Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
60 registered members (Best F100, Astro14, ABN_CBT_ENGR, A_Harman, BigGeo, 5 invisible), 1,030 guests, and 75 spiders.
Topics306,117
Posts5,287,835
Members71,604
Driven DI40 Specs #5413045 04/25/20 05:40 PM
B
buster Offline OP
B
Great option for those needing a 40 grade that have a GDI engine.
HT/HS - 4.2
TEOST - 18.2
[email protected] - 81.8
[email protected] - 14.0
VI - 178
Ash Content - .72
The DI line contains mPAO.
"Testing also revealed that increasing the level of Molybdenum reduces the tendency of these abnormal combustion events. Driven Racing Oil’s DI line of synthetic Direct Injection engine oils provide excellent protection from Low Speed Pre-Ignition by delivering cutting-edge lubricant technology specifically developed for direct injection engines. Every Driven DI oil utilizes an advanced additive package designed to reduce abnormal combustion and protects against soot related wear. Featuring a lower volatility base oil that reduces crankcase vapors and carbon buildup on intake valves, Driven DI oils also reduce turbocharger deposits as evidenced by exceptional performance in the TEOST turbocharger deposit test."
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Driven DI40 Specs [Re: buster] #5413263 04/25/20 10:28 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
For $14/qt it better be good. Given the likelihood of DI vehicles making it past 100k at this point, I think I’ll pas and stick with something a bit more mainstream and lower cost.
Hard to see what actual value add this provides compared to something like M1 0w-40, IMO. The moly claim is interesting, and the low volatility is useful, but? I don’t even see a NOACK value.
Re: Driven DI40 Specs [Re: buster] #5413385 04/26/20 07:26 AM
B
buster Offline OP
B
I hear you. I do wish their data sheets were better. I think the reason why some don't post Noack is because Noack values can range when testing, so I'm told. And companies end up going with te lower value, as expected. With that said, Driven does make top notch oil. The SA is .722 and they use mPAO. I haven't seen a VOA of the DI oils but I think they contain over 300ppm of moly which is also good at helping with LSPI. cheers
Re: Driven DI40 Specs [Re: buster] #5413505 04/26/20 10:04 AM
Strjock81 Offline
Customer support at Driven is prompt and detailed as well.
2016 White Town and Country Touring
2015 White Yukon XL Denali
2014 White Ram 2500 CCSB 4x4 Cummins Bighorn
Re: Driven DI40 Specs [Re: Strjock81] #5417609 04/30/20 06:12 PM
W
whizznbyu Offline
W
Incredibly prompt.
Re: Driven DI40 Specs [Re: buster] #5417639 04/30/20 06:45 PM
B
buster Offline OP
B
They are. thumbsup
