Wow. That is some ramp setup.
I had to Google the word dunnage
If this is show and tell...
Used these for over 20 years made from three 2x6 boards five thick. You can even have one side of the car higher than the other if the oil drain plug is on the side of the engine.
For sure … my “glued & screwed” Pine-O-Ramps are 5 layers of 2x10 and are very heavy.OP's ramp was light plastic. These probably weight 30 pounds each.
Could use this as a high wire act .If this is show and tell...
