Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
81 registered members (antonmnster, bbhero, 92SL2_oilburner, Astro14, 5AcresAndAFool, 9 invisible), 2,088 guests, and 45 spiders.
Topics306,108
Posts5,286,608
Members71,586
100 ft garden hose (heavy duty) needed #5410779 04/22/20 11:13 PM
paulri Offline OP
It is time to buy a new garden hose--we use it for light watering, but we need it to be heavy duty b/c I often neglect to put it back on the wind up cart, so it does see a lot of desert sun.
I looked online and saw Gilmour had a lot of stars, but then on amazon when I filtered for verified purchase, it seemed like everyone was bashing it for falling apart & springing leaks.
We do not need to put out fires with this thing--just push enough water through a nozzle to water plants in the front yard. We just want one that won't crack in a year or so.
Any recommendations?
2005 Toyota Sienna LE; 171,000 miles
2006 Toyota Highlander Hybrid 136,000 miles
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410781 04/22/20 11:17 PM
R
RazorsEdge Offline
R
I use Flexzilla for gardening, washing vehicles, etc.
Schaeffer Oil πŸ‘πŸ˜Ž
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410827 04/23/20 01:31 AM
K
KenshinHimura Offline
K
If you are willing to spend about 130 or so, Parker makes a great rubber hose that should survive a lot of abuse.
Technor apex makes a good neverkink hose for a lower price point hose.
https://www.lowes.com/pd/Teknor-Ape...ink-Free-Vinyl-Gray-Coiled-Hose/50328063
Goodyear/Swan makes the Maxlite hose which is also decent as well
1997 Mitsubishi Eclipse Spyder Penzoil Plat 5w30 A Purple colored filter
2019 Hyundai Veloster Turbo QS 5W-30 OEM filter
Re: 100 ft garden hose (heavy duty) needed [Re: KenshinHimura] #5410830 04/23/20 01:41 AM
Z
ZeeOSix Offline
Z
I've got two of those hoses, and they are many years old now and are still good. Leave them out all summer long in the sun too.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410871 04/23/20 05:19 AM
Carmudgeon Offline
I have a couple of the Craftsman black rubber hoses from a few years back. Assuming they haven't changed, they are actually rubber, not vinyl hoses, which I despise.
I guess you have to buy them from Lowes instead of Sears now, but they are easy to check out in person at a store.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410885 04/23/20 05:39 AM
4WD Offline
For 100’ I bought a 75’ Gilmour commercial 3/4” that stays stretched along a fence line often. It’s tough but heavy. Then use a 25’ section of light and flexible 5/8” for the part you move around with the most …
I also put a valve between them to use while getting a sprinkler set just right.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410935 04/23/20 07:28 AM
Donald Offline
The Craftsman black rubber hoses are great hoses. Great warranty.
When I worked at Sears if the hose broke for any reason (hit by a wild toss of a Lawn Jart??) you cut off the ends and bring them in for a new hose.
2015 Ford F-250 w/Powerstroke
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410936 04/23/20 07:29 AM
B
Brybo86 Offline
B
NeverKink means "always kinked" in regular use.
You want a heavy black rubber type, they will kink easily but unkink easily and do not have the horrible memory of the neverkinks
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5410948 04/23/20 07:44 AM
K
krismoriah72 Offline
K
For $30 you can get 3/4 inch commercial duty 100footer from Harbor Freight.
https://www.harborfreight.com/34-in-x-100-ft-commercial-duty-garden-hose-63336.html
[Linked Image from shop.harborfreight.com]
Re: 100 ft garden hose (heavy duty) needed [Re: krismoriah72] #5410952 04/23/20 07:55 AM
1
1978elcamino Offline
1
i have two of those HF hoses and they are garbage. They kink and in weather below 60 degrees they are hard as a rock. I bought a few red hoses at Rural King, 100ft for 39.99 and are their farm and ranch I think. Def a heavy duty hose that will last.
Re: 100 ft garden hose (heavy duty) needed [Re: Carmudgeon] #5411005 04/23/20 08:51 AM
SeaJay Offline
I have one of those that I've been using for well over 20 years now, It stays connected to water full time over the spring, summer and fall months and is opened up when the shrubs need watering or the car needs a washing. I wouldn't be surprised if it would last another 20 years.
Re: 100 ft garden hose (heavy duty) needed [Re: 1978elcamino] #5411006 04/23/20 08:51 AM
K
K
Good to know.
I bought my 100ft one from an estate sale for $5 about 7 years ago. I saw the HF ones the other day and was on my list in case mine starts going bad.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5411009 04/23/20 08:53 AM
B
Blkstanger Offline
B
If you can find the Industrial-Grade Gatorhyde Garden Hose they are great. I bought one 5 years ago and it's still going strong. Home Depot used to carry them but they are discontinued.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5411010 04/23/20 08:54 AM
M
MasterSolenoid Offline
M
I have a RUBBER Hose made by Good-Year / it's made heavy duty.
You also want to look at the brass ends, the Threads need to be machined / cheaper ones have stamped/formed threads.
I recently bought one of those shrinking hoses which I like a lot for small jobs.
The Instructions say: to NOT leave it in the Sun when not being used.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: 100 ft garden hose (heavy duty) needed [Re: paulri] #5411017 04/23/20 08:57 AM
5
5AcresAndAFool Online Content
Online Content
5
The most economical hose I have found is the ones you get at sams club. I think they are 30 bucks and made in USA. I believe they are 100 or 125 foot.I have one that is 10 years old and still going, starting to crack though.
When I was a 3 or 4 years old I remember a garden hose that was light green with a yellow stripe, When we move it moved. My mother still has that hose, it is hard as a rock, but does not leak, at least it didn't last year. Its probably 40 years old....
