Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
103 registered members (antonmnster, Astro14, 5AcresAndAFool, 77GrandPrix, Alfred_B, 2015_PSD, 9 invisible), 2,171 guests, and 45 spiders.
Topics306,108
Posts5,286,598
Members71,586
Page 1 of 4 1 2 3 4
Alaska cold: pan heater vs 0w20 #5410371 04/22/20 02:04 PM
I
Iowegian Offline OP
I
Moving to the Delta Junction area in interior Alaska this summer....Covid-19 and open borders with Canada permitting. Temp routinely gets down to -40°F...sometimes colder.
No garage for a while.
Plan to use 0w20 Castrol Magnatec in both this fall. Pour point is -51°C/-60°F
Also changing out the transmission fluid. Mercon LV pour point is -48°C/-54°F
Transfer case in F150 uses Mercon LV.
Changing all differential fluids with Mag1 75w90 pour point is -51°C/-60°F (wish I knew what super tech's pds is!)
See signature for vehicle info. Both Transit and F150 have block heaters. First time transmission, transfer case, and differentials will be changed.
I plan to add a battery blanket to the F150 ( transit battery is under the driver's seat)
I can put heaters on the transmission, oil pan, and differentials....but do I really need to?
If I do, I figured that it would be best to run the wires to the front of the engine for easy access, to be close to blick heater cord, and securing them. But I also figure that would be a pita?
Appreciate any help and your experience.
Edit: not seeing my own signature...
2015 Transit 10 passenger. 3.7l. 42k miles
2016 F150 5.0l 54k miles.
2011 Equinox, 2.4l (dumped)
2009 Sienna, 3.5l sold
2015 Transit t150 10 passenger. 3.7l. 43k miles
2016 F150 5.0l with 3.73 gears. 54k miles
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410380 04/22/20 02:12 PM
sloinker Offline
At -40F your transmission won't shift above 2nd or 3rd for many a mile until the fluid temperature warms up a bit. The oil in the differentials will thicken enough to be readily noticeable. The warm engine will help heat the cabin sooner and the engine will start easier and faster. You will almost need to bring in two separate circuit feeds for all those heaters if you go that route.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410390 04/22/20 02:23 PM
CONMCK Offline
Nice to see your proactive, keep in mind there are 100's of thousands of vehicles out there today exposed to the -40 to -45 cold, even mine on occasion. 0w20, a weather front and a engine block heater should be suffice, battery blanket would be optional. I'm not sure what the rest do.
Re: Alaska cold: pan heater vs 0w20 [Re: CONMCK] #5410394 04/22/20 02:25 PM
I
Iowegian Offline OP
I
Actually I'm a bit OCD.
smirk2
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410397 04/22/20 02:26 PM
R
ragtoplvr Online Content
Online Content
R
At That temp I would also find a way to safely mount a small electric heater in the cab for defrosting and warming the cabin. I have used the ceramic cube type with success but never at -40, in Iowa it was -22F and it worked well. Cabin felt toasty after being outside. I moved south after that winter!!!! I suggest a winter front or carboard in front of radiator. Do you even need a radiator at that temp?
That way you can run with the heater off during engine warm up and maybe the first few miles so you get coolant hot faster.
Rod
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410403 04/22/20 02:34 PM
Danno Offline
I ran a fleet of 200, 2015-2016 Ford Transits with the 3.2L diesel.
What I landed on for guaranteed start was.
Battery tender junior to keep battery at peak - 125W
Stock block heater - 400W
Oil pan heater - 150W
We had box trucks so the up fitters wired it all through a shore plug at the front drivers side corner of the box.
Adding 150W pad heaters for the transmission and same for rear diff is doable on a 15amp service.
We used Wolverine pad heaters.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410406 04/22/20 02:37 PM
B
Barkleymut Offline
B
So a pad heater is just something you lay on the ground under the vehicle and plug it in?
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Alaska cold: pan heater vs 0w20 [Re: Barkleymut] #5410413 04/22/20 02:44 PM
I
Iowegian Offline OP
I
This is what he means by pad heater
https://www.etrailer.com/Vehicle-He...QFZL44yKq9Y-l0tyXMgM6CTgdHBoCveAQAvD_BwE
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410414 04/22/20 02:44 PM
J
JimPghPA Online Content
Online Content
J
Look up Webasto heaters on the internet. There are companies that install them for you, probably most of the companies that install them are in Canada and Alaska. You want to get the hydronic heaters that heat the engine through circulating the engine coolant through the Webasto heater. These systems even take over the controls of the vehicles cabin heater fan and pre-heat the cabin of the vehicle to the temperature you set, along with the engine. You can pre-program them when to turn on, and or turn them on by remote control. They run on a small amount of fuel from the vehicle, and a small amount of power from the vehicles battery. They have a microprocessor built into the system that automatically controls the unit and several built in safety features. They make units that run on Diesel and gasoline, and are even used in sleeper cabs of big-rigs, and their larger versions can heat a bus.
These units are not cheap, but they are nice to have. They do require some yearly maintenance, like replacing the combustion screen and fuel filter every year, and the glow plug every couple of years. Also use them sparingly, because they do use motors that have brushes in them for the combustion air fan, and the hydronic pump, and brush motors have a limit on how-many hours they last.
If your vehicle does not have a second battery, you might want to add one to insure the power draw from the Webasto does not drain the battery too much.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410416 04/22/20 02:50 PM
T
tundraotto Offline
T
Pad heaters are next to useless when it gets really cold. The cold engine block will absorb the heat from the lukewarm oil quickly. Engine blockheater (freezeplug heater) and/or Webasto is the right way to go.
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410417 04/22/20 02:51 PM
H
hemitom Offline
H
back in the early 2000s i used to leave for work around 4:30 in the morning , the last thing i wanted to do was fool around with a no start truck or car.
Always used a block heater but some mornings things would just not turn over quick enough, added a 1 amp trickle charger, boy what a difference i swear they would spin over as if it was summer out what a difference a fully charged battery makes at minus 40.
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410420 04/22/20 03:00 PM
P
Pelican Offline
P
Re: Alaska cold: pan heater vs 0w20 [Re: Iowegian] #5410421 04/22/20 03:03 PM
demarpaint Offline
I found a combo of a block heater and Wolverine oil pan heater work well in extreme cold.
God Bless Our Troops
Re: Alaska cold: pan heater vs 0w20 [Re: tundraotto] #5410425 04/22/20 03:13 PM
L
Lolvoguy Offline
L
Pad heaters are meant to keep the oil "lukewarm" so it pumps faster to the critical engine components.
This is why they are usually employed in conjunction with block heaters.
To the OP, most people do not waste this much money and effort on their vehicles up here.
Combined with harsh cold, there's pot holes and salt/sand than accelerates the aging process of the body and suspension.
If your objective is to keep the powertrain minty, then by all means, go for it.
But as many others have discovered, this is an exercise in futility.
coffee
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Alaska cold: pan heater vs 0w20 [Re: JimPghPA] #5410429 04/22/20 03:18 PM
I
Iowegian Offline OP
I
Looked it up....thanks for the tip but yes, expensive.
Page 1 of 4 1 2 3 4
