Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
29 registered members (Danno, DaHen, CB900F2, bachman, Delta, ctechbob, 3 invisible), 754 guests, and 41 spiders.
Topics306,228
Posts5,288,638
Members71,608
Page 1 of 4 1 2 3 4
A little ramp mishap.. #5409612 04/21/20 03:28 PM
J
JTK Offline OP
J
I had a chance to finally chase a rattling heat shield issue on our 2015 Nissan Versa sedan today, so I figured I drive it up on my Rhino ramps. I must have gotten a little aggressive on the go pedal mid way up the ramps, causing the right side ramp to shoot rearwards towards the rear wheel. The vehicle then of course smashed down onto the ramp, causing the rocker panel pinch weld to chop through the plastic ramp like a meat cleaver. Rhino ramps do have rubber feet on them to prevent sliding, but maybe the cold temps and relative smoothness of the garage floor didn't help. The versa does have kind of a touchy tip in to the E-throttle which doesn't help. Probably lucky I was using plastic rhinos as opposed to my old steel set of ramps.
[Linked Image from i.imgur.com]
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: A little ramp mishap.. [Re: JTK] #5409620 04/21/20 03:34 PM
J
JohnG Offline
J
Oooops!
Glad nobody got hurt.
Re: A little ramp mishap.. [Re: JTK] #5409621 04/21/20 03:35 PM
B
Barkleymut Offline
B
wow, never thought about what would happen if you drove off the edge. I have a cheapo set from Harbour Freight that I use.....
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: A little ramp mishap.. [Re: JTK] #5409624 04/21/20 03:41 PM
R
R1jake Offline
R
On a concrete slick garage floor I always put something under the ramps to keep them from sliding only my set was wanting to slide forward before putting something underneath. Usually use a piece of carpet or something.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: A little ramp mishap.. [Re: JTK] #5409645 04/21/20 04:08 PM
A
AC1DD Offline
A
Kinda scary when you think about how fragile they are if you make a fairly common mistake....
Even if you use ramps ALWAYS use a SECONDARY support as a back up. Place a jack underneath on jack points and make sure the pad contacts the lift point.
It might save your life even if it takes a few extra minutes!
Re: A little ramp mishap.. [Re: JTK] #5409646 04/21/20 04:10 PM
M
mahansm Offline
M
I had that happen a few weeks ago when my daughter was driving her Odyssey onto a set of plastic ramps. She started to drift back and goosed the throttle. It spun the ramp under the right front tire back under the car.
No damage, easy recovery. Next try I drove it up and hit the throttle perfectly to put the car on the top section.
'14 Honda CR-V (toad)
'09 Honda Odyssey
'99 Bluebird Wanderlodge 43 LXi
Re: A little ramp mishap.. [Re: JTK] #5409652 04/21/20 04:28 PM
O
Oildudeny Offline
O
ouch duh
as long as you and the car is not hurt. all is good
Re: A little ramp mishap.. [Re: JTK] #5409656 04/21/20 04:36 PM
J
JeffKeryk Offline
J
You have waaaaay too much horsepower; it simply overpowered you.
Actually, I love my HF ramps, but thinks like this give me the heebie jeebies.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: A little ramp mishap.. [Re: JTK] #5409677 04/21/20 04:58 PM
K
Kira Offline
K
Actually, a relatively big shot of adrenaline coursed your veins; likely cleaning them.
You just pushed any circulation problem back 10 years. Natural SeaFoam.
Re: A little ramp mishap.. [Re: JeffKeryk] #5409678 04/21/20 04:59 PM
4WD Offline
I think the progression of steps on my Pine-O-Ramps handle forces different than a large angled face.
The last ramp I slung was a steel ramp going up 4 about a decade back.
Now I do one ramp, two ramp, and four ramp jobs without issues.
Re: A little ramp mishap.. [Re: R1jake] #5409703 04/21/20 05:37 PM
N
NormanBuntz Offline
N
Yep. I use two pieces of carpet padding on the smooth concrete.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: A little ramp mishap.. [Re: NormanBuntz] #5409726 04/21/20 06:14 PM
F
ffhdriver Offline
F
My ramps made out of a cross tie never moved, they were heavy.
Re: A little ramp mishap.. [Re: NormanBuntz] #5409728 04/21/20 06:18 PM
E
Egg_Head Offline
E
Great idea, Rhino Ramps + smooth concrete is dangerous especially w/FWD vehicles.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: A little ramp mishap.. [Re: JTK] #5409829 04/21/20 08:10 PM
Supersonic Offline
May not have helped in your situation, but I rock the car back a little and wedge the ramp under the tire.
Re: A little ramp mishap.. [Re: JTK] #5409863 04/21/20 08:50 PM
J
JTK Offline OP
J
Sad thing is, this ~47yr/old concrete garage floor isn't really smooth.
Like a poster above mentioned. What did me in is I lost momentum on my way up and goosed the throttle just a bit too much on this little 100hp monster. LOL!
A shame too because I liked these ramps. The one is now junk. I like the carpeting idea.
What sucks about a little econo box like this Versa is, everything underneath is flimsy sheet metal. I'm talking like soda can. You have to use the pinch welds for jacking. I've got 3 different 'pinch weld adapters' for my floor jacks. One puck, one fab'd aluminum job and one channel steel job. None of them are a really great fit on this car, but can be safely used.
I guess the good thing is a think I finally got the rattling heat shield fixed with by adding a fender washer to one of the screw mounts.
Disturbing the amount of under body rust spots on a 2015 with ~48K miles on it and I coated it with fluid film in the fall. Only owned the car a year.
Page 1 of 4 1 2 3 4
