Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
95 registered members (53' Stude, A310, 10WSmuckers, 4WD, ABN_CBT_ENGR, Al, 7 invisible), 2,512 guests, and 51 spiders.
Topics305,939
Posts5,283,333
Members71,540
Fatal explosion when replacing fuel pump #5413332 04/26/20 03:50 AM
W
wormwood1978 Offline OP
W
Last year i manually siphoned 20 gallons of stale gas from a boat. What a pain in the [censored] and thought to myself how much easier it would be if i connected an electric pump. I saw this article this morning.
https://www.wabi.tv/content/news/Le...-while-working-on-his-car-569959321.html
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413333 04/26/20 03:52 AM
Z
ZeeOSix Offline
Z
Not a good way to go. eek
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413346 04/26/20 05:51 AM
demarpaint Offline
Not good!
God Bless Our Troops
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413370 04/26/20 06:47 AM
T
Trav Offline
T
I see the cheap pump advertised on TV and wondered if using that could have the same result.
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413372 04/26/20 06:55 AM
T
Tjbouwhu Offline
T
Thanks for sharing. A good reminder,
Notice How often you see someone pumping gas these day with the vehicle running, especially...99.99% of the time it isn’t an issue, unless there is a fuel spill.
Tom
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413374 04/26/20 07:07 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Yikes. Not good practice to sit amidst a bunch of full gas cans, but it’s a little bit surprising that a little transfer pump would be sparking so bad that it would cause an explosion outdoors. I get it if it’s in an enclosed space. Conditions must have been just right.
Sad, especially since the design for the tank and pump probably didn’t have to be that way, and a slight design change with an access cover and a pump that is removable from the top might have avoided this...
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413384 04/26/20 07:25 AM
N
NYEngineer Offline
N
A few years back, a guy I know was draining gas from the tank of a customers survivor 67 Camaro. He spilled the gas onto a corded 120 volt drop light with a regular 60 watt bulb in it. Huge fireball and lit up the shop. He was burned pretty badly as well. It was his own shop and also housed his own cars and motorcycles. Im pretty sure it was a total loss... building, cars, customers car...
It seemed odd to me he would have made such a rookie mistake. He had been in the business for a lot of years.
I would never pump gasoline with an electric anything.
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413454 04/26/20 09:08 AM
ABN_CBT_ENGR Online Content
Online Content
Well, it does beg the question since there are all types of electric pumps for pumping flammable and explosive liquids that are intrinsically safe and well proven,
Was a "fit for purpose" electric pump being used and if so was it a pump malfunction or misuse in an unsafe manner.
The articles I saw don't really address that very important question.
Re: Fatal explosion when replacing fuel pump [Re: NYEngineer] #5413456 04/26/20 09:11 AM
CT8 Offline
everytime you go to the gas station you are using an electric something to pump gas. You car most likely has an electric fuel pump.
2015 F150 2.7
2018 F350 6.2
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413460 04/26/20 09:13 AM
P
PowerSurge Offline
P
A spark with a lot of gas fumes = not good
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413530 04/26/20 10:40 AM
F
Fitter30 Offline
F
Bought a battery pump similar to this one at walmart $11 to remove 20 gallons.of gas when replacing fuel pump in my van after dropping the tank then refilling tank when done.
https://www.walmart.com/ip/Handheld...Oil-Water-Liquid-Transfer-Pump/738242503
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413684 04/26/20 12:34 PM
L
Lolvoguy Offline
L
Yes, but the pump at the gas station probably isn't some cheap "made in China" garbage which sells new for under $10.
Anyone who uses a cheap electric fuel pump of the aforementioned quality can only expect favorable results.
Similar to those who use old concrete blocks to suspend a car while working underneath.
If I were in that position, I'd use something that uses vacuum to create suction, such as a mityvac(sp?) or something like this if I were on a budget:
hand operated gas pump
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Fatal explosion when replacing fuel pump [Re: Lolvoguy] #5413696 04/26/20 12:41 PM
9
92saturnsl2 Offline
9
What's wrong with concrete blocks? I use them to support a vehicle on occasion. Or are you referring to the hollow cell cinder blocks?
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Fatal explosion when replacing fuel pump [Re: 92saturnsl2] #5413705 04/26/20 12:47 PM
L
Lolvoguy Offline
L
Too frangible.
Say "no" to Turbo!
Re: Fatal explosion when replacing fuel pump [Re: wormwood1978] #5413716 04/26/20 12:54 PM
T
TheLawnRanger Offline
T
I like DIY auto repair but I'm afraid to mess with the gas tank. That being said. I likely would have gotten the gas out of a tank with a small electric or battery operated pump and not thought too much of it.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
