Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
16 registered members (BlakeB, bbhero, blufeb95, Char Baby, bachman, 1 invisible), 1,110 guests, and 47 spiders.
Topics306,047
Posts5,286,360
Members71,593
Key fob screw stripped #5413403 04/26/20 07:56 AM
I
Imp4 Offline OP
I
Ok, so here is a picture of my recently acquired Honda key fob and you can see that the phillips head screw that hold the thing together is stripped.
I've tried loosening it with 2 or 3 different small screw drivers but so far no luck.
Any ideas on how to get this apart short of drilling the head out?
Thanks!!!
cheers
Re: Key Fob screw stripped [Re: Imp4] #5413404 04/26/20 07:58 AM
spasm3 Offline
Small left hand drill bit?
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Key Fob screw stripped [Re: spasm3] #5413408 04/26/20 08:04 AM
Snagglefoot Offline
If you have the time, they’re available on Amazon.
If you want the job done right......do it yourself.
Re: Key Fob screw stripped [Re: spasm3] #5413414 04/26/20 08:14 AM
B
Brybo86 Offline
B
I agreed with this advice.
Those threads typically have a spot of blue locktite on them as well to prevent vibrations from loosening
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Key Fob screw stripped [Re: Imp4] #5413421 04/26/20 08:29 AM
K
KGMtech Offline
K
Hit it with a small pointed tip soldering iron first, if there was any loctite, it will be softened.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Key Fob screw stripped [Re: Imp4] #5413489 04/26/20 09:39 AM
Snagglefoot Offline
After years of reading about left hand bits I finally ordered a set off Amazon this morning. $15.00 US. laugh
Re: Key Fob screw stripped [Re: Imp4] #5413560 04/26/20 11:04 AM
E
ecotourist Offline
E
I had exactly the same problem. My only small screw driver kept slipping out of that equally tiny screw head. And that screw is in there really tight.
Here's what I did:
Put the screw driver and the key fob (with an appropriate piece of wood to prevent marring the fob) in a vice. Tighten gently so as to force them together. Have someone hold the two in line while you turn the screw driver with vice grips or similar. It sounds like overkill but it works.
PS I did the screws on both my key fobs while I was at it.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Key fob screw stripped [Re: Imp4] #5413565 04/26/20 11:09 AM
N
NormanBuntz Offline
N
My Honda key fob is 13 years old and the screw also became stripped. I drilled it out, and the two halves still stay snapped together. No problem.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Key fob screw stripped [Re: Imp4] #5413686 04/26/20 12:36 PM
Dave9 Offline
I don't understand. It's in plastic, impossible to need much torque, so just take some old worthless screwdriver and file down the point to fill in the shape of the stripped head.
Re: Key fob screw stripped [Re: Dave9] #5413737 04/26/20 01:16 PM
E
ecotourist Offline
E
The screw may extend into the metal part of the key. And they may have used some sort of loctite or similar agent on it as well.
I don't know that the screw is so much tight as you can't get hold of it because of that small Phillips head. Anyway it's a real bear to get out.
Re: Key fob screw stripped [Re: Imp4] #5413775 04/26/20 02:10 PM
O
Oildudeny Offline
O
Put a piece of rubber band or paper between the screw and screwdriver tip give it some pressure. Should fill in the stripped area.
Re: Key fob screw stripped [Re: Imp4] #5414782 04/27/20 03:48 PM
I
Imp4 Offline OP
I
Success.... Sort of....
I tried the paper and the rubber band trick.
No luck.
I ended up drilling out the head of the screw so I am able to get the fob apart but I didn't get the rest of the screw out of the body of the fob.
Time for Plan C, whatever that is.
Re: Key fob screw stripped [Re: Imp4] #5414865 04/27/20 05:40 PM
bdcardinal Offline
Some places sell the plastic "bodies" and you transfer the "guts" over from the original key. I know people come in wanting them for Fords all the time insisting we sell them, we don't but the aftermarket does. I will transfer the guts over for people, just charge them for a key battery since you might as well have a new one in there.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Key fob screw stripped [Re: Imp4] #5414881 04/27/20 06:02 PM
J
Jake_J Offline
J
I had the exact same problem with the an Honda Accord key that looks like the OP's key. You can buy the blank key with the plastic clamshell that holds the keyless entry circuit. I ended up buying the blank key body from Amazon, and going to the Honda dealer to get the key cut from the VIN number. Those style of Honda keys you can transfer the keyless entry circuit and the immobilizer RF ID chip and you don't have to do any programing.
Here's a couple examples of the keys (there's 2 and 3 button versions, so get the one that matches your key):
https://www.amazon.com/uxcell-Repla...blank+key&qid=1588027832&sr=8-19
My replacement key has worked well, the dealer had no problem cutting the aftermarket key. They don't look 100% identical to the original key as they lack the H or it looks different, and the metal of the key on mine is a slight gold colour compared to original's more silver colour.
Re: Key fob screw stripped [Re: Imp4] #5415210 04/28/20 12:37 AM
E
ecotourist Offline
E
Why not just snap it back together (without the screw).
