Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
98 registered members (01rangerxl, 10WSmuckers, 55hambone, 77GrandPrix, aquariuscsm, Astro14, 10 invisible), 1,763 guests, and 29 spiders.
Topics306,269
Posts5,289,303
Members71,616
Page 1 of 4 1 2 3 4
Anyone else pre-soak the filter? #5409865 04/21/20 08:53 PM
J
jqgz Offline OP
J
On both my vehicles I always pre soak the filter media in clean oil before installing it. Neither has a vertical mounted filter that I could fill; one is a top mount Subaru and the other a side mount Toyota catridge style filter. I picked up this habit from a relative who was an engineer and mentioned that a filter only filters when it's soaked in the media it needs to filter. Anyone else do this?
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409867 04/21/20 08:55 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I usually pre fill spin on filters. Never gave much thought to vertical cartridge filters...
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409873 04/21/20 09:05 PM
T
tblt44 Offline
T
Always.
I can fill it to the top/ overflow by the time it soaks in it's got very little in the filter.
Makes me feel good that it starts flowing sooner
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409879 04/21/20 09:17 PM
J
JeffKeryk Offline
J
I do if it doesn't make too much of a mess.
Even half way is good cuz the media soakes up the oil.
The 3 TSXs I service are horrible... The other cars are fine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409883 04/21/20 09:26 PM
blupupher Offline
Never done it with a cartridge filter, Guess I could on my Santa Fe, but really pointless IMO.
Being top mounted, there is not way to keep the filter slot filled, so it would still be empty on startup. What good would having already oiled media do for that 2 seconds while it fills?
For canister filters that mount thread end up I fill almost full. For sideways mounted, I fill 1/2 way and let it soak in, then add a little more right before I fill.
But only sometimes do I do this.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409885 04/21/20 09:28 PM
U
UG_Passat Offline
U
A top mount filter you can still pre-fill. You pour in enough that it soaks it up. Any oil left in the center tube, you can drain out back into the fresh oil container or crankcase. Use the mess you made on the filter to lube the O-ring.
Vertical cartridge filters, again, yes you can. You can only fill up as much as the media and whatever housing type it is takes.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409900 04/21/20 09:58 PM
M
mpack88 Offline
M
Ob2 gm cars have a mode called clear flood mode. If you step on the gas to the floor and turn the starter it won't start. I'll spin the engine over until the oil light goes out. Everything else get a lil oil in it if it wont make a mess. Some cars like ford small blocks and 4.6l filters have a tilt so I dont feel them all the way.
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409925 04/21/20 10:20 PM
Z
ZeeOSix Offline
Z
Why would a filter only filter if the media was pre-soaked with oil, lol. Some guys have some strange conceptions.
And yes, I pre-soak the media just because doing so also adds a bit more oil in the filter than just what the media can absorb.
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409938 04/21/20 11:12 PM
O
OS4A Offline
O
I pre fill/pre soak spin on and cartridge. Habit.
Doesn't hurt either way though. Personal choice.
2019 Subaru Impreza 5-door, Valvoline FS 0w-20 PBL14615 filter
2018 Honda Clarity PHEV, Valvoline FS 0w-20 PBL14610 filter
2017 Toyota Rav4 Hybrid, Valvoline ME 0w-20 PBL25608 filter
Re: Anyone else pre-soak the filter? [Re: jqgz] #5409946 04/21/20 11:20 PM
U
UG_Passat Offline
U
Maybe he's getting confused with K&N air filters. They filter better when they are dirty. OCD of clean oiled K&N air filters does more harm than good.
Re: Anyone else pre-soak the filter? [Re: jqgz] #5410011 04/22/20 05:09 AM
Char Baby Offline
Maybe your relative/engineer means that...a completely dry(just installed new filter) will go into bypass mode unless it has oil in it. So that the engine gets enough lubrication upon startup right after a fresh OCI...???
I mean, was there more to your relative's statement; a caveat to or a reason for their comment?
Or did your relative just make the statement and leave it go at that?
Were there any follow up questions asked to the relative/engineer? You know like, can you(engineer) elaborate further?
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Anyone else pre-soak the filter? [Re: jqgz] #5410032 04/22/20 06:13 AM
caprice_2nv Offline
I used to do it all the time on everything I could until I got ocd about the non filtered oil going in the clean side of the filter. This discussion has come up on here before. I still don't know whether it's better to have quicker oil pressure, or only oil that's already been filtered going straight to the bearings.
Cartridge filters I always did it in on customers ecotec engines in Cobalt's and cavalier's etc because the timing chain would rattle badly on first start after an oil change until I started soaking the cartridge before hand.
My personal cars don't make any dry noises even if I don't pre fill so I don't anymore. The 05 truck I could do the clear flood mode thing mentioned above, never thought about it before.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Anyone else pre-soak the filter? [Re: jqgz] #5410088 04/22/20 07:45 AM
T
tundraotto Offline
T
Always....shaves several seconds off the low oil pressure time on startup.
Re: Anyone else pre-soak the filter? [Re: jqgz] #5410102 04/22/20 08:02 AM
Chris142 Online Content
Online Content
If you do this you are supposed to fill it through the small holes. If you pour it into the big hole and there is any contamination in the oil or bottle it will go straight into the bearings unfiltered.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Anyone else pre-soak the filter? [Re: Chris142] #5410121 04/22/20 08:23 AM
T
tblt44 Offline
T
This is why it's important to check for metal shavings on the threads.
Dont believe filling it will change anything, I believe oil is pretty free of contanimants.
How in the world would you fill thru the small holes?
2006 Tahoe 5.3
Page 1 of 4 1 2 3 4
