Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
29 registered members (bworley, bachman, ajchien, ArrestMeRedZ, BlakeB, blufeb95, 2 invisible), 1,167 guests, and 35 spiders.
Topics305,879
Posts5,281,961
Members71,528
Stainless Steel tools #5412539 04/25/20 07:11 AM
Donald Offline OP
Amazon sells some expensive SS tool sets for keeping in your boat. Will the chromium (and ?? other metals) that are added make the tools significantly weaker that a normal tool? Wrenches bending?
2015 Ford F-250 w/Powerstroke
Re: Stainless Steel tools [Re: Donald] #5412547 04/25/20 07:23 AM
ABN_CBT_ENGR Offline
That's all a marketing gimmick
Like Bronze/Brass tools exist for non sparking situations- SS tools exist for certain applications like in the chemical industry or others where corrosion of ferric contamination can cause process issues in things like in food service, medical, certain chemicals like nitrates etc.
Some industries and processes wont allow the plated tooling for fear of the plating being damaged and exposing the CS
There is no significant difference in performance that I have ever seen or heard about (other than the cost)
I have heard accounts where they fracture sometimes as a result of a greater hardness to tempering ratio common to SS in any mixture but that's with cheater bars and impact usage ( personally I see almost the same with regular CS tools)
Re: Stainless Steel tools [Re: Donald] #5412571 04/25/20 08:28 AM
O
Oildudeny Offline
O
reminds me of a story..
boy takes his allowance to the bait and tackle shop and buys these fancy looking lures that are advertised to get you the biggest fish yet.
dad takes boy fishing and the boy thinks he's going to now out fish his old man with his new fancy lures... times goes on boy has little to no more bites than the old man.
old man says son, let me tell you something the only "big catch" of the day was you buying them fancy lures.
you dont need ss tools for working on a boat get yourself a can of wd40 or supertech spray lube and an old sock. wipe your tools down when you're finished save your money.
Re: Stainless Steel tools [Re: Donald] #5412577 04/25/20 08:35 AM
Driz Offline
The simple solution is better. Take a small water tight box like an ammo box or 2 that HF sells. Get the basic Chinese wrenches and screwdrivers, vise grips small hammer a crescent duck tape ect. . You’re good to go for anything that you realistically can do out on the water. I just oil mine up yearly like a gun yearly when they come out of the basement for the season. Never a problem.
Re: Stainless Steel tools [Re: Driz] #5412590 04/25/20 08:50 AM
WORD! That's exactly what I do too
Re: Stainless Steel tools [Re: Donald] #5412603 04/25/20 09:10 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
The 440 grade of steel is most popular for tool steel applications. It is used when you need tool steel together with corrosion resistance. It is made for quench and tempering.
Re: Stainless Steel tools [Re: Oildudeny] #5412622 04/25/20 09:47 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
+1. On the boat, my FIL keeps his tools in a sealable box with a bit of baby powder. Seems to keep them well enough.
Re: Stainless Steel tools [Re: Donald] #5412812 04/25/20 12:41 PM
Dave9 Offline
Yes stainless is weaker but a properly designed tool will have that taken into account and be built adequate for its intended use, unless of course, it is generic junk. Also consider that there are different stainless grades trading hardness for corrosion resistance, at least within affordable alloys.
