Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
87 registered members (555, 55hambone, 830Lee, 1978elcamino, 2015_PSD, 64bawagon, 9 invisible), 2,147 guests, and 80 spiders.
Topics306,053
Posts5,286,496
Members71,593
Page 1 of 3 1 2 3
Trouble with my Samsung Fridge #5410279 04/22/20 11:39 AM
sasilverbullet Offline OP
I just bought a home that has a Samsung Fridge, model RS2534VQ. I'm having issues with it leaking water under the front left corner. What I could find online says the condenser drain inside the fridge is either frozen or clogged. I tried using a blow dryer on it, made some difference, but still leaks water.
Can anyone please tell me how to fix it?
Also, anyone know how old it is? Info from the tag: Compressor: MK183C-L2U Model Code: RS2434VQ/XAA S/N: 952143CX600486 T
Thanks!
03 Porsche 911 Driven DT-40 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410291 04/22/20 11:53 AM
O
Oildudeny Offline
O
check here on youtube. samsung defrost
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410292 04/22/20 11:53 AM
W
WhyMe Offline
W
one thing to check is that it is level front to back. if it the top front is angled downwards when it defrost the water sometimes drains out the front of the freezer area
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410302 04/22/20 12:00 PM
K
Kawiguy454 Offline
K
Any water that drips goes into a pan where it evaporates by airflow. pull it out and make sure it isn't blanketed with dust underneath blocking airflow. While pulled out you may also find lost car keys, oven mitts or assorted cat toys.
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410303 04/22/20 12:04 PM
Chris142 Online Content
Online Content
We have one too. It's garbage! The condensation drain is too small and plugs easily. I cut ours to make it drain correctly.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410312 04/22/20 12:09 PM
Dave9 Offline
First, get a length of stiff rope about the diameter of the drain hole in the interior bottom of the fridge, and run that through.
Next, pull it out, take the back cover off and locate the drain pan and the snorkel/chute/whatever going in it and run the rope up through that too. You may also need to clean the pan out if it is gunked with fungus, and while you're in there, clean out the dust, particularly on the fan blades and coils.
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410335 04/22/20 12:47 PM
A
Alfred_B Offline
A
We have had two Samsung fridges and both have the same issue. It's a crappy design.
I have placed a towel inside the fridge to soak up the water, and have a waterproof mat under it.
Right now me and my wife are negotiating whether we should get top of line LG fridge or some cheapo Whirlpool while I'm saving money for when she wins the argument.
Re: Trouble with my Samsung Fridge [Re: Alfred_B] #5410387 04/22/20 02:19 PM
T
tcp71 Online Content
Online Content
T
Linear compressor LG here. So far, (knock wood) it’s been great.
[Linked Image]
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410391 04/22/20 02:24 PM
L
LoneRanger Offline
L
You're not supposed to lay refrigerators on their side like that.
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410399 04/22/20 02:30 PM
4WD Online Confused
Online Confused
Had that in my apartment in S Korea … they came and switched for an LG
The LG washer leaked … but it was on a concrete overhang that went into drain.
That company has been busted for dumping here … will not buy them.
Re: Trouble with my Samsung Fridge [Re: tcp71] #5410407 04/22/20 02:37 PM
A
Alfred_B Offline
A
[Linked Image]
She wants one with a giant tablet on the door. 😥
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410440 04/22/20 03:34 PM
A
Aredeeem Offline
A
Had an LG reefer with the bottom freezer. Every few weeks would develop a glacier of ice under the freezer door which ultimately would restrict the closing of the door. I’m tired of the you tube work arounds and the handy man videos. Can someone manufacture an appliance that simply works for a reasonable period of time?.
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410471 04/22/20 04:25 PM
O
Oildudeny Offline
O
friend of mine in the appliance repair business always says steer clear from lg and samsung appliances.. they make good tvs and phones but not appliances.
also later model kenmore is a rebranded lg.. ge profile is usually what he would recommend to someone in the market for a new fridge.
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410505 04/22/20 05:06 PM
Donald Online Content
Online Content
I have a Liebherr that leaks if I do not unclog the drain in the back. Its not very big in diameter. I got the rope/twine handles from a paper bag with handles and push/twirl it down the hole pushing it about 6" in. Fine for another 2-3 months.
2015 Ford F-250 w/Powerstroke
Re: Trouble with my Samsung Fridge [Re: sasilverbullet] #5410506 04/22/20 05:07 PM
K
Kawiguy454 Offline
K
I have same LG as pictured and not a single issue in 2 years. Used to have a GE Profile which was also OK but the auto ice dispenser design was always chunking up. ...GE profile is no longer a US brand it was sold to CHfew years ago.
Page 1 of 3 1 2 3
