Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
69 registered members (4WD, 2010Civic, ARB1977, 2004tdigls, 55hambone, Astro14, 3 invisible), 2,314 guests, and 47 spiders.
Topics306,296
Posts5,289,779
Members71,618
The ZX11 oil starvation conundrum #5409570 04/21/20 02:48 PM
IMSA_Racing_Fan Offline OP
OK oil gurus I place myself at your mercy. I have a pending deal on a theft recovery Kawasaki ZZR1200 which is complete but the owner bought it to swap the engine into his ZX11D model so it will come with the knocking connecting rod. I have rebuilt bike engines before and did some assembly work on hobby drag engines including supercharged gasoline and methanol fueled so I am temped to take the project on.
These engines had issues with oil starvation and many cures were developed from internal and external oil passage rerouting, restrictions to boost crankshaft pressure, and the cure that I am inclined to follow, deburring and port matching.
Do any modern oils offer a level of protection above those of the era? I used to run Valvoline automotive racing oil years back.
A thread I read carefully. TBH I got a headache trying to absorb it all.
https://www.zxforums.com/threads/oil-starvation-3-rod.5394/
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409593 04/21/20 03:12 PM
Z
ZeeOSix Offline
Z
I'm a bit confused ... so is this ZZR1200 has an older ZX11 engine put in it? Now do you know this ZX11 currently has a "knocking rod"?
I read through some of that thread, and what makes sense to me more than most of the talk in that thread is guys finding misaligned oil feed holes in the bearing cap (post #32 in that thread). That might also explain why not all ZX11s show this problem.
Different oils might give different levels of protection once metal-to-metal contact occurs, but journal bearing protection is mainly based on what viscosity is uses since journal bearings rely solely on hydrodynamic lubrication.
If there is an oil volume flow issue (as discussed in post #32) going on because of improper machining/manufacturing, then the issue isn't going to be saved by using different brand oil.
Re: The ZX11 oil starvation conundrum [Re: ZeeOSix] #5409611 04/21/20 03:28 PM
It is disassembled but complete sans a tire (I don't ride on old tires so not a problem) and comes with the ZX11 engine the guy swapped out.
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409618 04/21/20 03:34 PM
Z
ZeeOSix Offline
Z
What year ZX11 engine ... and how many miles on it?
Re: The ZX11 oil starvation conundrum [Re: ZeeOSix] #5409631 04/21/20 03:51 PM
1994 ZX11D, I don't have the mileage right now will ask (guess I should have already).
One side question:. I have always wondered about oil coolers on bikes and start-up. Since they're almost always mounted up high on the frame shouldn't there be an aeration/starvation in the first moment after starting?
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409650 04/21/20 04:16 PM
Z
ZeeOSix Offline
Z
Oil coolers are parallel flow, not series flow. So the main oiling system flow shouldn't be effected by an oil cooler.
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409657 04/21/20 04:38 PM
R
R1jake Offline
R
1991 kawasaki zx11 owner here back in the day anyway. I can even tell you which cylinder this will be. #3 I had this happen twice to my 1991 zx11. during the second instance we were in the process of going back together and while reading through a magazine I seen a add by falcon or falicon I’m pretty sure it was falcon. Anyway it read ZX11 owners trouble with #3 rod/crank issue we have the solution. I had to send them my oil pan and they did some type of mod that sent extra oil to that problem area. Never had a single issue again. And this bike was rode hard. We used to just do stand up wheelies on the highway and this is when it happened the first time. Not sure if falcon still exists but try researching this. It worked for me I sold the bike years later still running like a top.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: The ZX11 oil starvation conundrum [Re: R1jake] #5409730 04/21/20 06:21 PM
02SE Offline
It's Falicon. They're still around. Falicon Cranks
But it appears that their business model is possibly changing.
I have a Falicon forged stroker crank in my 'Busa. 285 rwhp, 160 rwlb-ft. No issues in 10 years in that configuration.
My '97 ZX-11D never had an issue with crank oiling. Cam pitting however was an issue.
Re: The ZX11 oil starvation conundrum [Re: 02SE] #5409737 04/21/20 06:28 PM
Wow thanks for that, will pull the cam cover.
Re: The ZX11 oil starvation conundrum [Re: R1jake] #5409747 04/21/20 06:39 PM
I performed a wheelie on a GPz750 with a fat kid on back for a crowd waiting for Iron Maiden tickets. He didn't hold onto my waist but my t-shirt, slid down stretching my shirt which put us vertical with his [censored] on the taillight. Came down hard sideways. The crowd cheered like mad and he jumped up with road rash on his chubby arm pumping his fist shouting "ROCK AND ROLL"!!!
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409753 04/21/20 06:49 PM
02SE Offline
Went to lots of concerts in the 80's, including Iron Maiden. Never came away with road rash, however. grin
Being a Motorcyclist back then, I did always have foam earplugs. They cut the decibel level enough that I still have pretty decent hearing today.
Re: The ZX11 oil starvation conundrum [Re: 02SE] #5409774 04/21/20 07:10 PM
On the same bike earlier that year a party I crashed ran out of beer so they gathered money for another keg. This one older, skinny drunk in cowboy boots asked me for a ride to the beer joint so I obliged.
As the caravan merged from one downtown highway to another I blew by pulling a power wheelie then felt a thunk under both armpits. It was cowboy boots! I slammed it down and his head thunked my helmet. Hard.
When we got to the bar the people in the were laughing, "man he was spread eagle with his head almost on the pavement" and that guy was like "sheeeit pardner I'm gonna ride in the truck goin' back".
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409895 04/21/20 09:42 PM
B
Bonz Online Content
Online Content
B
I know the ZRX 1200 pretty well and have a ZZR 1200 engine on a pallet in my garage that donated the cams and double valve springs into my ZRX 1200. I run a ZX11D ECU (in conjunction with the double valve springs allows an 11,500 RPM rev limit and provides the more aggressive timing advance curve of the ZX11) and timing rotor along with JE 12.5:1 pistons and have adapted ZX11/ZZR1200 40 mm carbs on to the side draft head. With a full muzzy exhaust system and stick coils from a ZX-14, the bike fairly much gets on down the road...
The rod knock could be from the engine being on its side if the bike was laid down. And it's typically the #4 bearing from oil starvation. Cam pitting typically is visible however is usually not an issue and thousands of ZX11's, ZZR1200's, ZRX1200's have been run over the years with pits that would make your eyes grow big in your head.
I had Webcam copy the ZZR1200 cam profile and they have those on file. The ZRX 1200 has to run the ZZR 1200 cams as they are a slightly different length than the ZX11 cams. ZX11 cams are plug and play into the ZRX1100. The ZZR1200 is the same profile as a ZX11 so if you send them cores they will make you a set of hard weld replacement cams. With that said, ZX11 cams are not that hard to come by so I would probably just keep buying cams if they pit and it bothers you. Otherwise just run then with pits and you'll never know the difference.
In terms of oil, your issue with a bearing isn't going to be as well addressed with additional zinc and phosphorus as it would be if you were talking protecting the valve train. The oil isn't going to fix the oil starvation problem. Pick any good motorcycle oil that has a good zinc content for that valve train because of the pitting issue and ride on.
Re: The ZX11 oil starvation conundrum [Re: IMSA_Racing_Fan] #5409960 04/21/20 11:49 PM
BusyLittleShop Offline
To test for a bad rod bearing set the engine at high idle and remove
one spark plug wire at a time... if the noise stops then that's the
cylinder with the bad rod... if noise continues after each spark plug
wires were removed then the noise is something other than a rod knock
because a rod will not produce a knock by just turning over the
piston... it takes the spark of combustion to produce a sharp metallic
sound...
Possible scuffed piston is one where it started to seize and the melted metal has
partial covered a piston ring... when a piston ring can not expand it makes a
sharp metallic sound as the piston knocks about the cylinder wall...
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: The ZX11 oil starvation conundrum [Re: Bonz] #5409970 04/22/20 12:33 AM
Wow you know your stuff. At this point I'm leaning towards not going through with the deal. In the worst case it has not merely worn but a spun bearing and damaged crank and I would be sinking more money into the bike than intended.
Then again cheap liter sportbikes are rare nowadays.
