Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
94 registered members (53' Stude, A310, 10WSmuckers, 4WD, ABN_CBT_ENGR, Al, 7 invisible), 2,503 guests, and 51 spiders.
Topics305,939
Posts5,283,333
Members71,540
2007 Duramax LBZ Delvac Extreme 10w30 #5411440 04/23/20 05:23 PM
P
Ponch Offline OP
P
Hello all,
I wanted to post my recent Black stone labs UOA on my rig with this Mobil delvac extreme 10w30 syn blend (CK4)
167,000 miles on motor.
10,600 miles on oil with 1.5 quarts added.
Ac Delco oil filter
S and B dry air filter
SUS viscosity @210f 65.7
CST viscosity 11.79
Flashpoint 420
Trace of fuel noted, no TBN test.
Aluminum 4
Chromium 1
Iron 18
Copper 2
Lead 0
Tin 1
Molybdenum 54
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 3
Boron 59
Silicon 9
Sodium 4
Calcium 1831
Magnesium 631
Phosphorus 1440
Zinc 1464
Barium 0
I had bought this oil on clearance, and haven’t done a UOA in a few years. I had refilled with delvac 1300 15/40 also bought on clearance. The delvac 1300 refill is the CK/4 SN rated oil which I hear some people fret about the limit on zinc.. but I don’t believe it should cause me any concern.
Have a great day folks.
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5411446 04/23/20 05:26 PM
M
mattd Offline
M
No real wear metals to speak of other than iron. Looks good. Al is still low at 4 ppm.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5411761 04/24/20 04:24 AM
U
userfriendly Online Content
Online Content
U
With aluminum block and heads, I've concluded that the aluminum shown in Duramax UOAs is aluminum oxide and not a wear metal.
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5411797 04/24/20 07:14 AM
B
Bighorn2500 Offline
B
Looks great
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5411849 04/24/20 08:44 AM
SubieRubyRoo Offline
With iron at 18ppm on a 10.5k OCI, that's not a wear metal to speak of either. You're talking 1.7ppm per 1000 miles, and UOA is not a valid tool to assess wear anyways.
OP, report shows oil stayed in grade an no real fuel (FP 420*). Soot & insolubles reading would be the most important things after viscosity and FP, in my book at least. All the other stuff is just window dressing, doesn't really tell you much unless you have a trend and see a huge shift in a number. Thanks for the report!
De omnibus dubitandum.
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: userfriendly] #5411850 04/24/20 08:47 AM
M
mattd Offline
M
That duramax does not have an aluminum block.
ASE Master, L1, L2
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5412282 04/24/20 08:18 PM
U
Online Content
U
Right! The iron in the UOA is rust, or iron oxide. Not a wear metal.
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: userfriendly] #5412342 04/24/20 09:27 PM
M
mattd Offline
M
[/b]With aluminum block and heads,[b] I've concluded that the [/b]aluminum[b] shown in Duramax UOAs is aluminum oxide and not a wear metal.
That’s not what you said here, that’s all I’m saying.
ASE Master, L1, L2
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5412472 04/25/20 03:33 AM
U
Online Content
U
The P & Zn levels of the Mobil Delvac 10W30 & 15w40 Extreme should be of interest to owners of engines with flat tappet camshafts.
Mobil specs it as a "boosted formula". As a result, the 10W30 grade will not pass API SL.
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: Ponch] #5433897 05/20/20 06:49 AM
dnewton3 Offline
Global Moderator
Global Moderator
Typical boring Dmax UOA. Admirable wear rates.
The value in this UOA is that it, and hundreds of others like it, tell us that the Dmax 6.6L simply does not care what is in the crankcase as long as it's a suitable HDEO. It does not care about how hot or cold the ambient temps are. It does not care about how hard you work it (or not). It does not care if you OCI at 3k miles or 12k miles. The wear rates for Dmax 6.6L engines are very predictable and low-wearing, period.
Nothing to see here folks; move along. And that's a very good thing.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2007 Duramax LBZ Delvac Extreme 10w30 [Re: dnewton3] #5433941 05/20/20 08:01 AM
K
kschachn Offline
K
Illustrating again that despite all the hoopla over UOA on here to determine what is the "best" oil, within properly rated oils it is actually all about the engine and not the oil.
So much time and discussion goes into micro-analyzing UOA results and pontificating over how one oil is better than another when time and time again it's shown that the UOA does not illustrate an oil is better than another.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
