Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
84 registered members (53' Stude, 4WD, Alfred_B, 928, AlienBug, ABN_CBT_ENGR, 6 invisible), 2,377 guests, and 39 spiders.
Topics306,017
Posts5,284,902
Members71,558
2001 Tundra Pad Slap #5410378 04/22/20 02:12 PM
J
JeffKeryk Offline OP
J
Just did a pad slap on our trusty '01 Tundra. This truck is awesome; 199K and zero issues.
I never understood how the driver side pads could wear evenly, about half way, and the passenger pads were almost gone. Again, nice and even.
The old pads were the NAPA better pads, hybrid or something. Had about 40K. I surfaced the rotors at the time.
The new pads were the Raybestos E whatever pads. Like $25 at RA. I just lightly filed and greased the contact points and slid them in.
Easy peasy... The pedal is really good now.
The early Tundras like mine had a too small caliper and pad. If I really loaded down the truck or towed much I would upgrade to the later caliper.
But for now this thing needs nothing. All good.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5410422 04/22/20 03:03 PM
J
jrvn Offline
J
my Tacoma is close to due for front pads I think im getting ADVICS which are the same as OEM Toyota pads from RockAuto
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5410518 04/22/20 05:20 PM
Donald Offline
I know there will be disagreement but I am not a fan of filing the pad ears for a better fit. Quality pads should be machined so that is not needed. You are filing off a quality paint or coating and there is the chance it will rust. I know you will grease it. Still, I buy Akebono and never need to file the ears. I just pulled all the pads on wife's Crosstrek and wiped the the ears clean before applying a tiny amount of grease. The ears were shinny clean paint after wiping with a rag.
2015 Ford F-250 w/Powerstroke
Re: 2001 Tundra Pad Slap [Re: Donald] #5410527 04/22/20 05:30 PM
J
J
Agreed. I just cleaned up the crud and surface rust on the caliper contact points.
And there ain't much rust in sunny Silicon Valley.
The only thing the pad ears got was a little brake grease. and I wire wheeled the slide pins...
Nice and easy.
2018 Lexus RX450h
2006 Acura TSX
Re: 2001 Tundra Pad Slap [Re: Donald] #5410597 04/22/20 07:16 PM
G
Gebo Online Content
Online Content
G
I agree. I've never had to file my Toyota OEM pads.
grin
Only time I had a wear problem was before I knew where to grease.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5410598 04/22/20 07:19 PM
cos Offline
JeffKeryk,
Did you lube the slide pins?
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: 2001 Tundra Pad Slap [Re: cos] #5410645 04/22/20 08:10 PM
J
J
Originally Posted by cos
JeffKeryk,
Just to make sure, I slathered tons of grease everywhere. Worked pretty good too!
Wire wheel and light grease on the slide pins. I use a q-tip to put a little in the caliper holes (round file to clean) and apply a little grease as they slide in, only in the caliper contact area.
These brakes are pretty dang easy.
Now if I could just lift the FJ Cruiser alloys and (larger) tires... Sheesh.
2018 Lexus RX450h
2006 Acura TSX
Re: 2001 Tundra Pad Slap [Re: Gebo] #5410663 04/22/20 08:21 PM
J
J
grin
I've never filed any pad.
2018 Lexus RX450h
2006 Acura TSX
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5410783 04/22/20 11:18 PM
H
HangFire Offline
H
So then... your truck DOES have one issue.
Various musings: http://hangfire.net
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5410902 04/23/20 06:45 AM
Donald Offline
If it were my vehicle I would want to figure out why the pads are wearing unevenly side to side. At 200K I might replace both front flex brake hoses.
Re: 2001 Tundra Pad Slap [Re: JeffKeryk] #5411027 04/23/20 09:06 AM
J
J
Good points about the side to side uneven pad wear.
The truck does stop a little straighter now; it wasn't 100% before. Not bad, just not perfect.
So this is an improvement in a couple of ways.
All good and thanks for your comments.
2018 Lexus RX450h
2006 Acura TSX
Re: 2001 Tundra Pad Slap [Re: cos] #5411987 04/24/20 12:47 PM
The Critic Online Crying
Online Crying
JeffKeryk,
The 4-piston calipers on Toyota trucks do not need lube on the slide pins. They are exposed.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
