e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
82 registered members (4WD, 2015_PSD, BAJA_05, 94astro, Avery4, 2010Civic, 6 invisible), 2,213 guests, and 65 spiders.
Topics306,301
Posts5,289,834
Members71,618
2014 TDI oil advice #5413195 04/25/20 08:26 PM
7
71Chevyguy Offline OP
7
Bought two 2014 TDI cars, one came with a maintenance plan from the VW dealer. That is all fine and good, but it got serviced and got Kendall Euro 5w40, which from my research was an A3/B4 oil. This engine calls for 5W30 low saps oil that meets VW 507 specs. The oil they used meets VW 505 specs which is pretty much the opposite formulation of what it requires. You would think a VW dealer would know better. Do I just let them use this oil in it? I don't think it will hurt the engine but I don't imagine the DPF will be too happy with it. On the other hand, the emissions system has plenty of warranty left and any repairs from it would be on their dime. They told me it meets euro standards so it is fine, I am not sure I agree. Opinions?
14 Jetta Sportwagen TDI
14 Beetle TDI
98 Buick LeSabre Defy 10w30 / Fram Ultra 3387a
Re: 2014 TDI oil advice [Re: 71Chevyguy] #5413205 04/25/20 08:43 PM
cpayne5 Offline
Ask the service guy to call his regional VW guy to confirm...on speaker phone with you there. I bet that would make him uncomfortable. Ha
They should use their 507 oil. I think they recently switched to Mobil from Castrol?
Is it Sheehy in Hagerstown or Beyer in Winchester? I had a 2013 Passat TDI that I ordered from Sheehy (when it was Sharrett) that I had Beyer do the first oil change on. I felt Beyer didn't do a good job, so I did them myself from that point forward, even though they would have been free at the dealer.
Re: 2014 TDI oil advice [Re: 71Chevyguy] #5413221 04/25/20 09:11 PM
7
7
It is actually Sheehy in Hagerstown. The vehicle was bought new from Sharrett and always serviced there on time. So at this point i'm not sure if it always got that oil or not. I stay away from Beyer, have known people who weren't too pleased with them. Their parts prices are decent on certain things though, like batteries were $70 cheaper than parts stores for OEM. I figured it would make sense to use the maintenance plan since I have it, but not sure I want to end up paying for it in the end when warranties run out and I have to put a DPF in it on my dime. May have to let them do it, then come home and drain and fill with the right stuff. Would give me free oil changes for one of the beaters haha. I just don't think it makes any sense that I would have to do that when the dealer should know what they are doing in the first place.
14 Beetle TDI
Re: 2014 TDI oil advice [Re: 71Chevyguy] #5413223 04/25/20 09:13 PM
U
UG_Passat Offline
U
Ideally you should get the proper oil in there. DPF's are not cheap, which the dealership will find some way to weasel their way out of warrantying the repair.
You should call them to arrange to get the proper oil used, the 507.00 oil.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: 2014 TDI oil advice [Re: 71Chevyguy] #5413325 04/26/20 02:10 AM
K
Kamele0N Offline
K
Call them...vw pcmo diesels are all on vw504/507 for almost a decade now...
Cant understand how dealer doesent know that? Murrica!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: 2014 TDI oil advice [Re: 71Chevyguy] #5421570 05/05/20 11:35 AM
R
racin4ds Offline
R
TDi with DPF MUST have proper 507 very low SAPS oil. Mobil is now the OEM supplier for this. Should be either 0W30 or 5W30 only.
I don' t think the occasional run of a non-507 oil will be detrimental but it wouldn't be something I'd do regularly. I brought my '13 Passat home from the dealer and noticed a window OCI sticker than stated 0W20 was put in. I quickly dumped it and put Rotella t6 in it being that I wasn't up to speed on the 507 VW spec oils. I've since went out and bought the (regretfully) Mobil 1 ESP 5W30 oil with the 507 spec.
I'd call VWOA immediately and tell them this is what the dealer is doing. I'll bet it changes very quickly... wink
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
