Worked on a Chevy Trailblazer my sister in law was going to use. It had sat for a long time. It needed a new battery, starter and front wheel bearing.
While working on it I noticed the passenger side of engine/under carriage area wet and drips on the ground. I decided to check the PS fluid level and when I took the cap off fluid poured out of the top of the reservoir. It had been way overfilled!
Would this cause leaking from the cap or hose damage?
