Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
85 registered members (55hambone, 1978elcamino, 2015_PSD, 64bawagon, 97prizm, alchargo, 11 invisible), 2,054 guests, and 91 spiders.
Topics306,053
Posts5,286,491
Members71,593
Automatic climate control acting wonky #5412050 04/24/20 02:34 PM
M
mclasser Offline OP
M
This is on my Pilot.
I noticed something funny with my ACC this winter. I leave it on 73 AUTO and normally, it would blow hot and fast during the first few miles to warm up the cabin, then gradually slow down/increase as needed to maintain the 73 set point. That's the whole point of automatic CC, right?
But now, it keeps blowing hot and fast and 'forgets' to drop down. I've driven on 30 min trips where it kept blowing hot & fast the whole time. As you can imagine, the cabin gets uncomfortably warm and I have to manually turn it down to like 70 to get some cooler air.
I've had this car since new and never had this sort of issue. What could be going on here? Is there a way to 'reset' the ACC?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Automatic climate control acting wonky [Re: mclasser] #5412066 04/24/20 02:48 PM
B
BMWTurboDzl Offline
B
Clean the cabin temp sensor with rubbing alcohol?
435i
Re: Automatic climate control acting wonky [Re: mclasser] #5412078 04/24/20 03:13 PM
W
Wolf359 Offline
W
Yeah, I'm going to guess temperature sensor. My car has the dual climate control and it actually has several sensors so I'm guessing one of them is bad. Mine showed up with a car specific scanner. Probably won't show up with a regular scanner that only does engine and emissions codes.
Re: Automatic climate control acting wonky [Re: mclasser] #5412093 04/24/20 03:32 PM
M
MCompact Online Content
Online Content
M
BMW's have a blower motor resistor which can cause similar issues when it fails. I'd scan the system as Wolf359 recommends before you start throwing parts at it.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Automatic climate control acting wonky [Re: mclasser] #5412099 04/24/20 03:39 PM
L
LazyDog Offline
L
Also check or replace cabin filter!
Re: Automatic climate control acting wonky [Re: mclasser] #5412108 04/24/20 03:55 PM
L
Lolvoguy Offline
L
Why not simply use the manual climate control controls?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Automatic climate control acting wonky [Re: Lolvoguy] #5412154 04/24/20 05:03 PM
W
Wolf359 Offline
W
I don't think you understand how you're supposed to use automatic climate control.
Re: Automatic climate control acting wonky [Re: mclasser] #5412172 04/24/20 05:33 PM
1
14Accent Offline
1
Easy enough to grab a can of compressed air and blow it into the in-car sensor. It's mounted to the driver's lower panel, on the far left. Looks like you just pull the left side dash trim (where the door closes), then take out a screw and the panel pops out. Clean the sensor, try the system and see what happens now.
Also, if you want to test the sensor, the specs are as follows, using a meter between pins 3 and 4 of the sensor. 3 and 4 are the 3rd and 4th from the left, with the connector tab facing up.
14 degrees - 7k ohms
32 - 5k ohms
50 - 3.5k ohms
68 - 2.2k ohms
86 - 1.5k ohms
104 - 1k ohms
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Automatic climate control acting wonky [Re: Wolf359] #5412458 04/25/20 01:53 AM
L
Lolvoguy Offline
L
Oh I understand alright, I have them on the Lexus and I use the manual function instead.
Say "no" to Turbo!
Re: Automatic climate control acting wonky [Re: MCompact] #5412507 04/25/20 06:19 AM
G
GMBoy Offline
G
This. ^^^^^
The fan is controlled by either a resister or a small module near the HVAC box. Auto CC usually has the module and manual systems a resister pack. I had the same symptom in my 2006 Denali which was the module near the blower. Also did it on a 2011 Lincoln. Check Rock Auto for the part.
Re: Automatic climate control acting wonky [Re: Lolvoguy] #5413108 04/25/20 06:51 PM
W
Wolf359 Offline
W
It's pretty clear you don't. It's automatic so you just set it and forget it. If you're using the manual controls, that defeats the point of the automatic. You mind as well walk when you have a car that you can drive places.
Basically the point was that if you have to use the manual controls because the automatic one is broken, then you should fix the automatic one. Otherwise that's like turning up the radio so you don't hear the noise that the car is making.
Re: Automatic climate control acting wonky [Re: 14Accent] #5415732 04/28/20 03:46 PM
M
mclasser Offline OP
M
32 - 5k ohms
50 - 3.5k ohms
68 - 2.2k ohms
86 - 1.5k ohms
104 - 1k ohms
I appreciate this info. Took a quick look and there is no dust at least on the outside slits. Shined a light and didn't see any visible dust behind the slits either. I'm gonna wait until it warms up to see if it behaves the same during A/C season. If it does, I'll open everything up for testing/cleanup.
Cabin filter is clean. Some peeps mentioned the blower motor resistor. When I turn the temp down, the fan speed also slows down. Wouldn't a bad resistor not respond/keep blowing on high?
