Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
79 registered members (1978elcamino, 2015_PSD, alchargo, AndyB, akh, 53' Stude, 9 invisible), 1,949 guests, and 38 spiders.
Topics306,053
Posts5,286,477
Members71,593
'13 Honda FIT : NAPA engine oil and transmission crush washers #5412102 04/24/20 03:45 PM
O
odie Offline OP
O
Anyone use / used the NAPA Solutions oil drain plug gasket NOE 7041954 and Altrom ATM PB3001 automatic transmission drain plug ? Thanks
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: odie] #5412113 04/24/20 04:00 PM
J
Jake_J Offline
J
They're just crush washer's I'm sure they work fine. Personally I've reused the oil drain plug crush washers many times in various Honda's and they generally won't leak unless somebody has over tightened them before. Honda does advise to replace them everytime officially.
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: odie] #5412122 04/24/20 04:09 PM
K
krismoriah72 Offline
K
I think i did 12 oil changes in my 2012 Fit and used the same crush washer..never a leak.
If i did want to get a new crush washer may as well get a magnetic plug while i was at it.
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: odie] #5412234 04/24/20 07:18 PM
T
Timmastertech Offline
T
We get the drain plug washers from the local honda dealer in bags of 50 for the oil plug. I dont like how the aftermarket gaskets fit, they are a bit too big ID for my liking compared to the Honda washers. I think they are somewhere around 50 cents each, 94109-14000. That trans plug gasket is a copper gasket, the factory gasket is aluminum. We keep a few different sizes of them in stock in Genuine Honda. not real expensive.
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: odie] #5412374 04/24/20 10:19 PM
M
Mainia Offline
M
My drain plug gasket on my 2009 Honda Fit lasted years without a leak. I see posts on people getting all anal on a fricken oil gasket every oil change, I look at their post and shake my head and groan like Lurch of the Addams family.
https://youtu.be/xCc-RWIp7XU
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: odie] #5412424 04/25/20 12:03 AM
M
michaelluscher Offline
M
It should be okay
But I had a batch of 18mm aluminum crush washers from Dormant that leaked
Application was a Toyota transmission drain plug gasket
The ones from Toyota looked similar, but they didn't leak
confused I don't know anymore
'17 CTS Performance AWD 3.6 11K
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: '13 Honda FIT : NAPA engine oil and transmission crush washers [Re: michaelluscher] #5412434 04/25/20 12:28 AM
clinebarger Offline
You're surprised Dorman is junk?
2001 Chevy Camaro L92/4L80E
