e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
82 registered members (4WD, 2015_PSD, BAJA_05, 94astro, Avery4, 2010Civic, 6 invisible), 2,213 guests, and 65 spiders.
Topics306,301
Posts5,289,834
Members71,618
2008 Kia Rondo 2.4 shift flare 2-3 when cold #5411087 04/23/20 09:57 AM
5
55Test Offline OP
5
So the '08 Kia Rondo 2.4 I've been driving has an annoying shift flare between 2nd and 3rd but only when it's cold. After the drivetrain is warmed up there is no more shift flare evident to me. To avoid this, when the vehicle is cold I'll let it idle 2 to 3 minutes to get some heat into it then drive off. This usually eliminates the issue for as long as I'm driving. The vehicle has 250000 kms on it and the transmission fluid was changed roughly 1.5 years ago and maybe had 6000-7000 km put on it since then. I was thinking about draining off some transmission fluid and putting some Lubegard Red or Platinum into it to see if it would help the issue. Would it have any effect or am I going to need to learn to live with it?
The total sum of everything I have learned from this website: ...Oil in engine, good!
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411101 04/23/20 10:23 AM
P
pandus13 Offline
P
What ATF fluid you have right now? Kia/Hyindai SP III? (Mitsubishi Diamond )
You could try a drain and fill with Castrol Import Multi-vehicle. I think it takes about 2 quarts.
drive 2 weeks, than do another drain and fill.
Had my Elantra some time ago, so not sure on capacity. i remember the original fluid went dark really quick.
I think at that time, on the hyundai forums, anything not dealer/original was fru-fru , but I think Lubegard red helped some.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411104 04/23/20 10:27 AM
Char Baby Offline
Have you ever changed the Rondos ATF? I change mine regularly.
Well, the LubeGard alone didn't work for me. I had shift flaring in a 2004 Altima 2.5S. Similar to yours, mine would flare between 2-3 and sometimes, 3-4 as well(but not quite as often).
Once flaring occures(slippage & over reving between shift changes) it is difficult or impossible to fix.
The(IMO) best thing to try is draining the ATF(pan drop) change the screen and refill with proper ATF(Hyundai/KIA SP III, Valvoline MaxLife, Castrol Transmax IMV) as well as(possibly but not necessarily) LubeGard RED or Platinum.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411311 04/23/20 02:29 PM
H
HyundaiAbuser Offline
H
Hyundai/kia sp3 darkens really quickly and I ran into this problem in an xx350 i used to own. I support the change fluid with castrol imv and using lubeguard red.
I'm also pretty sure idemitsu makes an sp3 alternative that you could try.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000
Supertech 10w40 High Mileage (RIP)
Valvoline Maxlife
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411339 04/23/20 03:00 PM
SubieRubyRoo Offline
Start off with checking the fluid level, cold. I don't know about Kias, but Subaru has a cold and hot range on the stick. Then check it hot. My Subaru showed in the middle of the hot range after running, but when cold was actually barely on the stick. I brought the level up to the high circle on the cold side and my cold shift flare disappeared.
If that doesn't help, do a D&F with the correct fluid. Add 1oz per qt of total transmission capacity of Lubegard Red. MolaKule said he'd never, ever, use or recommend Platinum as it is highly friction modified and you can't be sure what the resulting mix will end up as, possibly ruining your trans.
After the D&F, be sure to disconnect the battery for 10-15 minutes to let the TCM lose its memory, and therefore relearn the shift logic with clean fluid. It really does affect how your trans works. I spent $150 on Amsoil ATL for my Fusion (with the fussy 6F35) and changed out 4 full D&Fs and the trans still had shift flare after the fluid change. I did the battery thing and reset everything, and the trans shifted like new. Even if you only do a single D&F (roughly 1 gallon on most cars) I recommend resetting the logic.
De omnibus dubitandum.
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411394 04/23/20 04:22 PM
M
Mainia Offline
M
The fluid is low.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: 2008 Kia Rondo 2.4 shift flare 2-3 when cold [Re: 55Test] #5411441 04/23/20 05:23 PM
M
mattd Offline
M
You either have a piston seal that is tired, or a valve body issue/internal leakage. Low fluid should affect ALL shifts, not just one.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
