Forums Migration
Please read this thread
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
HydroxZ, JDMorgan, sycboi, Chuck_Ellison, BakonBittz
71871 Registered Users
111 registered members (4WD, 94astro, 928, 2010Civic, 77GrandPrix, 1978elcamino, 14 invisible), 1,946 guests, and 22 spiders.
Topics307,552
Posts5,313,022
Members71,871
2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles #5411584 04/23/20 07:56 PM
T
ToyotaNSaturn Offline OP
T
Hello, It's been a while smile
2009 Subaru Forester X, base 2.5L H engine
Bulk 5w-30, whatever filter
Added 0.75GC 0w-30 at around 4K to top it off. Yes GC. I wish I could find more of this product, it's my last quart.
Bought this vehicle from my dad last July with 89K on it. This is the first sample taken on this vehicle.
I'm happy to see 5K is easily achievable in this engine. And also happy to see there's no worries of coolant in the engine either.
Cheers2
Code
OIL             Bulk 5W30, 0.75qt GC
MILES IN USE    5200
MILES           110,160
SAMPLE TAKEN    April 17, 2020
ALUMINUM        2
CHROMIUM        0
IRON            5
COPPER          1
LEAD            0
TIN             0
MOLYBDENUM      41
NICKEL          0
MANGANESE       0
SILVER          0
TITANIUM        1
POTASSIUM       0
BORON           42
SILICON         12
SODIUM          3
CALCIUM         1523
MAGNESIUM       421
PHOSPHORUS      763
ZINC            844
BARIUM          0
SUS VIS 210F    61.1
cSt @ 100C      10.52
FLASHPOINT F    N/A
FUEL DILUTION%  <0.5
ANTIFREEZE%	0.0
WATER           0.0
INSOLUBLES      0.1
TBN             2.9
2008 Honda Odyssey
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: ToyotaNSaturn] #5411730 04/24/20 12:41 AM
SubieRubyRoo Offline
Happy to see 5k is achievable? Right in the OM it says change oil at 7.5k, and that was recommended on conventional back in 2009. Non-turbo Subies are very easy on oil. Pick any name-brand API SN 5W30, change it every 7.5k, and don’t bother with any more UOAs.
Because if the head gaskets don’t leak, the only thing stopping you from seeing the far side of 250k engine-wise is not doing the timing belt every 105k and having it snap.
Did you replace the belt and pulleys since you bought it at 89k and are now at 110k?
BTW, especially with your nonchalance about oil and filtration (bulk oil and whatever filter), save any GC for a vehicle you actually care about. The N/A EJ25 does not need nor benefit from a super-fancy oil.
De omnibus dubitandum.
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: ToyotaNSaturn] #5411818 04/24/20 07:58 AM
B
bluesubie Offline
B
^ What SubieRubyRoo said! I've seen N/A EJ uoa's here with 8-9k on conventional and 11-12k on synthetic.
That wasn't the original Gold GC, was it?
drive
'20 Subaru Outback Onyx XT | Idemitsu Zepro 0W-20
'04 Subaru Forester 2.5XT | Castrol Edge 0W-40
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: ToyotaNSaturn] #5411823 04/24/20 08:02 AM
JohnnyJohnson Offline
Looks pretty good and with bulk oil no less. What kind of oil consumption are you experiencing with your Subie?
2004 Corolla 140638
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: bluesubie] #5411878 04/24/20 09:37 AM
B
bluesubie Offline
B
I meant Green GC!
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: ToyotaNSaturn] #5411946 04/24/20 11:26 AM
L
LoneRanger Offline
L
Gotta love the EJ 2.5, look at that viscosity retention. Not even a hint of shearing. Best engine Subaru ever made.
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: bluesubie] #5412795 04/25/20 12:21 PM
T
T
I meant Green GC!
It was indeed the coveted green Castrol. Oh the memories smile
2008 Honda Odyssey
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: SubieRubyRoo] #5412798 04/25/20 12:27 PM
T
T
I'm learning about Sub's quickly. No I didn't get that maintenance done. I will book it. Thank you for making me aware of it!
I was under the impression the head gaskets were prone to leaking given the H engine design. Yeah they have specific coolant to use for this application but I wanted numbers to show me, to put my mind at ease, that wasn't the problem.
There is a slight coolant leak somewhere, no one can find it. I say slight because the coolant reservoir barely goes down at all. You can smell it once the engine is warm though.
I use bulk oil since the local garage has a good special on GOF & tire rotations. I have serviced my vehicles there for years. I was going to get an M1 filter and run a batch of 5w-30 M1 EP that I have but never made it to the store for the filter.
cheers
2008 Honda Odyssey
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: LoneRanger] #5412799 04/25/20 12:27 PM
T
T
Oh yes! I was surprised. It's good to see the car I now I have isn't a worry when it comes to lubrication.
2008 Honda Odyssey
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: JohnnyJohnson] #5412802 04/25/20 12:29 PM
T
T
Very minimal if any. Thing is, I live where there isn't any level ground, so I'm always checking it at the gas station, but the engine is never cooled down there for an accurate reading.
2008 Honda Odyssey
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: ToyotaNSaturn] #5414287 04/27/20 07:06 AM
The "slight coolant leak" is external (for now) most likely. If it is, you should be able to find some coolant along the lower edges of the heads; if you don't find it here it's likely not the problem. It's also why you need to use Subaru Coolant Conditioner (which is really just relabeled Holt's Radweld) when you change the coolant, every time. This helps keep those little weeps down, and yes, while not a fix, I've never had an EJ lose the HGs and have used SCC as recommended every time. Being a 2009, your car should have the revised, MLS HG, and should not have the same kinds of worries as the turn of the century EJ25s. If you have a coolant smell, I'd be checking the heater core and all the heater hose and radiator hose connections.
Re: 2009 Subaru Forester X, 2.5L, 110K, Bulk 5w-30, 0.75qt GC, 5200 miles [Re: SubieRubyRoo] #5416519 04/29/20 02:37 PM
Danr42 Offline
Check your valves lash at the same time. Commonly neglected and will catch up to you somewhere around 200k.
