The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
98 registered members (97prizm, Alfred_B, ABN_CBT_ENGR, 77GrandPrix, antonmnster, 928, 8 invisible), 2,251 guests, and 32 spiders.
Topics306,106
Posts5,286,527
Members71,586
Time to do the car trailer deck #5409756 04/21/20 06:50 PM
ls1mike Offline OP
Just getting started. It was due.
Had the wood delivered from a local place. 18 6in x 2in x 14ft pressure treated boards delivered was 300 bucks.
I didn't think that was too bad. Boards are actually 5.5in x 1.5in x 14ft, but most of you already knew that smile
I still have to get screws. Hope to have it done this weekend.
[Linked Image]
[Linked Image]
[Linked Image]
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Time to do the car trailer deck [Re: ls1mike] #5409769 04/21/20 07:01 PM
K
Kira Offline
K
In stead of wood we should have recycled plastic wood which doesn't get slippery when petroleum products drip on them.
It should come in a broad range of colors and last forever.
Good luck measuring and cutting.
Re: Time to do the car trailer deck [Re: ls1mike] #5409771 04/21/20 07:02 PM
dave123 Offline
Boy a quick sandblast and paint and it would really be looking good. It will look great with a new deck.
Re: Time to do the car trailer deck [Re: dave123] #5409773 04/21/20 07:07 PM
CT8 Offline
That is a great idea!
2015 F150 2.7
2018 F350 6.2
Re: Time to do the car trailer deck [Re: dave123] #5409781 04/21/20 07:13 PM
ls1mike Offline OP
I will pressure wash it and rattle can anything that needs it, but I don't want to spend a on ton it.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Time to do the car trailer deck [Re: Kira] #5409782 04/21/20 07:15 PM
ls1mike Offline OP
The main deck takes the 14 foot boards just right, the rear portion I have to cut.
There are two boards that will have to be ripped to like 3 inches.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Time to do the car trailer deck [Re: ls1mike] #5409859 04/21/20 08:47 PM
M
Miller88 Offline
M
I have kero/oil soaked 2x12s ready to go for mine. I hope that holds up as well as I've been told
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Time to do the car trailer deck [Re: ls1mike] #5409862 04/21/20 08:49 PM
Driz Offline
When I clean up something like that I knock the rust off it with a 4.5” grinder and wire wheel.to get the rust off . No need for rattle can paint on those frames. I just use a brush in those flat easily accessed areas. Prime 1 coat and two quick top coats. It’ll be thicker and hold up better than that thin rattle can enamel. Down in there is where the water ends up so square it away while you can get at it. Do it right while it’s apart and you’ll never need to touch it again.
Re: Time to do the car trailer deck [Re: ls1mike] #5409936 04/21/20 11:00 PM
B
BrocLuno Offline
B
I quit using speed screws on trailer decks a long time ago. That's a production speed thing. No need for a DIY r4epair. I just grind/cut the old ones off flush with the frame. Then slip the plank in and drill 1/4" down through the wood and frame flange. Carriage bolt and nylock on the bottom. Two for the front and rear frames if they are not tuck-in style. Alternate sides of the planks for bolts for the intermediate frames.
For HD tilt beads that will carry track equipment, I switch up to 3/8 bolts, same schedule. But I counter bore the top of the plank so the head is recessed so a tracks can't catch a bolt head and pull it out. Slop Cuprinol in the head pocket to stop debris rot from starting and bolt them down.
I switched to 2x12's a long time ago where the wheel or track loads are, skinnier planks only in the middle. The 2x12's bridge the frames better under load w/o splitting or breaking. That's why the alternate side bolt pattern to stop the expansion and shrinkage stresses from splitting the planks summer and winter.
In your case, you have tuck-in plank butts on the back end that float, so they should resist splitting well there smile
Re: Time to do the car trailer deck [Re: ls1mike] #5410079 04/22/20 07:36 AM
Z
Zaedock Offline
Z
Delivery was a nice option on the new boards. When I re-planked my trailer years ago, I stripped the old junk off, prepped the trailer, and then used it to pick up the new PT from the lumber yard.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Time to do the car trailer deck [Re: ls1mike] #5410093 04/22/20 07:54 AM
K
Kira Offline
K
So that's what the "PT" stands for in PT Cruiser?
Re: Time to do the car trailer deck [Re: ls1mike] #5410097 04/22/20 07:58 AM
Z
Zaedock Offline
Z
Those were "Pressure Treated" if female driven.... hide
Re: Time to do the car trailer deck [Re: Zaedock] #5410202 04/22/20 10:09 AM
Driz Offline
[quote=Zaedock]Those were "Pressure Treated" if female driven.... hide[/quote
🍿🍿🍿. You definitely gonna get a beatin for that one
Here’s one special no no for anyone redoing an ALUMINUM. Framed trailer. You can’t use Pressure treated lumber and have it touching the frame sections. The newer post 1988 ( green😾) pt wood causes corrosion on aluminum. boxing
Re: Time to do the car trailer deck [Re: Miller88] #5410324 04/22/20 12:31 PM
Donald Offline
You cannot get any liquid treatment very far into the wood without pressure. Or heat the treatment with the wood submerged in the treatment. Impractical for anything large.
2015 Ford F-250 w/Powerstroke
Re: Time to do the car trailer deck [Re: ls1mike] #5412999 04/25/20 04:39 PM
ls1mike Offline OP
Well almost done. I need to put some screws in the rear section but that is easy.
I put it back the way it was. I figured it lasted 17 years that way. My neighbor is a welder and took the back transition pieced off so we could use full 14 foot boards. He added a few supports and fixed one piece that holds the ramps. We slid the transition pieced back about 1/2 an inch, it also made it easy to install everything.
[Linked Image]
[Linked Image]
[Linked Image]
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
