Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
89 registered members (2010Civic, 53' Stude, ABN_CBT_ENGR, 2015_PSD, 2009Edge, Ag76, 9 invisible), 1,928 guests, and 37 spiders.
Topics306,089
Posts5,287,208
Members71,596
Oil Specification and Approvals #5410800 04/22/20 11:51 PM
O
OilUzer Offline OP
O
How different are the engine designs that require this many specifications?
I may have some gas, diesel and obsolete specs mixed in below but I'm also sure I have missed many as well.
Can't manufacturers get together and come up with some limited number of specs not to confuse the consumer? or it is entirely a money making machine? Licensing, etc.
Before joining bitog, when it came to engine oil, I don't recall paying attention to the specifications as long as the viscosity grade was what I wanted ... Not saying it was a good idea but do we really need this many specjfications?
BMW LONGLIFE-98
BMW LONGLIFE-01
MB-APPROVAL 229.5
MB-Approval 229.51
BMW Longlife-04
RENAULT RN0700
RENAULT RN0710
VW 502 00
VW 505 00
VW 501 01
VW 507 00
VOLVO VCC 95200356 (SERVICE FILL)
JAGUAR LAND ROVER STJLR.03.5004
JAGUAR LAND ROVER STJLR.03.5003
Jaguar Land Rover STJLR.03.5005
Jaguar Land Rover STJLR.03.5007
ACEA A1
ILSAC GF-5
ACEA A5
ACEA B5
ACEA A5/B5
ACEA A3/B4
ACEA ...
GM dexos1 Gen 2
GM dexos2
MAN M 3275-1
MB-Freigabe 229.1
MB-Freigabe 229.6
Porsche C30
VW 503 01(AUDI)
GM-LL-A-025
GM-LL-B-025
FORD WSS-M2C930-A
FORD WSS-M2C930-B
FORD WSS-M2C925-A
FORD WSS-M2C925-B
FORD WSS-M2C948-B
FORD WSS-M2C913-D
CHRYSLER MS-6395
NISSAN
MAZDA
SUZUKI
TOYOTA
FIAT 9.55535-CR1
HONDA/ACURA HTO-06
Re: Oil Specification and Approvals [Re: OilUzer] #5410810 04/23/20 12:35 AM
CPA1989 Offline
Wholeheartedly agree.
2020 Honda Civic Hatchback Sport 1.5T
2017 Ford Escape Titanium 1.5T
Re: Oil Specification and Approvals [Re: OilUzer] #5410812 04/23/20 12:45 AM
edyvw Online Content
Online Content
It is NOT money making machine. Stop with that conspiracy theory malarky.
VW charges approvals some $5,000. Not too expensive for XOM, don't you think?
No manufacturers cannot come up together as engines are different, have different issues etc.
It is not confusing (unless you own Hyundai) and you just have to follow approval your engine requires.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Oil Specification and Approvals [Re: edyvw] #5410828 04/23/20 01:36 AM
O
OilUzer Offline OP
O
I was thinking maybe it's about $ since I couldn't find a good reason and it was just a guess since we live in a capitalistic world. But you are right. didn't mean to develop a new conspiracy theory.
Having said that, I keep reading on this site that bearing clearances have been basically the same for the last 40 years ... what other parts of current engine designs are so different from each other that require so many different engine oil specifications?
btw, I found few more specs but can't edit my original post. There maybe lots more. Who knows.
Re: Oil Specification and Approvals [Re: OilUzer] #5410891 04/23/20 06:04 AM
SR5 Offline
I think BMW LL-98 was replaced by BMW LL-01, both are high SAPS. The BMW LL-04 is the low SAPS version of LL-01.
Similarly MB 229.3 was replaced by MB229.5 both are high SAPS, with MB229.51 being the low SAPS version.
VW 502/505 is the high SAPS version, always given as a pair, but strictly speaking the 502 is for petrol (gas) engines and 505 is for Diesel engines. This has mostly been replaced by the low SAPS 504/507 (gas/diesel).
All the above are high HTHS and so the high SAPS versions are based off ACEA A3/B4 (gas/diesel) while the low SAPS version is based off ACEA C3. These are the fundamental requirements that the OEMs above are built on.
Similarly Ford 913-D is based on ACEA A5/B5 and replaces the previous 913-C and 913-B. High SAPS but low HTHS.
After awhile a bit of a pattern slowly emerges.
Fundamental API or ACEA base requirements that OEMs are built on.
Then it’s Gas or Diesel, high HTHS or low HTHS, high SAPS or low SAPS.
It’s more about which overlap in the Venn Diagram are you the interested in, then ignoring the rest.
Sure a few random specs based on very specific tests, plus mid-SAPS oils etc.
But I find they sort of group and form clusters. A good oil in the cluster you are interested in tends to carry most of the specs in that cluster.
Eg in High-SAPS and high-HTHS you get Shell Helix Ultra which carries API SN, ACEA A3/B, BMW LL-01, MB 229.5, VW 502/505 and Porsche A40. It will never carry a low-SAPS or low-HTHS spec, because it isn’t that type of oil.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Oil Specification and Approvals [Re: OilUzer] #5410896 04/23/20 06:23 AM
K
kschachn Offline
K
And to further what SR5 has noted, many oils carry multiple approvals or specifications so it's not as if they only carry one and you're restricted some narrow selection. Some not so much, but for the majority this is true.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Oil Specification and Approvals [Re: OilUzer] #5410900 04/23/20 06:32 AM
B
BMWTurboDzl Offline
B
Answers:
No 1: Compatible with emissions regulations in various markets throughout the world which in part a determined by the amount of sulphur allowed in gas/diesel.
No 2: Compatible with intended operating environments in various markets throughout the world.
No 3: Consumer power-plant preferences within each individual market.
No 4: Help reach/maintain fleetwide FE requirements.
No 5: Compatible with the individual attributes of the power plant and meet acceptable wear rates.
No 6: Simplify consumer choice. Only on BITOG to we get into the weeds over the presence of additional certs.
For example if the United States and the EU had been synchronized with regards to sulfur levels for gasoline and diesel then half the euro oil certs would essentially disappear in these markets.
435i
Re: Oil Specification and Approvals [Re: OilUzer] #5410923 04/23/20 07:12 AM
SR5 Offline
I’ve removed some of the older specs that are covered by the newer specs already listed, plus put some base requirements in brackets after. Just the ones I (sort of) knew off the top of my head.
I’m sure some others can improve it more.
Originally Posted by OilUzer
BMW LONGLIFE-01 (A3/B4)
MB-APPROVAL 229.5 (A3/B4)
MB-Approval 229.51 (C3)
BMW Longlife-04 (C3)
RENAULT RN0700 (A3/B4)
RENAULT RN0710 (A3/B4)
VW 502 00 (A3/B4)
VW 505 00 (A3/B4)
VW 507 00 (C3)
JAGUAR LAND ROVER STJLR.03.5003 (= Ford 913D) (A5/B5)
ILSAC GF-5
ACEA A5/B5
ACEA A3/B4
GM dexos1 Gen 2
GM dexos2 (C3)
MAN M 3275-1
MB-Freigabe 229.1
MB-Freigabe 229.6
Porsche C30
FORD WSS-M2C930-B
FORD WSS-M2C925-B (5W20)
FORD WSS-M2C948-B (C2 5W20)
FORD WSS-M2C913-D (A5/B5 5W30)
CHRYSLER MS-6395 (SN)
NISSAN
MAZDA
SUZUKI
TOYOTA
FIAT 9.55535-CR1
Re: Oil Specification and Approvals [Re: OilUzer] #5410940 04/23/20 07:34 AM
B
Boomer Offline
B
VW 508 and 509
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Oil Specification and Approvals [Re: SR5] #5411543 04/23/20 06:58 PM
O
OilUzer Offline OP
O
Good idea @SR5.
It would be nice if there was an excel sheet showing which spec covers the others ... Like a parent spec and eliminating redundant specs. I need a more knowledgeable person to sort it out.
There is some element of automakers gone wild grin2
sometimes when a new spec is out, some oil companies claim that they have already been meeting it x many years ago ...
I think most good oils may already cover most of these specifications but can't print it.
To be honest with you, if for example I owned a BMW and did my typical oci which is on the conservative side, and my typical driving (conservative again), I would not be afraid of using oils that don't have LL this or that. Could be wrong again but even after being on bitog for a few years, give me my viscosity with a good Noack and reasonable hths (I'm a thickie) and I am good.
Re: Oil Specification and Approvals [Re: OilUzer] #5411691 04/23/20 10:32 PM
M
MCompact Online Content
Online Content
M
I don't understand what's so difficult about it; the owners manual states the approved specs, and most every spec is relatively easy to find. I'm not going to cut corners on the vehicles in my garage.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Oil Specification and Approvals [Re: OilUzer] #5411708 04/23/20 11:15 PM
Online Content
Good idea @SR5.
It is not that simple, that is why approvals exists so you do not have to guess or fall into that trap.
BMW LL specifications are constantly updated, as well as MB, VW etc. It is not all about HTHS or Noack. BMW for example is not that strict on Noack (though LL01 TPT oils have Noack of 6.8%) but it is on oxidation. LL approval tests are also specific to BMW valve mechanism, valvetronic Also, BMW latest LL update has more stringent test on oil interaction with gaskets.
However, BMW does not expect average customer to care about that, so they say: Use oil that is approved for LL01, and call it a day.
Re: Oil Specification and Approvals [Re: OilUzer] #5411856 04/24/20 08:55 AM
M
Online Content
M
The N12 in my R55 Clubman was using a quart of oil every 900 miles or so when I bought it; the PO had run a synthetic 5W-30 with no LL approvals. At the next oil change I switched to BMW TPT 0W-30(LL-01FE) and in less than 4000 miles oil consumption dropped by over 50%. In my opinion, using the correct oil spec in a BMW/MINI is a no-brainer.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: Oil Specification and Approvals [Re: MCompact] #5412165 04/24/20 05:19 PM
O
OilUzer Offline OP
O
True. in general, for average consumer that may not be a hardcore bitog member, it's best to stick with the spec and not to venture out. I agree with the comments about following the manufacturers spec.
I do crazy stuff ... for example i have a relatively new 0W20 car and seriously considering using a 0W30 A3/B4 API SL while others are excited about API SN+
However, in your particular case you went to a much better 0W base oil and potentially much better Noack as well. With the average 5W you could get an inferior oil and have to do more research.
Re: Oil Specification and Approvals [Re: OilUzer] #5412499 04/25/20 06:04 AM
M
M119 Offline
M
I believe some oils do not have the approvals for commercial reasons but are still really good. For exemple, Shell HX5 15W-40 is just rated as API SN and ACEA A3/B3 without any manufacturer's approval but it appears to be a better oil than other 15W-40 oils that carry approvals but are still rated as API SL.
In this case i think it meets specs like MB 229.1 whithout question but they dont care about obsolete specs and they dont want lower end oils to sell as much as the synthetics etc.
1998 Mercedes W202 C180 - 155K kms (Daily)
1995 Mercedes S124 E250 Diesel - 480K kms
1994 Pontiac Trans Sport V6 3.8 - 280K miles
