Forums Migration
Please read this thread
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
58 registered members (blufeb95, Alex38, boom10ful, BlakeB, AITG, alcyon, 4 invisible), 1,091 guests, and 33 spiders.
Topics307,625
Posts5,314,458
Members71,888
Stabil use in E0 pure gasoline #5412371 04/24/20 10:16 PM
Superbuick96 Offline OP
I'm fortunate to have a Circle K (rebranded Marathon)that sells ethanol free 90 octane gasoline, using it for all of my outdoor equipment with a dose of Stabil. I've been wondering do I need to use Stabil if I go through 2 gallons of gas approximately every 4 months between the mowers, and snowblower? The way I'm looking at it why burn and inhale more chemicals than I have too.
07 Saturn Vue 3.5 AWD M1 5w-20
18 Subaru Forester 2.5 M1 AFE 0w-20
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412376 04/24/20 10:25 PM
Chris142 Offline
Naw. Even e10 is ok to use if the equipment is used often.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412403 04/24/20 11:20 PM
T
TmanP Online Content
Online Content
T
I buy ethanol free 91 octane (from Kwik Trip) 3-5 gallons at a time for use in the (MTD) snowblower, (Honda) pressure washer, and (Honda) mower.
I don't bother treating it and it can last for 3+ months, often longer during spring and fall when those machines aren't in use. Nary a problem, and the Hondas are 2-pull starts.
The leaf blower and trimmer get the same 91 octane mixed with Stihl synthetic oil. That does include a stabilizer, but I don't add any extra.
I wouldn't worry about it. E0 is already great for storage/limited use.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412523 04/25/20 06:44 AM
Slick17601 Offline
I still put it in just for peace of mind.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412528 04/25/20 06:57 AM
4WD Offline
I buy E0 in 92 octane. Use it in a small boat that makes only about 4 outings a year … so use Techron marine multi purpose that claims it has pretty much all fuel related issues addressed.
What E0 stays in a can for small engines has normal stabil since it might take a year to use it up.
My Stihl gets can gas … by using my electric saws for lighter stuff often … it’s seeing less duty.
Lastly … lawn tractor burns enough gas that E10 is fine … with a shot of gumout PEA
https://boatus.com/magazine/2011/december/ethanol.asp
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412535 04/25/20 07:05 AM
CT8 Offline
Marketing works.
2015 F150 2.7
2018 F350 6.2
Re: Stabil use in E0 pure gasoline [Re: CT8] #5412544 04/25/20 07:16 AM
4WD Offline
Exactly what do you mean … post that enough times and what ?
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5412710 04/25/20 10:55 AM
J
JohnG Offline
J
The biggest issue I've had with Ethanol gas in small engine is its impact on plastic and rubber parts. I have an old chain saw that actually had the screw in gas cap swell up so bad that it wouldn't fit any longer! After that I use 0E gas in them, but if I don't have that, I just drain the tank out and leave the cap off after I use it.
Re: Stabil use in E0 pure gasoline [Re: Slick17601] #5414837 04/27/20 04:59 PM
Duffyjr Offline
Same here, been doing it for so long I"m afraid the world may come to an end if I don't. banana
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5416827 04/29/20 08:20 PM
ChrisD46 Offline
Sometimes I can find non - ethanol regular 87 at a local gas station - if not , I'll bite the bullet and buy a can of True Fuel from Home Depot , Lowes , etc. and use as my last mower fill before putting the mower away for the season .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Stabil use in E0 pure gasoline [Re: Superbuick96] #5417437 04/30/20 02:41 PM
DGXR Offline
At your rate of usage, you can run whatever gas you want without concern. I recommend a busy station so the gas is relatively fresh.
I use Sta-bil in the dirt bikes regularly because I never know how long they are going to sit. I ride them often in the warmer months but still there have been times when life happened and they sat for many months. So I like to keep them protected. I use it in the mower only during the winter when it usually sits for 3-4 months at a time, and even then a use will only burn 1/3 of a tank of fuel. I use the car and pickup year-round and I practically never use stabilizer in them.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
