
104 registered members (another Todd, AandPDan, BlakeB, 53' Stude, bullwinkle, 14 invisible), 2,234 guests, and 24 spiders.
Topics305,990
Posts5,284,276
Members71,557
scratch help #5413417 04/26/20 08:18 AM
marine65 Online Content OP
OP Online Content
I have a black car.
There is a 6" long scratch that is to the metal.
Is there a product that will fix this with out using paint?
Like rub and rub and its gone?
2018 Hyundai Elantra GT black
2018 Hyundai Elantra GT silver
yup got two of them.
Re: scratch help [Re: marine65] #5413419 04/26/20 08:25 AM
wwillson Offline
Administrator
Administrator
If the scratch is to the metal, then no there is rubbing out. The body shop route is probably the only way to fix it correctly, if the car is worth it. It's already rusting and the body shop will have to remove the rust, prime, paint, and clear coat.
Re: scratch help [Re: marine65] #5413499 04/26/20 09:58 AM
2
2010Civic Offline
2
Touch up paint or getting it resprayed are your only options.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: scratch help [Re: marine65] #5413584 04/26/20 11:33 AM
W
wymi516 Online Content
Online Content
W
My sisters Black 2012 Honda accord had a deep scratch on the drivers side rear door. Body shop repair was $550.00, they did a great job on blending the paint.
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
Re: scratch help [Re: wymi516] #5413589 04/26/20 11:38 AM
H
HowAboutThis Offline
H
Depending how new, you could get the spray paint car touch up paint and tape off that side of the car except for the area around the scratch. Then clean it and use the spray paint touch-up paint and clear coat your can get at places like NAPA. I did it on a car years ago that had some dents and dings and it actually turned out Ok. Unless you really looked you couldn't see it.
But I wouldn't recommend if you care about your car's looks. I did it just to keep it from rusting but was surprised how well it worked. My car was about 8 years old at the time.
Re: scratch help [Re: marine65] #5413679 04/26/20 12:32 PM
danez_yoda Offline
6" scratch isn't that bad. There are DIY methods to fix this that i've used over the years. its not perfect but if someone doesnt know the scratch is there, they would not notice it.
1) supplies
a. touchup paint that is color matched to your car. Dealership is best, Duplicolor is OK.
b. 1500 grit wet-dry sandpaper.
c. 70-90% alcohol (good luck funding it today. smile you are just using a little of this to clean the oil/wax from the scratch before painting. not critical
d. Meguiars ultimate compound
e. microfiber towels
f. polishing pad (foam) (if you have a DA polisher that works too. Orange pad form Harbor freight)
g. A flat sanding block to hold the 1500 grit sand paper)
2) fold the 1500 grit to a V and run it across the bottom of the scratch to remove any light rust. should see bare metal below.
3) Wipe with alcohol to remove any oil (fingerprints) or wax from the scratch and area
4) put masking tape on either side of the scratch as close as possible to the edges and fill paint.
5) allow to dry overnight
6) Paint will shrink back a little quite a bit.
7) fill again with more paint until it is slightly proud
8) allot to dry again.
9) remove the tape and sand with the 1500 grit sand paper on the flat block. you should only be sanding with +/- 1/2" r so of the scratch. Go across the scratch not with it. I also used circular motion when sanding. Rince often and continue until the paint is flush with the rest of the pain on the car. Be carefull to only sand the ridge and not through the clear coat on either side of the ridge.
10) when done will have a dull inch or so along where the scratch was.
11) then get the meguiars ultimate compound and go at it in a circular motion by hand with the foam pad. This will not cause scratched in the paint as it is pretty mild but can buff out the 1500 grit scratches with enough persistance.
12) once done use the alcohol to cleak the cutting oils off the paint, if you still see hazing, go at it again with the meguiars. It shoud get it all out.
13) once done apply a coat of wax.
Step back 10ft from the scratch then give it a look. If you still see it and are highly annoyed by it, you need a paint and body shop. I've done many of these and as long as the metal is not dented under the scratch, it works really well.
Re: scratch help [Re: danez_yoda] #5420069 05/03/20 03:11 PM
OP Online Content
1) supplies
thanks but thats a whole lot more work then i want to do.
I may just clean it up good and cover it with black magic marker(its a black car).
Re: scratch help [Re: marine65] #5421037 05/04/20 05:56 PM
OP Online Content
I cleaned it up and removed the hot wax from the car wash.
Very carefully I did 3 coats of black magic marker.
It looks better then I thought it would.
I just wonder how long the magic marker will last.
