Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
73 registered members (4WD, 762fermeandyou, 86cutlass307, 55hambone, Astro14, aquariuscsm, 2 invisible), 2,030 guests, and 37 spiders.
Topics306,299
Posts5,289,806
Members71,618
Eneos 75w-90 Gear Oil #5410921 04/23/20 07:09 AM
K
klt1986 Offline OP
K
Anyone used or know much about Eneos 75w-90 Gear Oil? Getting ready to change the rear diff fluid in my 2011 Tundra. I was looking online at the local NAPA for an air filter and searched their selection of gear oils. It was the only gear oil that came up as a "direct fit" for the differentials and t-case on the Tundra. Surprisingly it was priced the same as M1 and Valvoline SynPower. In addition there was 20% off if you bought 3 or more items.
Re: Eneos 75w-90 Gear Oil [Re: klt1986] #5410966 04/23/20 08:15 AM
L
LoneRanger Offline
L
I used it in my 2009 Subaru Forester. Main reason was the unique situation with the Subaru manual transmission: Hypoid front differential located internally in the manual transmission sharing gear oil with it. Yellow metals in the transmission's synchro's do better with a GL4 but hypoid diff needs GL5. Could not use any gear oil with friction modifiers in it due to the synchro's. The formulation of the Eneos 75W-90 at the time was a decent compromise for the situation. I have only anecdotal info about it's performance however since I traded the car in before doing the next scheduled gear oil change on trans and rear diff (had it in rear diff too). I do know that it's not synthetic, or at least it wasn't at the time. I had emailed a company tech rep and their reply said it was not synthetic and that the performance criteria were accomplished with a conventional base oil. But that was in about 2011, so formulation could have changed since.
