Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
13 registered members (blufeb95, bbhero, Char Baby, bachman, BlakeB, 1 invisible), 1,150 guests, and 58 spiders.
Topics306,047
Posts5,286,359
Members71,593
Page 1 of 3 1 2 3
Anyone know about sink garbage disposers ? #5409562 04/21/20 02:34 PM
L
LoneRanger Offline OP
L
Disposer quit working, but only immediately after new dishwasher installed. Free install (dishwasher) from big box store using their contractor appliance installation service.
We have an insinkerator brand disposal, model is "badger." Estimate it to be maybe 5 yrs old. We bought house late 2018 and moved in early 2019. Prior owners did major kitchen remodel in 2015, new sink, counters, etc., so that's why I estimate age of the unit to be 5 yrs, plus it looks very good still.
So here's a head scratcher for you. It's been working perfect, no problems no weird noises. Yesterday we had a new dishwasher installed which is under cabinet next to sink. It was a Bosch 300 DXL which requires a special Bosch supplied junction box be installed on electric wire that supplies current to dishwasher. The previous dishwasher, also a Bosch (Ascentia) did not have nor require this box and was direct wired from Romex wire coming out of wall. That wire now goes into junction box and junction box output wire is a special Bosch supplied one that plugs into dishwasher underneath. Installers put in the junction box.
The dishwasher and the disposer are the only two appliances on the circuit with 20 amp breaker in the house's panel.
Tried the RESET button bottom of disposer, no joy. My wife said all she heard when flipping disposer on after breakfast was a "click" under the sink but no action from disposer. It's DOA for now. There are two Romex wires coming out of wall, one for disposer, one for dishwasher, as mentioned only two on the 20a circuit (#16 on panel). It is not tripping the breaker. The disposer's wire is ran in a metal conduit, wall-to-disposer.
I cannot see anything from the dishwasher install that would have borked the disposer, but it's just very coincidental that a 5 yr old disposer would fritz out at this particular time right in sync with install of the new dishwasher.
What am I missing?
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409564 04/21/20 02:40 PM
BlueOvalFitter Offline
The blades could be jammed/stuck. Use the double ended allen wrench that came with the disposer to unjam it. You stick it in the middle of the disposer at the very bottom and rotate it until you get it to rotate on its own.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409566 04/21/20 02:43 PM
T
tomcat27 Offline
T
jammed. or a loose wire (since it sounds like they did some rewiring.) are you comfortable taking apart access and checking to ensure that the wires are tight in the wire nuts? do you have a test meter?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Anyone know about sink garbage disposers ? [Re: tomcat27] #5409569 04/21/20 02:48 PM
If it were an electrical issue the dishwasher wouldn't work/run. He stated both appliances were on the same circuit.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409582 04/21/20 03:01 PM
L
L
Going to try the allen wrench trick first and see it if turns freely. If so, then will check wiring. I wish the builder had done this more conventionally and put a GFI receptacle on the wall under the sink for regular plug-ins, instead of direct wiring the thing to the romex wire coming out of the wall. Thing is, there's no slack in the romex wire and conduit, so to check if the wires are securely affixed into the disposer I pretty much have to leave it mounted and try to get to it that way, which for my size and the confines of the space in the cabinet under the sink is probably going to be a no-go.
I'm telling you, this house is turning out to be a money pit. It's just one thing after another.
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409584 04/21/20 03:06 PM
W
wog Offline
W
Check reset button in center of unit. Find it underneath,if it hums it is jammed shutoff and use allen wrench back and forth in center underneath.
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409587 04/21/20 03:07 PM
W
wog Offline
W
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409588 04/21/20 03:08 PM
J
JohnG Offline
J
So they screwed up the wiring. I don't see a big mystery here. Sorry.
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409592 04/21/20 03:11 PM
R
ragtoplvr Offline
R
There is a knockout that must be removed to attach the dishwasher. It is hard plastic. If it is left in the disposer it will jam over and over, too hard to grind.
Check reset button and use the wrench to unstick.
You can drop it very easy to look inside at the gross mess inside the grind chamber.
Rod
Re: Anyone know about sink garbage disposers ? [Re: wog] #5409600 04/21/20 03:19 PM
He tried that already. It just clicked. That's why I think the blades are jammed/stuck.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409604 04/21/20 03:21 PM
Is anyone here, besides me, ACTUALLY reading his post from beginning to end?
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Anyone know about sink garbage disposers ? [Re: ragtoplvr] #5409607 04/21/20 03:27 PM
DBMaster Offline
I would test the wires the disposer is connected to just to make sure you have your 110V there. If not, and it isn't jammed, it IS possible that the thing went out on you. But, in my experience, the Badger 5 models generally last about ten years. The Badger models have stainless steel blades and weights, but regular steel turntable, which rusts. If it rusts enough, the weights can stick.
Re: Anyone know about sink garbage disposers ? [Re: BlueOvalFitter] #5409622 04/21/20 03:39 PM
Chris Meutsch Offline
Having replaced a few Badgers in my time, yes. I'm your Huckleberry. Eagerly awaiting news!
2016 Toyota 4Runner Trail Premium, 58k
*RIP* 2005 Honda CR-V EX, 284k
Re: Anyone know about sink garbage disposers ? [Re: LoneRanger] #5409633 04/21/20 03:56 PM
I
Inspecktor Offline
I
It may just be a coincidence. My disposer locks up maybe twice a year, just hums and refused to turn. Socket on extension inserted through sink opening and turn nut on end of shaft a wee bit, back in operation.
2004 Mini Cooper 43,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 74,500 mi
2001 Buick LeSabre Limited 299,800 mi
2001 Subaru Outback 169,000 mi
Re: Anyone know about sink garbage disposers ? [Re: Chris Meutsch] #5409644 04/21/20 04:08 PM
thumbsup
2007 F150, 4.2 V6
"One Box, One OCI!"
Page 1 of 3 1 2 3
