Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
97 registered members (830Lee, 2_Tall_Mitchell, 53' Stude, 2010Civic, 1911CHAMPION, ABerns, 4 invisible), 1,991 guests, and 58 spiders.
Topics306,089
Posts5,287,231
Members71,596
Castro Edge 0w/40 2013 BMW N52 #5411834 04/24/20 08:23 AM
G
GJM120 Offline OP
G
Slow getting this out here.
This was an very short change interval mileage wise. It was a year from the last change and I've been going on 7,000 miles or a year - whichever comes first. The car does often see short runs (~8 miles)
Blackstone thinks I could wait longer. I do my own changes and it's pretty inexpensive so I'm inclined to stay with my current regimen.
The only thing I wondered about is the 100 C vis was down a bit from the virgin spec of 13.1.
Attached PDF document
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411877 04/24/20 09:37 AM
G
gonefishin Offline
G
If it were mine, I would stick with your once a year regiment. Cheap insurance and it gives you an opportunity to look for any leaks developing while you are under the car.
I see what Blackstone is saying about oil is just sitting in the oil pan. My belief is it makes a difference if your car is garage kept or parked in the driveway. A garage kept, seldom ran vehicle is in a more climate controlled environment. The oil in the pan with a car in the driveway is subject to wide variations in heat and cold, humidity changes, condensation opportunities, etc.
Edge 0w40 is the same oil I use in the wife's BMW with confidence.
2015 Cadillac SRX
2014 BMW 528i
2004 Chevrolet Trailblazer 4.2
1969 Chevy Camaro
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411896 04/24/20 10:12 AM
M
mightymousetech Offline
M
The viscosity degrade is probably just due to fuel dilution. Try taking it on longer highway runs more frequently, or just take the long way home to get the oil up to temp. I would still to the once a year. If doing it yourself, it is extremely cheap insurance. Why worry about $40-$50/year?
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411908 04/24/20 10:28 AM
T
TiGeo Online Content
Online Content
T
The drop in viscosity seems pretty normal to me?
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly 5W40 VW filter+Ceratec/MoS2
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411917 04/24/20 10:39 AM
G
GJM120 Offline OP
G
Humidity isn't terrible high here and the car is garaged. Viscosity drop is probably fuel dilution as mightmousetech mentioned. Looking at a recent Edge 5W/40 UOA posted on here, the vis at 100 went from 14.1 to 11.22 after 9,500 miles. So I guess my decrease isn't that severe.
Certainly going to keep on doing 1 year or mileage.
BTW - this was the older German/Belgian Edge. I still have one more o/c left as I loaded up on it when it was cheap at WalMart.
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411961 04/24/20 11:51 AM
K
KCJeep Offline
K
Most of the Xw40's seem to shear down to about that range, regardless of brand. I have heard of no issues because of it, and certainly the manufacturers that spec those oils must be aware of it and are apparently unconcerned.
I personally doubt you are having much fuel dilution with a flashpoint of 410. I think it does confirm (as often speculated here) most shear occurs earlier in an OCI.
2018 VW Passat GT VR6 - 28k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 107k - Valvoline Maxlife 5w30
2012 VW Tiguan 108k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5411981 04/24/20 12:35 PM
K
kschachn Offline
K
Along with an apparent inability to accurately measure flash point, Blackstone has also demonstrated difficulty in measuring viscosity.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Castro Edge 0w/40 2013 BMW N52 [Re: kschachn] #5412140 04/24/20 04:45 PM
The Critic Online Crying
Online Crying
Are they even an accredited lab?
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5413321 04/26/20 01:14 AM
edyvw Online Content
Online Content
That is significant drop for 1800 miles run, especially in port-injected engine.
Are coil packs OK? You need to run that thing longer on the road. I have never had Castrol 0W40 or Mobil1 0W40 drop below 12 in my DI cars, let alone port-injected.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Castro Edge 0w/40 2013 BMW N52 [Re: edyvw] #5413844 04/26/20 03:22 PM
G
GJM120 Offline OP
G
No issues with ignition whatsoever. Plugs were changed just about the time of putting in that oil. Like I mentioned in another thread, the Edge 0W/40 starts out with a 100C vis of 13.1. With that in mind, do you still think the degradation is a lot?
Re: Castro Edge 0w/40 2013 BMW N52 [Re: GJM120] #5413865 04/26/20 04:06 PM
G
GJM120 Offline OP
G
I'm editing this post -
Looking at other UOA's for the same oil (appreciating that each engine is different) this does seem like a big degradation. I'm really wondering if they messed up the analysis. Above posts cast some doubts on Blackstone's accuracy. Then when I look at the low fuel percentage and a flash point that is pretty much the virgin spec, I really start to think it's a bad analysis.
