Why would someone own both a hi-temp grease and non-hi-temp grease? Let's stick with lithium complex no 2 greases to keep things simple.
If water washout is not a concern then the hi-temp grease should cover every application, right?
I know in some cases, the non-hi-temp grease tends to be tackier which helps it cling to certain applications, but nowadays it is not difficult to find a hi-temp grease that checks off all the right boxes.
