Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
61 registered members (4WD, blufeb95, bbhero, BlakeB, bamorris2, 6 invisible), 1,163 guests, and 73 spiders.
Topics306,273
Posts5,289,387
Members71,616
Coolant bleeding proceedure details #5413247 04/25/20 09:52 PM
spavel6 Offline OP
Just replaced a bunch of gaskets and coolant system components on a Ford 4.0 OHV in my Ranger.
I think my standard bleeding proceedure is leaving air in the system because I keep getting a fluctuating temperature reading. Meanders towards the middle, then drops, then repeats.
Today I parked on an incline, and used a coolant funnel in the radiator and let the car idle, no bubbles appeared. Once warmed up, if I rev the engine and hold it there, coolant stays at its level. Once I release my foot off of the gas, I get a geyser of coolant as it comes back down to idle.
Another geyser when I shut it off (with the cap off).
I can't find any info on why it would geyser like that as it returns to idle. Most sites say to rev the engine to force air out. Or is this wrong?
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Coolant bleeding proceedure details [Re: spavel6] #5413291 04/25/20 11:25 PM
J
Jake_J Offline
J
The geyser is not normal, have you checked that your radiator is not partially blocked up? What was the condition of the coolant that came out of the radiator when you changed it? Revving the engine during bleeding is optional, it just speeds up how fast the engine reaches operating temperature and the thermostat opens up. Are you sure that the thermostat opened when you did the bleeding procedure, did both radiator hoses have the same temperature to the touch?
Re: Coolant bleeding proceedure details [Re: spavel6] #5413295 04/25/20 11:31 PM
clinebarger Offline
Don't rev it with the cap off! I find that varying the rpm in quick succession will force the thermostat to open faster (From idle to @ 2500 rpm). The temperature might rise a little past normal then drop like a rock....This is how you know the 'Stat opened.
Shut the engine off & allow the pressure to bleed off if any is present in the system.
Add coolant 'til full. Put the Rad cap back on, Start the engine & rev it to @ 2500 RPM to bleed the rest of the air out of the system. (Both Rad hoses will be HOT)
Shut the engine down & allow to cool, Add coolant as needed.
I don't recall the 4.0L Ford being difficult & needing all the above? But sometimes even systems that aren't known to airlock will anyway!
Glad I bought a Coolant Refiller....Saves alot of time!!!
2001 Chevy Camaro L92/4L80E
Re: Coolant bleeding proceedure details [Re: spavel6] #5413302 04/26/20 12:04 AM
J
junk1020 Online Content
Online Content
J
I've had plenty of different engines geyser when bleeding the cooling system while coming back to idle after running at high rpm, so in my experience that is pretty normal, as long as it doesn't continue to bubble through your funnel if you let it sit and idle for a few minutes. Did you notice a fluctuating temp gauge before the repairs you performed? Used to see a lot of cracked heads and blown head gaskets on the 4.0 ohv engines, and a fluctuating temp gauge was usually a symptom.
2011 Hyundai Sonata, Castrol Edge 0w40, Hastings LF565
2017 Toyota Sienna, Castrol Edge 0w20, Hastings LF607
2018 Hyundai Sonata, Mobil 1 5w30, Hastings LF565
Re: Coolant bleeding proceedure details [Re: spavel6] #5413313 04/26/20 12:46 AM
spavel6 Offline OP
It doesnt bubble at all, besides the geyser-ing as mentioned above.
I have a thermostat with a jiggle-valve in it, which I suppose would have taken out most of the initial air. There wasnt a big drop in fluid level when the thermostat opened up.
I did do a leakdown test this afternoon and did not see any bubbles in the radiator. It was done cold as I didnt have time to warm up the car. I'm wondering if I need to take the thermostat out to see bubbles with that approach.
Re: Coolant bleeding proceedure details [Re: spavel6] #5413323 04/26/20 01:24 AM
R
Reddy45 Offline
R
This sounds identical to when I did coolant work on the 4.2L V6 in my old F150. I saw the same fluctuations in the gauge,
Does the Ranger have an overflow reservoir (degas chamber) or are you fiddling directly with the radiator cap opening? This could be one important difference and why you are getting gushing.
On the F150, the incline trick worked for me with a little bit of accelerator input to "burp" the bubble out.. which felt like it was near the heater core. I had the degas chamber cap off at the time and the coolant level in the chamber was on the lower side of things, so if there was a "gush" it was minimal due to the space available. I don't recall ever fiddling with the radiator cap on the F150 or if it even had one.
Re: Coolant bleeding proceedure details [Re: spavel6] #5413476 04/26/20 09:27 AM
K
Kira Offline
K
A quick search over on Ranger-Forums.com or therangerstation.com might be helpful.
Could you list the "bunch of gaskets and cooling system components" you replaced?
Re: Coolant bleeding proceedure details [Re: spavel6] #5413594 04/26/20 11:42 AM
spavel6 Offline OP
Intake manifold gasket
Valve cover gaskets
Thermostat
Water pump
Rocker arms and push rods
Re: Coolant bleeding proceedure details [Re: spavel6] #5413685 04/26/20 12:36 PM
slacktide_bitog Online Content
Online Content
The Lisle coolant funnel is awesome smile
Re: Coolant bleeding proceedure details [Re: spavel6] #5415252 04/28/20 03:54 AM
T
t1snwrbrdr12 Offline
T
I work on a fleet of about half ford 4.0. They still give me trouble occasionally after 6 years of working on them. I always fill with a funnel and remove one heater hose. Sometimes I can get all the air out of the heater hose but usually not.
Re: Coolant bleeding proceedure details [Re: spavel6] #5415253 04/28/20 04:09 AM
L
Lubener Offline
L
I would use a scan tool to see exactly what your temperatures are doing. Ford has had bad sending units in the past or to verify an actual air pocket problem.
The "thinking" man's friend.
